Question about Sanyo DRW-500 DVD Recorder
Channel setup When the antenna is connected the setup program will not find the channels using setup.
    Genius:
  • Sanyo Master
  • 1,552 Answers
Have you set the Sanyo to "antenna" or "remote" ?
Try the other setting.
Posted on Feb 14, 2015
2 Suggested Answers
  • 3 Answers
SOURCE: programming channels
Press Menu, press up and down arrows to choose the Input Select option then press side arrows to set the channel. Tuner will automatically cycle through all available channels in your area. After the Auto channel search is complete make sure the Channel source is set appropriately (TV or CATV) by pressing up and down arrows and chossing the correct source by pressing the side arrows using the channel setup menu. Press Menu to return to the TV screen. Use CH/TRK arrows or CHANNEL arrows on the front panel to cycle the DVD+VCR through the channels in memory.
Posted on Mar 21, 2008
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
How to use an antenna box for more channels
Once the antenna is mounted and connected to the TV then you can go into setup menu and do a channel search. You will be prompted to set it up as CABLE or AIR/ANTENNA. Select ANTENNA and it will program all available channels for you.
Apr 19, 2016 | Televison & Video
How do I switch from catv to antenna on model mwc13d6
First make sure that the TV/DVD player is on TV by pressing the Channel Up. (The channel up/down will rotate through AUX and any programmed channels.) You'll need the original remote or an universal remote that matches the Set-up function. Then press Set-up on the remote; it's to the left of Mute above Play.
Use the Up/Down arrows to navigate to Channel Setup. Press Enter to access the Channel Setup menu. Use the Up and Down arrows to select Auto Ch Programming and press Enter. Wait for the TV to scan all available channels. Afterwards, you can go back to the Channel Setup menu and choose Add/Delete channels. Press Set-Up again to exit the On-screen menu system.
Unless you have a set-top Digital-to-Analog converter attached to the TV, you will only get one of the few remaining low power analog stations, if you are close to the transmitter. This set only has an NTSC tuner. Most set-top boxes can be attached to the Antenna input and be set to Channel 3 or 4 or connected to the Aux input.
The Magnavox MWC13D6 was manufactured by Funai and the manual is available here: http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is MWC13D6 is http://www.funai-corp.com/support/om/MWC13D6.pdf .
I hope this helps.
Mar 24, 2015 | Televison & Video
How to change channel from one to any one channel in sony bravia
I need more info. Are you using antenna connected to RF input or are you using cable box, sat box or ATT Uverse? If connected to antenna . go in menu or Home on Sony. Press setup and look for channel scan. Set to antenna and do auto scan. If cable or other provider box set tv to ch 3 or what ever provider says. You are then using the tuner in that box. You will use providers remote to change channels. Be sure in setup that tv is set to cable if cable box is used. Hope this helps but the info you posted could be more descriptive.
Oct 02, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    How do I retune my Panasonic Viera TV?
    Hello
    To tune your Panasonic Plasma to on air TV channels do the following:
    Connect the antenna connection to its antenna in at the back panel.
    Automatically searches and adds available channels to the memory.
    Select "ANT in"
    Select Cable or Antenna Select "Auto"
    Select a scanning mode
    Auto channel setup
    Select "Auto program"
    Select "ANT in"
    Select "Auto"
    Select scanning mode (ALL channels/Analog only/Digital only
    Start scanning the channels
    Available channels (analog/digital) are automatically set.
    All channels: Scans digital and analog channels
    Analog only: Scans Analog channels only
    Digital only: Scans Digital channels only
    Confirm registered channels
    If OK is not pressed after selecting "Apply", the channels will not be saved.
    The channel will be saved when no operation is performed for 60 seconds and
    the "Manual program" menu will also exit automatically.
    If you perform scanning more than twice, previously saved channels are erased.
    About broadcasting systems
    Analog (NTSC): Conventional broadcasting
    Digital (ATSC): New programming that allows you to view more channels
    featuring high-quality video and sound
    [Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
    Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
    I GET TO THE WINDOW TO PROGRAM A RECORDING BUT FOR CHANNEL SELECTION I ONLY GET L- L-2 OR L3 I NEED TO BE ABLE TO SELECT THE CHANNEL LIKE 6 THIS IS A NEW HD TV. I AM ABLE TO PLAY EXISTING SHOW ON THE DVD...
    Hi.
    You will need to connect an antenna and program channels to internal tuner if you want to use the built in tuner.
    It is not clear if your problem is with the HDTV or with the DVD recorder.
    Both have an internal tuner, and both can tune channels , L2 and L3 are the input lines used when you connect for example to an external receiver.
    Regards.
    Nov 14, 2009 | Panasonic DMR-E80H DVD Recorder
    17 in. trutech tv unable to get channels except 2-13
    For channel setup you will need to;
    1) Connect the signal source to the back of the set.(Antenna or Cable)
    2) Go into the TV Menu and select the same signal source you connected to the back.(Antenna or Cable)
    3) Go to the auto program/scan menu and run it. This may take a few minutes.
    Now the channels may be watched.
    Mar 16, 2009 | TruTech PVS31170S1W 17 in. LCD Television
    Akai VSG285 video - I can't tune any TV stations thru to the VCR?
    This sounds like a hookup or programming problem.
    The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
    If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
    I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
    Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
    If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
    Apr 09, 2008 | Televison & Video
    Vcr to tv connection
    There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
    Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
    Sanyo DRW-500 DVD Recorder Logo
    49 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
