Question about Maxtor Hard Drive
Hey thanks for replying no there is no sound coming from the drive. I know the power is working as the other hard drive when put in goes ok. Can I get it fixed or get the stuff off it. As it has all my photos on it.
    Sergeant:
  • 268 Answers
There is an harddrive to usb cable you can get from a computer store should run about 20 bucks and is easy to hook up. After you get this and hook it all up you will then be able to tell if you can or can not get your information off. If you need more help feel free to contact us at our site
Company Site http://www.attechcomputers.co.cc
Posted on Jun 18, 2009
Connecting old hard drive
Hi Dave,
Thanks for putting your concerns here and I'd pleased to assist any suitable reply.
The drive comes with an USB 3.0 cable which you'll need to connect the USB port situated on the back of your CPU or any corner (either left or right) of your Laptop. You'll need to insert one cable to the power cord as well if there is no internal source of power supply.
At last, if you're struggling while making your hard drive to work, feel free to ask.
Feb 17, 2014 | Seagate Computers & Internet
My hard drive does not seem to turn on! i.e.-- no light on, not showing up in Finder (I have an Imac) I've changed ports, and outlets... no luck.
either the case power connect died or the whole unit went bad.
you can try pull out the hard drive and put it in another external usb case to see if it will work.
Mar 06, 2011 | Verbatim (96759) 1 TB USB Hard Drive
Can't find hard drive on computer anymore. Blue light constantly blinks on Lacie
My LaCie drive was not showing up on my Mac, and making a soft clicking sound ....I thought i was in for expensive data recovery and worse...But I met a guy who told me that La Cie have had a lot of trouble with their POWER SUPPLY and that i should try their customer service. I did, and after a round iof idiotic scripted replies I got to a smart CSR who sent me a NEW power supply. Hey Presto! The drive is back and working perfectly, no data lost!!!
Nov 26, 2010 | LaCie (300770) 250 GB Hard Drive
ACER Aspire L100 Desktop is dead?
If the hard drive is OK then you can remove the hard drive from the desktop case, and insert the hard drive into a USB 3 1/2" hard drive adapter case, this should come with a power adapter. These are available at your friendly computer shop.
Boot up the laptop then plug this USB hard drive adapter into the laptop's USB port. The laptop will see this as an external USB hard drive. You can open the various folders and files on this external drive and copy the folders and files to the laptop.
You can delete the Windows folder and Program Folders on this external drive to free up disk space and use this as a back up drive etc.
If you are not sure how to remove the hard drive and install it into an USB hard disk case, then I suggest you get a computer savy friend to help you.
Dec 08, 2009 | Acer Aspire L100 PC Desktop
Help... Acer Aspire 3690 laptop.
My dear friend as I told you that you should change your RAMs it will b ok give me your response on jazib_qurashi2000@yahoo.com
Nov 19, 2009 | Acer Aspire 3690-2196 Notebook
Laptop turns on but nothing shows on screen
I think you should replace you RAM but 1st clean the old RAM inser it if work then ok otherwise just change you RAM If you think I am right then give me your response on JAZIB_Qurashi2000@yahoo.com
When power on my laptop it is not working?
Ok, you say when you power up the unit, the power Led comes up an then goes out.?
1st. If you have the battery inserted and the power adapter plugged in and the charging light comes on, showing the battery is charging, the power adapter and battery are most likely OK.
That's not the problem.
2nd. If the unit tries to power up and fails, the best thing you can do is, A. Remove any media in CD/DVD drive. Reove the power adapter and battery,
B. Remove the two covers showing the Hard Drive and Memory. Remove Both H/D and Memory.
C. Disconnect the CMOS Battery, located just above and top right of memory. (Next to Wireless Card). The is a white 2-pin connector.
D. Flip the unit over and press the power button for 15-30 seconds.
3rd. Know you have cleared the CMOS. You will have to re-enter the time and date, once the unit comes back on line.
4th. Reinstall only one piece of memory, Then the CMOS battery and leave the cover off for now.
5ft. Install the battery, Flip the unit over and plug in the A/C adapter.
6st. Look to see if the charging light comes on.
7th. If the charge light comes up, Power up the unit.
The message you should see is Date and Time press F-10 to continue. and then should say, missing Operating system or no disk found.
Remember if the unit will enter the BIOS screen and does not drop off, your in good shape.!
Power off the unit.
8th. Re-install remaining memory and check again. If no problems,
9th. Turn unit off and re-install Hard Drive.
10th. Power on unit and if you have problems, OK., more than likely, its the H/D. and may need to be re-formatted.
If the unit comes up OK, and you suspect the hard drive is at fault, Look for the Hard Drive Test utility in the BIOS screen. (This will smart drive test the hard drive and will take some time, depending upon the size of the drive..)
If you have errors on the drive on the boot partition, you will know soon enough, being the drive has two partition, one in the front of drive and one at the end.
If the drive is OK good deal.
If after trying all the above and the unit still will not power up and run correctly, please respond to this info. and I will run you thru some other things to check.
People please respond to our reply's to for help. If you do not rate us, we are waisting our time to go into detail helping you.
If you feel this information has wasted your time, please call HP and you will come away feeling differently.
Hope this information has been of some kind of help.
Try it, it may work !!
John Ray
john@johnrraycomputer.com
Jun 28, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate problem
YA THAT WILL BE THE NEXT TRY.
TAKE IT OUT AND TRY ANOTHER CASING.
Mar 18, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
