Question about Amana AGR5844VDW 5.0 cu. ft. 30" Self Cleaning Freestanding Gas Range
AGR5844VDW oven not lighting
Opens Gas valve for oven, Clicks 4 times then stops, waits and retries. Replaced ignitor, but still see no spark.
  • 494 Answers
Most modern ovens have a glow bar ignitor, not a spark ignitor. It will glow a bright orange and then the oven valve will click open and allow gas through and the burner lights. Many gas ovens have a small shutoff handle located on the silver appliance regulator, which is located either behind the stove or at the bottom behind the oven drawer. Make sure it has not been accidentally closed. It will cut off gas to the oven only.
Posted on Mar 19, 2015
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: gas ignitors continue to spark every 5 seconds in off position
try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Posted on Feb 13, 2009
fixyourboard
  • 310 Answers
SOURCE: I have an amana AKS30E gas cooktop and the
I think it's more likely to be a wiring problem, either bad ground or loose connection on the controls of the spark module connector. Look carefully at the switches on the controls to see if they are asking for spark when they're supposed to be off.
Best Regards,
bruce
www.fixyourboard.com
Posted on Jun 19, 2010
heatman101
  • 43501 Answers
SOURCE: spark ignitor for two of the burners for the range
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 19, 2010
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
I have a 2003 gas oven, model #JGBP28BEK3WH. All the top burners kick on but the oven doesn't. I can set the oven to preheat but so far it never lights. Please help.
You probably have a bad ignitor in your oven. The gas will not turn on until the ignitor glows red hot - less resistance and more current for valve to open. This can be replace by a repairman or a tool savvy homeowner. If you call a repair man, your looking at 150.00 to 200.00. Part can be from 50.00 to 110.00. I usually charge 110.00 plus the price of the ignitor.
Aug 04, 2010 | General Electric Profile JGP945 30 in. Gas...
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
Jul 31, 2010 | Jenn-Air 30 in. CCG2423 Gas Cooktop
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
Burner won't light
is gas comeing out of the hole? sometimes by cleaning the orfice hole (food and debrie will get in there and plug the hole not letting the gas come through) i get a needle and poke it.
when you say it is sparking...When you turn the dial for that specific one you want ignited... That one is sparking? If so Great. This means you either have a plug or the valve is bad and not letting the gas flow through.
Apr 04, 2009 | Amana AKS3040 Gas Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Amana AGR5844VDW 5.0 cu. ft. 30" Self Cleaning Freestanding Gas Range Logo
205 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
