ERR HAS SHOWN UP IN WINDOW ON DR-3 NAKAMICHI TAPE DECK
AFTER RECORDING I PRESSED THE STOP BUTTON AND ERR CAME UU IN THE WINDOW NOTHING FUNCTIONS WHEN YOU PRESS ANY BUTTONS AND THE DOOR WILL NOT OPEN
  • Audio Player... Master
  • 1,258 Answers
It has a transport that needs attention. This is work for a Technician and they are still around but you need to find a good one. Nak units are best worked on by people that used to service them for the company. Tom in Nashville at HI Tech Service is one of those people.
Posted on Jan 02, 2015
robotek
  • 1512 Answers
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Posted on Dec 09, 2007
ctf1800
  • 4402 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
Have you checked all the drive belts? Some dual decks use one drive motor and a long belt to drive both decks.
you also should be able to remove the cover of the tape compartment off to see the deck better
Posted on Feb 07, 2008
SOURCE: CT-W602R Dual Cassette Deck- door won't open
had same problem, just changed the belts and works like new.
Posted on Nov 18, 2008
INTERLOGIC
  • 326 Answers
SOURCE: i have a tape stuck in my sony tc we645s cassette deck
try factory restore settings
Posted on Apr 14, 2009
robotek
  • 1512 Answers
SOURCE: I purchased a Nakamichi 480 tape deck from a
Hi there
It is probable that the head assembly or pinch roller assemblies are not returning to their correct rest position. The arms that carry the pinch roller assemblies develop dried grease problems in the bearing/post they are mounted to that prevent their timely return and fouling the casette shell preventing eject. Check them by seeing if they are clearing the cassette shell, and are "sprung into the home position with out binding.
I have repaired scores of these decks over the years, and am happy to talk to you more about the problem. Thanks for using FixYa.
regards robotek
Posted on Jul 08, 2009
Why wont my Nakamichi 680ZX tape deck record
It is strange that people go to belts when that has nothing to do with the problem at hand. The probably cause can be a defective record enable switch or there have been some Nak decks that have a defective capacitor in the Bias oscillator circuit. The only way to find out is to do the troubleshooting that is necessary. It may need belts but that does not stop a unit from recording. The deck is playing so the problem is with the Bias oscillator turning on. I bet it does not erase either.
Jul 05, 2014 | Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Nakamichi DR 10 does not eject. I loaded a cassette, pressed 'Play' the cassette played 10 seconds and stopped. The display showed 'ERR'. I removed the cover, nothing immediately obvious. The cassette...
The DR1o might have a Sankyo transport and they have sense fingers that become tarnished. This needs to be serviced to make the deck work. It is possible that the deck is still in play mode which blocks the eject from taking place. Unplug the unit and open it up and rotate the worm gear with a finger and the door will eventually open up but do not force things as understand the size of motor in the unit that normally turns the worm gear.
Sep 19, 2013 | Nakamichi Audio Players & Recorders
Nakamichi DR 10 eject button not working and Err
The internal mechanism feedback switches need to be cleaned.
Sep 17, 2013 | Nakamichi Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Dec 06, 2007 | Audio Players & Recorders
77 people viewed this question
 Grubhead
Grubhead
