Question about Speed Ceiling Fan 3-speed Switch By Westinghouse 77021
Changing the 3 speed switch on my westinghouse ceiling fan
I believe I am returning the wires to their appropriate positions but I only get a hum from the fan when I turn the main power back on.
Inside the fan I have purple, yellow, gray and black
The switch the hardware store sold me has black, red, white and blue
Westinghouse quoted me the 77021 switch but the local hardware said they don't buy these replacement parts from Westinghouse and that the one they recommend will fix it.
They say even thought the wire colors don't match, as long as the L,1,2,3 are spliced appropriately it'll work.
It's not working!
Where do the the purple, yellow, gray and black correspond in relation to L,1,2,3?
Thanks
CP
De-coding the nonsense..........
Black = L = Power
Brown = 1 = Low Speed
Purple = 2 = Medium Speed
Gray = 3 = High Speed
Posted on Aug 18, 2009
  • Bill
    Bill May 10, 2014
    This was very helpful, watched three others that did not help, so thnaks a million for this.
    President:
  • 1,723 Answers
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
Goodman air handler ARUF036-00A-1A does not blow air in heating or cooling mode only hums/buzzes, what could it be?
Looking at the wall thermostat, you will see the fan switch that has two settings: fan auto, fan on.
You will need to place the fan switch in the fan on position for testing purposes.
This will make the indoor fan run continuosly, and never cycle off.
In the fan auto position, the fan will turn off when the thermostat temperature setting has been satisfied.
Remove the air handler access panel.
Is the air handler fan operating?
If the fan isn't working see if you can listen closely if it is humming, or can touch the motor to see if it is hot.
If it is humming and has a bad capacitor, you can tell this without having an electrical tester by spinning the fan wheel by hand.
Be very careful... making sure your hand won't get cut by the fan wheel spinning when it starts up.
If the fan spins and picks up full speed, replace the defective fan capacitor.
It is the shiny silver metallic cylindrical object with electrical wires attached to it.
Make sure you write down where those wires attach and turn the power off before removal as they carry 240 volts to the fan motor.
If you find that the fan wheel doesn't turn freely when you try to spin it by hand, the bearings have seized and you will need to find another fan motor of the same size, shaft length , speed , and horsepower to replace the defective motor.
Keep in mind that a humming sound in the air handler COULD be from the transformer instead of the fan motor.
The transformer is a black cube shaped device with electrical wires attached to it.
If the 24 volt transformer goes bad, your thermostat will not function and nothing will come on.
Dec 01, 2014 | Goodman Heating & Cooling
I am looking for a way to test my GE Arctica Refrigerator Fan Motor & if need be my Electronic Board that sends power to this fan, how do I find a Wiring Drawing that say's what these 4 wires -...
The Red wire is positive around 13.5 VDC
The White wire is the negative
The yellow should also be Positive around 13.5 VDC
The blue wire should also be around 13.5 VDC
Check Connector #2 on the main board for voltage.
on all those connectors. ignore the blue/blk.
To get the fan working the red and white MUST be connected and have voltage., if the yellow does not have 13.5 dc the fan will not work. the fan will work even if it's not connected.
So, The RED and WHITE wires always have voltage. jump the yellow to red and the fan WILL work. either inside the fridge or on the board. if you jump it, remember to disconnect the yellow from the board.
You can also check the fan with external voltage outside of the fridge with a small 12vdc transformer. RED and Yellow to Positive. White to negative.
The fan rarely goes bad. It usually starts humming before it goes bad(for weeks). U might change the fan, the board and not fix it. There might be a simple short from the board to the fridge connector.
Jul 13, 2011 | Refrigerators
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Fan won't run at all.
    If you plug it in and turn it on, does it "humm".
    If so, it is getting power. It could be the blades are stuck on something: do they turn by hand?
    The motor could be dirty also, is the blade hard to turn?
    It can be repaired by Vornado, or you can dis-assemble the motor and clean it.
    Dec 24, 2010 | Vornado Circulating Fan
    RVP 8000 A/C just experienced slight power surge. Compressor on.
    I'm leaning toward sticky relay as well, but if you want to confirm it's not thermostat, remove thermostat from wall, and temporarily disconnect the yellow wire from thermostat (compressor) when/if, it happens again. If compressor stays running, I'd say relay for sure.
    Just for future reference , Gray wire from thermostat is low fan, green wire is high fan, yellow is compressor, blue is ground. ( For cooling side) The red is 12 v + to furnace and white is negative to furnace.(heat side)
    Jun 10, 2010 | Coleman Mach 15 Air Conditioner
    My ceiling light and stopped working
    Hi there,  First of all, can you tell if there's power going to the light? Lets first make sure that it's not a power problem. You can check your circuit breaker in your main electrical panel. Now, when checking this - leave your light switch in the ON position. So when you're checking the circuit breakers, you can see from afar if the light/fan comes on. Now, you can also have a light switch problem too. Turn the switch on and off; and wiggle the toggle (lever) on the switch to make sure its tight. Next, get up on a ladder and make sure that your switches on the light itself are on the ON position. It most likely is, but you're just ruling things out. So, if you think there's power getting to the light - then turn the wall switch OFF. You can also turn off the circuit breaker as added protection. You would then need to take off the bottom of the light/fan to get to the wiring connections. If you have a little inductance tester, which when you put it up against the wires - a light, a beep, or both come on to let you know there's power. These little testers are invaluable. There very inexpensive, and they can save you plenty of headaches. If you can buy or borrow one, you would open the bottom of the light/fan - and make sure all your connections are tight and secure. I come across a lot of shabby splices were the wires aren't all the way in (secure) when its installed, and eventually with the vibration of the fan motor - the wires will work themselves loose. After checking the connections, clear yourself from the light/fan and turn the wall switch ON. Then go back up the ladder and wave your tester up against the wires to see if you have any power at the light. If you do, then you most likely have a switching problem at the light/fan.  To confirm this, you would turn OFF the wall switch again. Go back up the ladder and wave your tester to double check that there's NO power. Your next step would be to bypass the switch on the light/fan. You can do this by removing the switch and splicing (joining) the two wires together...or, you can locate each (only two) wire coming from the switch - and then splice (join) these two wires together. Now that you've bypassed this light/fan switch - get down from the ladder and turn ON the wall switch. If this is the problem, then the light/fan should work ALL together when your wall switch is in the ON position. If it works, then you'll have take that switch with you to your local Home Depot, Lowes, or hardware store to get this part. Its easier to take the switch with you and show the clerk at the store the part you need. They are common parts, so you should have no problem. Lets stop here for now. I believe you should find the problem by now. If not, please contact me again - and let me know what you have done, and what everything you did resulted in. I don't believe you'll go this far, but if so - then we'll proceed from there. Good Luck, and remember to turn the power OFF when you're working on the light/fan - and make sure your connections are secure when rewiring your connections back up. And then put everything back in order of how you took them off. I hope this works for you! Jim
    May 10, 2010 | Hunter 52" Ceiling Fan With Light And...
    I need to replace the bottom element in my oven
    You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
    To test and replace the element:
    1. Turning off the mains power to the oven.
    2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
    3. Remove the 2 power connectors to the grill element if one is fitted.
    4. Check the element resistance reading on the main oven heating element and not the grill element.
    5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
    6. Remove the earthing wire to the main oven heating element screw terminal.
    7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
    8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
    9. Reconnect the earthing wire to the element screw post.
    10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
    11. Reconnect the power cables to the main oven heating element.
    12. Reconnect the power cables to the grill element if one is fitted.
    13. Reconnect the power and check that the element works correctly.
    14. Disconnect the mains power again and replace the rear panel(s).
    15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
    Nov 14, 2009 | Ovens
    Dissposal does not acvtivate with the wall switch
    Do you get a loud hum when it is turned on? If so, then there is very likely something inside the grinder that is jamming rotation. Is there a way to turn the motor from the bottom? If so, try to turn it back and forth while someone watches inside the grinder with a flashlight for any obstruction. If no hum, check the power outlet with a working lamp. No power--check the appropriate breaker in the house electrical panel--push off, then on.
    Sep 18, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
    How to remove bathroom fan pull switch?it doesnt click
    1 turn power off remove appropriate fuse
    2 UNSCREW PROTECTIVE CAP
    3 screws aqre visible they usually hold 3 wires
    black green and red. if they have losts of black wound together it means they are in series with other lighyt switches. Ideally get an electrician in.
    anyway unscrew the wires from their holders and attach a new swtch placing wires basck in the same congfig. RED is LIVE Black is RETURN ( Usually) and Green EARTH.
    (Sometimes live and return may be blue and brown)
    put cover back on replace fuse and turn power on and hope there is no "bang" because you put wires in wrong way
    Jun 12, 2009 | Electrical Supplies
    The pump lost vaccum, now the motor shut off and pump only hums.
    Prime the pump. If it still just hums, try to turn the impeller. If the impeller is not jammed, and the motor hums or it doesn't start at all, the motor may be bad. Check for correct voltage of the incoming power wires inside the motor connection housing. Sometimes turning the circuit breaker off, then back on will fix it.
    Jan 15, 2009 | Garden
    Open Questions:
    See all Speed Ceiling Fan 3-speed Switch By Westinghouse Questions
    Speed Ceiling Fan 3-speed Switch By Westinghouse 77021 Logo
    1,777 people viewed this question
    Top Speed Electrical Supplies Experts
    Craig Butler
    Craig Butler
    epangan29
     Generator Guru...
    Generator Guru...
    Are you a Speed Electrical Supply Expert? Answer questions, earn points and help others
