Question about Belkin Computers & Internet
Blue light flashing
My router blue light flashes then goes red. I have not internet connection. I have tried unplugging and re plugging in. No different.
    Scholar:
  • 168 Answers
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
Posted on Apr 18, 2014
JSPCEXPRESS
  • 178 Answers
SOURCE: 2wire 2700 not connecting to internet
Make sure you have DSL filters installed contact me if you need any help
Posted on Feb 11, 2008
  • 4 Answers
SOURCE: dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Posted on Jan 14, 2009
SOURCE: no internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
Posted on Jan 21, 2009
pamthegreek
  • 148 Answers
SOURCE: Wireless printer not communicating with router
See manual: http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
Posted on Feb 20, 2009
SOURCE: I have Belkin F5D5231-4 router. My DSL modem is connected to the
problem solved!
Posted on Mar 30, 2009
Ngv510 red light blinking
hello i was wondering if anybody can help me out here,recently my att unverse dsl nvg510 modem redlight (wifi setup ) is flashing red and sometimes flashing green. my internet is running good, all the device that connects to wifi is good also. and also i unplug the power for few minutes and plug it back in and still that redlight keeps on flashing. nobody can answer my question. thank you
Jul 29, 2012 | Arris Nvg510 At&t U-verse Modem Gateway...
Unable to connect to internet through Linksys WRT160N router. Can unplug it and internet is fine. Tried power cycling the modem and router. Linksys comes up with all lights flashing and will not...
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
Dec 30, 2010 | Linksys WRT160N Wireless Router
Had to unplug the router and now that it is hooked back up the internet light is flashing red along with the modem light
unplug both the router and the Internet modem at the same time and leave off for 30 seconds.
Then, plug both back in and see if it reboots the system.
Try to connect with your wifi laptop or wifi adapter desktop.
Jul 10, 2010 | Belkin (F5D7230-4) Router (587009)
At the bottom of my router are two icons, the modem and the internet, which are flashing orange. all other icons are blue. i am unable to get a connection. I also have VOIP connected to my router, if that...
Some routers will not get online if voip is connected while repairing connection. I would unplug your voip and try to connect then. Unplug your modem for about 30-45 seconds and then make sure all wiring is correct. Once you are able to connect the plug your voip back in. Internet light is not supposed to be orange but green or on some routers blue. If your modem aslo has orange light it is possible it is your provider issue. I would also check with them if steps i described above dont work. Good luck.
Apr 28, 2010 | Computers & Internet
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Wont connect to internet
You need to reset the router if the lights are flashing. Press the reset button at the back of the router for about 20 seconds then release it. Now unplug the power for 20 mins as well and plug it back in. Make sure your connection is right. PC connected to port 1 and modem to WAN or Internet port.
Dec 17, 2008 | NetGear WGR614 Router
Red intenet light. what does it mean.
it means your not connected. unplug your router for 3 minutes and the plug it back in so it can reset. then go to your network connections and disable them and then enable them again close all boxes when your done and when all the lights on your router are STEADY GREEN not flashing then you can acces the internet. i hope this was helpful.
Dec 06, 2008 | Westell Wirespeed VersaLink...
Dsl light flashes red constantly
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Thompson speedtouch ST585 RED LIGHT ON WLAN
When the red WLAN light is flashing in conjuction with the internet light it just means a wireless computer is connected to the internet through the router
However I had a problem with the internet light flashing red and it required the router to be reconfigured
gudozdad
Oct 20, 2008 | Computers & Internet
On and off line every 20 flashes.
Have you attempted to connect the internet after the router stops flashing? Do the lights start flashing again? If you do, then it would be considered normal.
If they don't and you do not have an internet connection, try the next step.
Next, plug your computer straight into the modem - Do you have an internet connection now? If you do, your router may require configuration.
Nov 10, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
122 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
