Question about Roper RS22AQXKQ Side by Side Refrigerator
No Water Side by side Roper refrigerator/freezer. Not getting any water out of the water outlet. The ice maker works and I can get ice out of the ice outlet.
  • Anonymous Mar 18, 2014
    No water and ice not working
  • 232 Answers
Is there stuff freezing in the veggy drawers water storage is behind it, if not find water valve test for power to it wile button is pushed the one with the larger line is the one your testing if you got power replace it
Posted on Jul 02, 2009
No water flowing into the ice maker reservoir. I poured water into the reservoir, but no ice dropped after 10 hours. Next day I unplugged refrigerator opened freezer door and thawed it out for about two...
Well, if the ice maker were working properly, when you poured water, assuming you poured A, enough water, and B, not too much water, you should have seen some cubes drop into the bucket. But since you did not get any ice cubes, I would have to say the reason your ice maker is not making ice is because you have a bad ice maker. Its not receiving water because it is not cycling.
Oct 09, 2010 | KitchenAid KSRU25CR Side by Side...
Ice maker quits working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
poptypty
May 23, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker is not making ice, but the water dispenser is working
The water valve has 2 features that work independently. One feature is for water in the door, the other is for the ice maker. It is quite possible the side that operates the ice maker is defective. A simple test can be made:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 01, 2010 | Roper RS25AEXLQ Side by Side Refrigerator
No water going into ice maker on our roper side by side refrig
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jan 05, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
My roper side by side ice maker does not work. I replaced the part on back which directs water to the ice maker and water through the door. I get water through the door, but ice maker still does not work....
See if the ice maker starts working when it dumps the ice.
Sep 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
RS25AWXEW01 side x side refrigerator has leak at ice maker water drips into frozen ice chute and leaks onto floor and also in freezer compartment
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 13, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Ice maker is making ice but leaking alot of water under the fridge and in the freezer. What can I do to shut if off until I repair the ice maker?
pull our your frig. and follow the water line coming into it. the other end should have a valve on it in the floor or the wall. turn off the valve and that will stop any water from coming to your frig for water or ice making.
Apr 22, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
My ice maker has just about quit working for no reason that I can find
Check to see if water is in ice cube forming tray. If No then probably a bad water inlet solenoid. Water line to fridge goes to inlet solenoid.
Feb 18, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Icemaker does not work
check the water hose. water supply to ice maker
Sep 11, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
105 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
