WONT START LIGHTS WILL COME ON BUT WHEN I PUSH START IT CLICKS
THIS IS A FRONT LOADER FRIGIDAIRE MODEL GLTF2940FS2
reddyanantha
  • 205 Answers
SOURCE: OK I have a frigidaire front load washer model
hello mam
after taking the water to its drum to a given level it should start the thumble wash and if it wont then we should check the timer switch,motor,and the water level controler.so please call the engineer.
Posted on Oct 07, 2009
  • 572 Answers
SOURCE: front loader frigidaire wont spin or drain final
in the bottom panel theres a coin trap
Posted on Feb 06, 2010
Jahn27
  • 1554 Answers
SOURCE: frigidaire frontend washer LTF2140ES3 will drain not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle to advance to the spin cycle. When the machine works except advancing to the spin cycle, it signifies that this auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to fix the washer.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the wires from its terminals then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Mar 10, 2010
ginko
  • 19396 Answers
SOURCE: maytag neptune front loader model
Hi.
First disconnect power by tripping circuit breaker or disconnecting power cord. While power is off access the hose connected to drain pump. The pump assembly is mounted to the right rear of the base. With power not connected undo hose from pump, collect water and remove blockage, fit the pump back. See page 63, section six in the manual below:
SERVICE MANUAL.
Regards.
Ginko
Posted on Jun 18, 2011
  • 32 Answers
SOURCE: how to clean drain pump frigidaire front loading
Remove the bottom access panel by removing the almost two hidden screws along the bottom. The pump is located on the right. Remove the two hoses and two screw that mount the pump to the base. Clean away. Reattach hoses and screws. TEST unit with panel off to check for leaks. The hoses can be a pain to get on right. Also beware water caught in tub and drain hose will leak out. Bring towels. Lots.
Posted on Sep 28, 2011
Code e62 on frigidaire gallery series model GLTF2940FS2
Good Morning Friend,
I understand you are receiving an E62 code on your Frigidaire Gallery washer, model# GLTF2940FS2. The E62 code means that there is a communication problem between the different control boards in your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire GLTF2940F Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
My Frigidaire GLTR1670A front loader hot and cold
sears parts direct carries a lot of parts can be accessed online can start there or just search for frigedaire part number
Dec 10, 2009 | Frigidaire GLTF1670A Front Load Washer
OK I have a frigidaire front load washer model #GLTF2940ES0 it won't start but the lights are on. I push the button and it blinks err then lock. what can I do?
hello mam
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer does not fill at all
Have you checked the filter just inside the water hoses. You just turn off the water and unfastenent he hoses from the machine and you will find a little filter. It may be clogged with lint, sand, etc.
Jul 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loader
My front loader stops at every cycle. Is there a simple solution to this?
Jan 22, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
