Question about Garden
Craftsman LT 1000 w/Kohler 16.5 HP will not crank over
New battery and starter
    New Friend:
    Problem Solver:
  • 16 Answers
I would check the safety switches. also try jumping it off because a new battery also may be dead.
Posted on Apr 17, 2014
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
panilling9
  • 284 Answers
SOURCE: Craftsman LT 1000 I replaced the battery,
be sure you are sitting on the mower with the clutch pedal pushed down,blade engagement in off position,
there may be a safety switch bad or a wire pulled off of one or more of them or a bad starter solenoid which is a high failure item.
Check safety seat switch wires under seat,look under mower for clutch pedal switch wires located under mower near clutch pedal, check the blade safety switch if its a manual blade engagement? The (starter solenoid) you will need to find the red wire on your battery and follow it until you find it or from the starters red wire back towards battery.
Once you find it inspect the solenoid to be sure wires are in tact,then find a dc volt meter and check to see if you have voltage(12volts dc min.) to the small red wire hooked to the solenoids coil (near the bottom) when the the ignition key is turned to start position(one of your meters wire to the coil wire and one to a good ground,,if your meter goes backwards reverse the meter leads)Note:lock the clutch pedal down before you do this) If you have voltage to this wire when key is turned to start position? solenoid is most likely bad or if you dont have voltage trace that wire backwards until you find voltage then you may have found your culprit.
Posted on May 17, 2010
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
My craftsman LT 1000 wouldn't start, it's silent. I changed my battery - still the same.
1. try jumping your mower battery with your car/battery and see if it cranks. If it does, charge your battery. If it doesnt
2. try jumping directly from battery to starter. If that works, its your starter solenoid. If it doesnt,
3. change the starter.
I would need engine model number in order to find your part numbers.
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 16 hp Kohler engine with a compression release not working,help.
i have a Kohler 16 Magnum opposed cylinder engine and it wont crank over with the spark plugs in it,battery and starter are both good,its an aluminum engine and i have seen several of the Kohler engines break the automatic compression release on the cam gear and they seem to lock up while trying to start,pull the plugs and the crank fine,Kokler is the most expensive engine i have seen and their parts are outrageously priced,old Kokler was a good engine,newer ones in my opinion are junk,i work at a small engine shop,i have seen new Kohler engines with a broken ACRs,i work at a second job,we got a new supervisor that worked for Kohler before her came to our plant,he said he worked customer service at Kohler and he heard complaints constantly from people using their engines and the returns were out the roof on their engines,what im saying is i wont ever but another Kohler unless itsm an old one,Thanks Tommy
Jun 06, 2012 | Kohler Electrical Supplies
My craftsman lt 1000 lawn tractors starter keeps overheating
check the battery cables bypass them with jumper cables to test them that engine needs alot of amprage
May 13, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman II LT 4000 MOD # 917-255691 with a Kohler Command 14 HP Engine SN#2202002414. Wont start with key starts with jumpstart on starter. With key to on positon. Replaced the starter solinoid, ignition...
Check the wire from the ignition switch to the small terminal on your solenoid with a volt meter to make sure you are getting current to the solenoid. If not try a "jumper wire" connected to the same terminals and see if it now cranks. If it does, replace the wire
Sep 12, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
