Question about Zebra GK420D Direct Thermal Label Printer
Barcode prints fuzzy
It looks like the barcode is being dithered. I had a similar problem on another computer. Then , I just turned dithering off. I've done that here as well but the problem persists. Some barcodes print clearly but others that have more characters print fuzzy. They appear fine onscreen and print fine on other printers.
  • Eric Isaacson
    Eric Isaacson Apr 16, 2014
    I haven't. On the one computer, it prints fine so I don't think there's actually anything wrong with the printer, just the settings. I've even tried exporting and importing settings. That doesn't help.
    Problem Solver:
  • 17 Answers
Have you tried to "clean" the printerheads. You know like you would do with a normal printer. Sometimes the printheads go stucked with old ink(wich you cannot see on screen ofcorse)
Posted on Apr 16, 2014
Testimonial: "I haven't. On the one computer, it prints fine so I don't think there's actually anything wrong with the printer, just the settings. I've even tried exporting and importing settings. That doesn't help."
  • Eric Isaacson
    Add a CommentI haven't. On the one computer, it prints fine so I don't think there's actually anything wrong with the printer, just the settings. I've even tried exporting and importing settings. That doesn't help.
SOURCE: improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
Posted on Nov 09, 2007
jigeo
  • 57 Answers
SOURCE: Zebra LP 2844
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Posted on Apr 24, 2008
  • 45 Answers
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
Posted on Sep 23, 2008
SOURCE: Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Posted on Mar 31, 2009
  • 9 Answers
SOURCE: Unwanted underscores added to 2D barcode scan
are they the same barcode type?
what is the font set at? using Arial or other fonts can make the software send a more complicated image. use the Zebra Triuverate font. this keeps it simple. also, do a print out of the settings on each printer and compare them line by line. change the settings to match the printer that is printing correctly.
Posted on Aug 31, 2009
Testimonial: "Thanks. Printing out the settings helped me realize it was not a printer issue. It was a software issue. Installing older version of software fixed it"
Print quality on Brother Intellifax 2840 fax/printer has changed from black to gray. I've tried different toner cartridges, but it doesn't help.
The online fax service allows you to choose the quality or your outbound faxes: black and white thresholding (with improved readability) or grey and colors dithering (to render grey zones of pictures and logos).
Aug 12, 2013 | Office Equipment & Supplies
Tip
How to change settings on a barcode
<p>Barcodes can be printed symbols encoded information printed in black and white contain. You can use bar codes entering data into bar code - the generation of the image software and print barcode using a normal printer or a barcode printer. Printed bar codes are read by a barcode scanner that reflected light rays used to decipher the code. Bar codes may contain different information. You can change or a bar code can be adapted by entering the information reviewed in the bar code - generation software. <br /> <p><br /> <p>1. Access your favorite browser and go to barcode generator, barcode, bar code or soft (see Resources) can use a free barcode - generation software. <br /> <p><br /> <p>2. Most sites that offer bar code - generation software to present their application interface on their own pages. Enter the information reviewed or custom code in the space you want, and "Generate Barcode" button to click to create barcode images. <br /> <p><br /> <p>3. See the image of the barcode displayed on your computer, click on the image to pop-up menu to display. Click "Save Picture As" from the pop-up window, select the location where you want to save the image and click "Save" next window to save the image in the selected folder. <br /> <p><br /> <p>4. Connect the cable to patch your bar code scanner in its corresponding port on the back of your computer. Keep the scanner about six inches from the printed barcode, which focuses on the barcode and press the button to scan the bar code. Look at the revised data upload to your computer and check its accuracy. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How do I adjust Barcode on the price tickets?
<p> <p> <p>Bar codes are created using the software to generate bar code and printed on price tags with bar code printers. Tickets barcode typically contain product information and pricing, but there are times when prices should be adjusted to produce a product more salable. Establish a barcode on a price tag, generating a new image of the barcode using a computer, print the barcode image and paste the image printed on the sticker price. <br /> <p><br /> <p>1. A site of a software program that allows you to create an image of the barcode (see Resources) to download. <br /> <p><br /> <p>2. See the homepage of the site and watch the program interface. Choose the type of barcode you want to generate from the list displayed. Enter the information you want to encode the space provided. Click "Generate barcodes" to create barcode images. See the image and right click on it to a drop-down menu to display. Click "Save image as" the image of the barcode on your local computer store. <br /> <p><br /> <p>3. Place a sheet of paper label on the computer printer. Open the folder where the image of the barcode. Right-click on the image of the barcode that you saved and click on "Print" from the menu bar to print. <br /> <p><br /> <p>4. Cut the bar code printed on the price tag to match, and stick it in the bar code on the old price. Scan the barcode with a barcode scanner and check the data sent to your computer. <br />
My fargo printer prints black and white on the back of the card
Possible solution: Change the resin dither from Optimized for Graphics to Optimized for Photos with in the printer driver under the image color tab.
Feb 23, 2012 | Fargo DTC525 ID Card Printer
Icons and text exhibit a right-handed black and white dithering or noisy shading effect. This gets increasingly bad as windows are opened and closed. It almost looks like a RFI/EMI radiation problem but...
If the monitor displays a similar effect on the monitor's own display, the colour ajustment or no signal display then the answer is most likely yes. A good tech guy may be able to fix the problem but it's going to cost almost the price of a smaller screen, similar to what you have, anyway. My suggestion is to just grab yourself a new monitor.
May 07, 2011 | Balance CM2019 19" LCD Monitor
Tip
How do I create custom Barcodes?
<p>Barcodes can be printed symbols with encoded data will be charged to the computer via a scanner. A bar code allows a company to maintain control of their actions to secure and instant access to information about each product. A bar code is created using software barcode generation software. Customizing a bar code is a simple process to enter your data into the software program, and print.<br /> <p> <br /> <p>1. Open your Web browser and visit Barcode Generator, barcode or Soft. See the program's interface is usually presented on the homepage of the website page. Look at the list of different types of bar codes available, and click the type of barcode you want to use. <br /> <p><br /> <p>2. Locate the area where you are allowed to present the information is converted into a bar in, and within the data type. Click "Generate Barcode" to create barcode images. View the image resulting bar code, right click on the image and click "Save image as" in the drop-down menu to save the resulting image on your computer. <br /> <p><br /> <p>3. Close the program bar code generation, and open the bar code image stored on your computer. Right click on the saved image and click "Print" from the output drop-down menu to print the bar code. Scan the bar code information printed to be loaded on your computer and check the data sent to make sure it is correct. <br />
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Barcode printing on using Code V on IBM 4232
SOME OF THE COMMUNITY COLLEGE IN OUR TOWN STILL USE COBOL IN THERE NETWORKING, LOOK IN YOU PHONE DIRECTORY FOR ANAMATED SULATIONS, SOME PLACE MAYBE HELPFUL IF COMPTER USERS GROUPS, COMPUTER CLUBS, I LIVE IN MESA AZ AND THE BOY SCOUT OF AMERICA HAVE A COMPUTR SWAP MEET EVERY LAST SUNDAY OF EACH MONTH AT SCOUTSDALE COMMUNITY COLLEGE YOU MAY BE ABLE TO CONTACT THE BOY SCOUT TROUP LEADER AND ASK FOR ASSISTANCE IN THIS MATTER HE MAYBE ABLE TO HELP YOU 1-480-423-6000
ROD
Feb 09, 2009 | IBM 4247 A00 Matrix Printer
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra 4M Plus
What software are using? If you use or Zebra Designer Label Matrix, uses its own drivers. If you use another driver, verify that the graphics option is "dithering".
Roberto Martinez
May 20, 2008 | Zebra Z4M Printer
Zebra GK420D Direct Thermal Label Printer Logo
191 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
