Question about Moulinex Blenders
How to remove the white rubber gasket from a blender
SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Posted on Nov 02, 2007
SOURCE: Kitchen Aid Blender Rubber Coupling replacement
Someone else suggested a link that explains exactly how to unthread the old coupling... and it works. It took me about 90 seconds to fix my blender. But in case that link is dead, here's a summary:
(1) Note that the coupling (the round part with teeth) is threaded to the blender motor in reverse to a standard threading. So it screws off just like a bottle top, but in a clockwise direction.
(2) place the blender base on a tabletop, facing you. You should probably unplug it.
(3) take a punch or a flathead screwdriver, and place it against one of the coupling teeth that is furtherest away from you.
(4) strike the back of the screwdriver with a small hammer or maillot. The result will spin coupling clockwise. It may take several tries, but the coupling will eventually spin clockwise faster than the motor, and it will begin to unthread.
(5) unscrew the old coupling, and screw the new coupling into place (counterclockwise). Note that the new coupling will tighten itself every time you use your blender, so no need to worry about tightening it too much.
(6) Make a smoothie to celebrate your success!
Posted on Nov 10, 2007
fossilruins
  • 114 Answers
SOURCE: Smoothie Plus 600
Here is the website you can order replacement parts:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3699&secid=53&linkon=category&linkid=91
Posted on Jun 16, 2008
  • 16 Answers
SOURCE: Hamilton Beach blender rubber drive removal
plz cont -23051554 \ 23095757
Posted on Aug 05, 2008
SOURCE: leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Posted on Sep 21, 2009
Need a rubber gasket for Betty Crocker BC-1352C
Fixya does not sell replacement rubber gaskets. Check with a local appliance parts supplier.
Jun 23, 2014 | Betty Crocker BCF1350 Work Top Blender
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Gasket melting
Awesome...
Try AMAZON FOR THESE parts...
((amazon be cool... dogs drool & cats rule)).
4X Sealing Gasket Rubber Ring Replacement Seals For Ninja Juicer Blender...
Jan 28, 2014 | NINJA Blenders
Rubber gaskets on hamilton beach blender
Possibly the gasket while it lasts on the cheap on eBay by searching "VINTAGE HAMILTON BEACH REPLACEMENT RUBBER GASKET" there. Try typing in your model number at HB's parts site, located by clicking here . Many www sites like abtecparts.com and goodmans.net could help you. Besides matching description, I would match the pictures of what you are going for against what you've got as much as possible. Good luck!
Aug 05, 2013 | Hamilton Beach 50200 BlendMaster Work Top...
Hi. We have a Cuisinart smart power blender. When we mix drinks, there is some sort of black residue seeping into the glass pitcher. Do you know what is causing that?
This can be coming from discoloration and/or food acting on the rubber gasket. Be sure to take the pitcher apart, removing, the screw on base cap, the blade mechanism,and the gasket to clean your blender after each use. Acids and liquids can act on the rubber causing a discoloration and this will seep into your pitcher. This should take care of your problem. If it does, please come back to Fixya and rate my solution!
Jul 14, 2011 | Cuisinart Blenders
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
Rubber Gasket
I would reccomend getting one directly from the manufacturer - their number is: 1-877-689-2737
If they don't sell the gasket separately, there are small appliance and hardware stores in some locales that will find the right gasket if you bring the machine in - I would call ahead to make sure.
-Tha Mp3 Doctor (also loves Margaritas)
Sep 08, 2008 | Margaritaville Frozen Concoction (DM1000)...
Blenders Logo
Top Moulinex Blenders Experts
Ross Keen
Tom Chichester
Steve Luck
Steve Luck
Are you a Moulinex Blender Expert? Answer questions, earn points and help others
