Question about Saeco Incanto Classic Espresso Machine
No steam or hot water
Pump in whirring away, but no minimal steam comes out of the steam want. When I try to get hot water a small stream starts then it begins filling up the overflow tray from behind the door, nothing out of the wand.
  • 11,896 Answers
Check to make sure pressure is coming out of the wand, if not, there is definately dried up clog inside the tube somewhere or possibility that the hose is loose on motor.
Posted on Jun 18, 2009
Saeco poemia espresso machine, cant complete circuit prime as water stream does not come thru steamer wand, as instructions say. Left open for 5 min.
Not sure I understand your question since there are no question marks "?" But assuming you open hot water and nothing comes out. Saeco uses micro switches to activate pump for hot water. Steam sometimes ruin the switch. Open and replace
Jan 06, 2015 | Coffee Makers & Espresso Machines
Water light is on ,Water tank is full but the light stays on
If the water tank stays full it indicates that the pump cannot function properly.
Before first use, the Sirena pump needs to be 'primed'. This is indicated by the blinking blue 'water' LED. On a new machine (or a refurbished one as in my case), empty the water container first, then
  • remove the plastic water container
  • activate the small spring valve mechanism built into the bottom of the water tank.
    This plastic valve mechanism could initially be hard to depress, because the small metal spring is too strong, or the entire mechanism may be stuck altogether. Exercise this spring and the small valve a few times (ok: 10 times).
  • once the spring-loaded valve moves freely (it becomes easy to depress with your finger), the pump will have no problem activating the spring mechanism and starts sucking water out of the tank:
  • refill with filtered water almost to the top and observe the floating magnet (fill indicator) now in its UP position. You will have to refill the water after a few shots and using steam.
  • Press the ON/OFF button and open the steam knob clockwise all the way until you can hear the pump working and a steady stream of water escapes... onto the floor, or if you're smart, into a small container.
  • Once primed, the pump can operate and in turn, the machine starts heating up.
  • Now you can make your espresso, and even try the steam wand after it shoots out a short stream of water. Once you have steam coming out of the wand, you can start getting serious about making your brew...
I believe that a lot of problems, like failure to heat up, machine doesn't work, etc. are caused by this small spring mechanism being a little hard to operate initially. The Sirena is programmed to operate ONLY if it can extract water out of the tank.
Try it and enjoy the superb cappucino, espresso, etc. -the beautiful Sirena was born in Italy and is a little temperamental, but will be your best friend with a little help in the mechnical department (Think FIAT). By the way: I am a German engineer -no kidding.
Sep 08, 2011 | Saeco Starbucks Sirena Espresso Machine
My CVA620 machine asks to "expel air " but
keep holding the hot water button down until you get a steady stream of water with no air. if you continue to get the error message after the water comes out, you will need to check the flow meter. if water never comes out, you have a leak inside the machine, a pump issue, or a blockage in the water path. That machine uses the same pump for steam and hot water, so if your steam is working, your pump is probably good. Blockages usually occur from not descaling properly. That machine is prone to leak at the hose fittings. the original o rings were black rubber, and failed fairly early. the replacements are red silicone and last much longer.
Jun 12, 2011 | Miele Coffee System
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
Jul 28, 2009 | Saeco Royal Professional Espresso Machine
Not making steam
hi tried99X. couple of possibilities: have you made sure steam wand is completely clean? allowed adequate time for water to heat? try looking inside: unplug machine, remove the ten screws on the bottom and gently lift away base: it does have wires connecting it to rest of machine so be carefull not to yank on them. locate the hose leading from the pump to the steam-arm (may be hard to see; use a good penlight and a small telescoping mirror if you have to; Autozone & other auto parts stores sell them for a couple of bucks-if you don't want to take off the entire casing of the machine. does the hose look okay?) also see if the pump has vibrated out of position. also, when's the last time you descaled? good luck!
Dec 07, 2008 | Breville ESP8XL Espresso Machine
No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Nov 10, 2007 | Breville ESP8XL Espresso Machine
Ventilate
I fixed my ventilate problem! After 2 days of utter frustration and pushing many buttons, I read another guest comment about resetting to factory settings. Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings. Then my machine started working again! Hallelujah! It erased my personal coffee cup setting, but who cares.
Big thanks to the person who posted their solution on Dec. 2007.
Jun 11, 2007 | Gaggia Titanium Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
208 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
