Question about gracelyn Full-size Stroller: Graco Duo Glider Stroller: Meadow Menagerie
Release button broken
I can't open stroller
    New Friend:
  • 62 Answers
Unlatch storage latch on side. see page 9 of manual at the following web address. http://download.gracobaby.com/ProductInstructionManuals/PD161950A.pdf
Graco Customer Support is available Monday through Friday, 8am to 5pm EST.
800-345-4109 (US)
800-667-8184 (Canada - 8:30am to 5pm EST)
Posted on Apr 16, 2014
Stroller not folding. Locked in open position. How do I get it to fold again?
I Marion, I would have to see photos. is that possible?
Sep 14, 2014 | Baby Gear
Hi , I was given this stroller that's in great condition but it won't seem to close up . Is there any solution to this it's a safety 1st stroller.
I know you have to squeeze in on the grey center button (after you have removed the car seat). Push down slightly on the handle after you push and hold the button in to see if it releases the handle lower down near the wheels/frame. I have included a link to the instruction manual section of the manufacturers website where you can enter the info on your stroller and pull up the manual that will help you further with your folding issue. If something is broken, you can also find the customer service number on the website. Good Luck!
http://safety1st.djgusa.com/webapp/wcs/stores/servlet/InstructionSearchView?storeId=10154&catalogId=10051&langId=-1
Nov 08, 2013 | Baby Gear
I have a broken wing nut on my hadlebar. I'm
Depends on what's broken the wing nut is quite easy to get out, the plastic block it screws into is a bit more difficult. You need to take to top cap off (the black plastic cover where the extension handle comes out) It's held by either a small screw or a pop rivet. If a rivet you'll have to drill it out and replace with a self tapper screw or a new pop rivet. The wing nut assembly will now side up and you can access the screw at the back that keeps the wing nut from coming right out. If all you need to do is swap the wing nut you're done! But if you need to replace the plastic block you have to open up both sides, remove the handle release buttons and find a small Allen/hex key to release the plastic blocks clamped to the wire rods that links to the hubs. Then you can pull the extension handle out and access the screw blocks.
Aug 04, 2011 | Bugaboo 'Cameleon' Stroller
I don't know how to reverse the handlebars on the stroller.
The handle has two white release buttons, the one on the side opposite of the break lever has a smaller safety release button. You have to push the safety release button in than pull up on both release buttons. This whole handle lock assembly can get quite stiff without proper lubrication. Check my tips section for best ways to maintain your Bugaboo.
Feb 08, 2011 | Bugaboo Frog - Black Stroller
I received a replacement handle for my mutsy urban rider stroller, but cannot detach the broken one in order to replace it. how do you remove/replace a broken handle?
Remove the 5 screws from each seat holder clip. Remove half of the seat holder clip. Removing these will allow the handle to slide out. Hold the release button on the handle and pull the handle out of the frame.
Jan 10, 2011 | Mutsy Urban Rider Next Standard Stroller
The stroller is not folding
All strollers like a bit a lubricant and Silicon spray is the best (Bugaboo put a can in their maintenance kits for a reason) Buy a can and spray the handle release then work the release buttons back and fourth. Wipe off any excess with paper towels.
Dec 21, 2010 | Bugaboo Bee Stroller
Trouble opening and collapsing a quinny stroller
The Quinny Buzz can only be folded/unfolded with the seat in the most upright position facing forward. If this is the case and it won't unfold, remove the seat first by pushing down the two grey release buttons either side of the frame. It may be the case that the gas strut (automatic close/opening mechanism) is seized and will need replacing. This can only be done by Dorel UK 01842 763 281 as it is a pressurised unit. Hope this helps
May 28, 2010 | Quinny Buzz Jogger
Release button very difficult ro push. it is very
deborahzd, try to visit this site. Check page 26, illustration 35-37:
http://www.graco.net/common/sitemedia/6121GGG_ISPA083AA%20Manual.pdf
Read carefully the instruction. Hope this help your problem.
Feb 16, 2010 | Graco MetroLite Air 6116 Stroller
How do you unfold the power twin frame?
The release is on the right hand side of the pushchair when you are holding the handle bar. It is about two thirds of the way down and is usually light grey with open written on it. Put Jane powertwin into U tube and KiddieCare do a video to demo this.
Jan 13, 2010 | Jane Powertwin Azulon Stroller
Unfold my stroller?
I can't find a manual and I don't know this particular product but I always have to get this for my wife on our strollers... Usually on the side (one or both sides) there is a hook/button holding the metal together in folded position. It could even be in the handle, but its almost always on the sides. Its hard to see through all the bunched up fabric and metal, but I STRONGLY ENCOURAGE you to look again for the release. This little switch, clasp, lever, button or whatever should instantly pop this thing open or its broken!
Aug 28, 2007 | Baby Gear
gracelyn Full-size Stroller: Graco Duo Glider Stroller: Meadow Menagerie Logo
66 people viewed this question
Top gracelyn Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a gracelyn Baby Gear Expert? Answer questions, earn points and help others
