Question about Electrolux Dishwashers
Dx 403sb dishlex has an i30 code
It has a i 30 code flashing on the screen and will not clear i have removed yhe bottom tray and cheked the flot switch it looks ok
4 Suggested Answers
  • 70 Answers
SOURCE: Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Posted on Jan 07, 2010
jyackle5
  • 8197 Answers
SOURCE: My dishlex dx403 is stuck
Code 30 is the anti flood switch.
You have a leak and water has gone into the base and operated the anti flood switch which will make the drain pump run until you disconnect from the mains.Tip dishwasher on its back to get the water out of the base and reset the anti flood switch. Now retry. If it floods again you have a leak inside and need to find out where it is coming from
Posted on Feb 28, 2011
SOURCE: Dishlex 302 model is displating "i30" error which
i ahve the same problem! ANy solutions out there?
Posted on Oct 28, 2011
Error 50 is coming up on my dishlex dx 301 and it is not working. It is about 3 years old.
A 50 Code means an electrical fault
This is something that is triggering the computer to think a conponant has failed
It could be a faulty motor for eg
Sometimes water in the door or condensation under the unit can cause this
Dishlex suggest you call their service center when this code comes up
hope this helps
Mar 27, 2015 | Dishwashers
Frigidaire dishwasher fault code i30
Good Afternoon Friend,
I understand that you are receiving an i30 error code on your Frigidaire dishwasher. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start your dishwasher. If this does not correct the i30 error code, I suggest you contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Dishwashers
Dishlex 403. Error Code 30 is stopping machine from filling
First thing you need to do is Check and make sure the FLOAT is moving inside, once you get this working properly, then it will reset itself. There is not a Clear CODE for it.
Mar 01, 2014 | Dishwashers
My dishwasher keeps flashing i30 and wont start what shall i do
In your case occurred intervention of anti-flooding system.
Displayed Error is "i30"
The cycle is interrupted and the drain pump switches on.
Could be:
Water leakage from the tub - sump and various
connections (pump, upper spray arm duct etc.);
floating sensor blocked mechanically; microswitch
faulty; fill solenoid blocked mechanically; circuit
board faulty (solenoid triac short-circuited); wiring
faulty.
First, try to tilt dishwasher and see if leaking water from its bottom.
This is most commonly occurs.
Dado
Jan 20, 2014 | Electrolux Genuine ZANUSSI ZDF511...
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
Try and remove power for few hours so that the processor resets, check if there is fault in the door switch as the error had come in, check for good pressure at the inlet, and possibility of any fault in the pump. It is best to take a full view of the functioning of the units to ensure that there are no errrors that feed back. Clean and reset.
Sep 29, 2011 | Dishwashers
Washer starts then stopps a few minutes in and the delicate and fast and dry lights flash,please help
this sounds like a heating circuit failure, two most likely are failed heater
or pressure switch. Heater is access fro bottom of unit after base tray has been removed base tray will have safety flot switch attached to it,
pressure switch located in frame right front inside right hand panel
Apr 19, 2010 | Hotpoint Dishwashers
check this
Jan 06, 2010 | Electrolux Dishwashers
Hello. Can i put an front panel on the door of my dishlex DX 103 to integrate it with the rest of my kitchen?
Yes but it must be a material that is made to withstand the heat dont cover any vents or spaces around the dishlex
Nov 09, 2008 | Dishwashers
Dishwashers Logo
35 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
