Question about Electrolux EWFLS70JSS Washer
Electrolux front load washer drain - Electrolux EWFLS70JSS Washer
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Friend,
I see that your Electrolux washer, model# EWFLS70JSS, is having trouble draining. First, I would start by checking the drain hose, to make sure there are no kinks in it and it is not clogged. Secondly, I would make sure that the drain hose is between 6-8 inches down inside the drainpipe. If it is too far inside the drainpipe, it can cause slow or no drainage. Thirdly, I would make sure that the drainpipe is not clogged. Finally, I suggest resetting your washer. You will do this by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. When the power is restored, run a wash. If your washer is still experiencing a no drainage issue, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Posted on Apr 23, 2014
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Posted on Jul 22, 2008
huuum
  • 750 Answers
SOURCE: error message E31 on Electrolux I-touch front load washer
Hello kleveille
Welcome,
You said, your machine comes on but will not start
I need the model number to start to help you???????????????????
huuum
Posted on Oct 16, 2008
SOURCE: Our Electrolux front loadeing washer wont drain,
You will have to get the water out,down by the filter at bottom lhs see if there is a small rubber hose next to filter if there is it should pull out so far then you can remove the small plug on end to drain into a container.If no hose down then try putting the drain hose down to floor level into a bucket or out of an exit door to syphon out water.Or get machine filter by an exit door and release the filter plug and let water drain out.E21 means that there is either some blockage in the pump or the drain pipe may be kinked or blocked.
Posted on May 04, 2010
torres No9
  • 27 Answers
SOURCE: error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
Posted on Jun 25, 2010
  • 1531 Answers
SOURCE: Washer is not draining. How do I remove the front
you will need to remove the lid first then remove the screws that hold the control panel in place.then you will need to remove the door boot on the front panel. there will be two screws on the bottom of the panel that will need to be removed as well as the screws on the top of the panel.
Posted on Feb 15, 2011
Testimonial: "Thanks so much, really appreciate the quick response!"
How to acess the drain pump on an electrolux front load washer
Good Morning Friend,
I understand you want to know how to access the drain pump on your Electrolux washer, model# EIFLW55HIW. Typically, this is not a do it yourself access, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to access the drain pump with ease. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Electrolux EIFLW55HIW Front Load Washer...
Where is the drain pump on a Electrolux front load washer
I understand that you want to know where the drain pump is located on your Electrolux washer, model# AWF 1435. In researching the model number you provided, I show that this was manufactured in France. I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you where the drain pump is located in your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Electrolux AWF 1435 Front Load Washer
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
Washer making loud noise willnot spin cycle or drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Electrolux AWF 1435 Front Load Washer
My front load Electrolux washer asks me "clean
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
Aug 03, 2011 | Electrolux Washing Machines
Washer will not spin out in any cycle
heatman101
Apr 10, 2011 | Electrolux EW1000i Front Load Washer
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
Sep 08, 2017 | Electrolux AWF1220 Front Load Washer
Washer is not draining. How do I remove the front panel of my Electrolux IQ front load washer (Model EIFLW55HIW) in order to access the drain pump? There is no access panel on the front of the washer....
Feb 15, 2011 | Electrolux EIFLW55HIW Front Load Washer...
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EWFLS70JSS Washer Logo
152 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
