Question about Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012
I let it freeze
What probably needs replaced?
    New Friend:
  • 14 Answers
The whole washer :)
sorry but the ice can make large damage in stuff like that. Disasseble it and carefully open your eyes :) look for cracks... It may be a sealing, or a whole pump may be broken...
Posted on Apr 16, 2014
Won't Chill or freeze. The thermostate was replaced.
Did you change the thermostat or the thermistor? Thermistor is probably your problem.
Jul 24, 2015 | GE Profile PSW26P Stainless Steel Side by...
Why are my vegetables freezing in the crispers and my juices in back of the refrigerator freezing?
Someone has either ran your thermostat to the coldest setting. Most thermostat controls should be set at mid position, On most that is a 5 setting. If this does not help, your thermostat probably is not functioning because the contact in thermostat may have welded together and needs replaced.
Sep 25, 2014 | Refrigerators
No heat smell burning antifreeze in exhuast
if you are smelling anti-freeze in the exhaust system and have no heat then you probably have a head gasket that is bad leaking anti-freeze into the combustion chamber and being burnt.the head gasket will need replacing.if the motor hasn`t gotten overly hot then the cylinder head is probably okay.
Apr 16, 2011 | Mazda MPV Cars & Trucks
I have a kawasaki KX250 motorcycle and there is oil in the radiator.
Check your engine and transmission oil for anti freeze. Also check to make sure your engine breather is not plugged. You probably have a leaking water pump seal , that is allowing oil to get into your anti freeze through the transmission. Normally when this happens the anti freeze goes into the transmission oil.
If there is no anti freeze in the lower engine or transmission , then the oil is leaking from a high pressure oil line going to the head to the cooling chambers filled with anti freeze. This means you probably need to replace your head gasket on the motor. While you have the head off check to make sure that the head has not warped. If it is warped it may have to be machined back to flat or replaced.
Dec 28, 2010 | 2006 kawasaki KX 250
My ice maker is freezing up sounds like a plane taking off
Most ice makers have a heater in them to release the ice cubes but if the heater is not working it will freeze up and the ice maker probably needs to be replaced. Call a certified service repair depot such as Sears.
Jan 29, 2010 | Refrigerators
1996 audi a4 2.6 v6 looks like steam from top of dash and smells like anti freeze
There's located the internal heater running on the engine coolant - something's broken: either the radiator or a pipe .
Dec 04, 2009 | 1996 Audi A4
Coil freezes up
Usually when the indoor coil freezes up you either have dirty filters or coil but if you had this unit replaced last year your coil and filters are probably OK so you probably have a leak in the unit and are low on refrigerant.
Apr 24, 2009 | Heating & Cooling
EVERYTHING FREEZES!
Probably need to replace that temperature control. Also check damper. If manual, set to where less air is going to fridge.
Sep 24, 2017 | Amana ARB224RCW Bottom Freezer...
Time to replace engine?
200k, congrats! I imagine you're asking this question because this freeze out plug is probably not easy to get at. I am guessing the truck has been well maintained to reached it's 200k milestone. I think I would replace the plug, as the engine seems to be humming along nicely. If you purchase a used engine, you may be inheriting a new set of problems. I'd go with replacing the freeze out plug, it's a heck of a lot cheaper than a motor swap. GOOD LUCK! countrycurt0
Aug 08, 2008 | 1990 Toyota Pickup
Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012 Logo
153 people viewed this question
Top Greenworks Garden Experts
richie46
Josh Van Nostrand
Steve
Steve
Are you a Greenworks Garden Expert? Answer questions, earn points and help others
