Question about GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator
Water is forming at bottom of freezer ..warping my hardwood floor
Repair just here..can't figure it out!!
  • debzieg Jun 18, 2009
    It is not a commercial model It has a drip pan..we looked at it .it is dry.
    one thing he did find is that there is "moisture" on the sides of the draws when he pulls out the freezer. He told me to keep paper towels in front of my freezer.
    Problem remains is that floor / frig/ freezer was fine 2 weeks ago..now my floor is warped.
  • Ivan Longcrow May 11, 2010
    Is this a commercial model? Some have a pan underneath with a heating element in it as the moisture runs into the pan a float valve turns on the power and the heating element eveporates the water...................
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Ice forming in bottom of freezer
Rita, your drain hole is frozen over and when your refer goes into defrost the water is running out into the cabinet instead of down the drain hole. Remove the evaporator cover and poor some boiling water in the evaporator drip pan. This should melt the ice and clear the drain hole....Catriver...post back.
Posted on Aug 17, 2006
yalmer
  • 552 Answers
SOURCE: frigidaire refrigerator with ice maker leaks water
It sounds like your ice maker is leaking.
If you are able, try opening up the ice maker for a visual inspection.
just remember to unplug first.
Apparently there is a leak somewhere.
Sometimes ice makers will over flow if the float gets stuck or a connection has come loose.
If you cannot work on it yourself, then I suggest looking up a service technician on the Fixya website.
Posted on Apr 22, 2008
jumptrout51
  • 3361 Answers
SOURCE: water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Posted on Mar 11, 2009
  • 44 Answers
SOURCE: 10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Posted on Jun 10, 2009
Why is water leaking on to hardwood floor and warping it.
Excessive water in the catch pan can be caused by a leak in the ice maker. Shut off the water supply and if the problem goes away it is caused by a small leak. If it continues it can be caused by high humidity in your home.
Jul 12, 2014 | Samsung RF220NCTASR 22 cu. ft. 30-Inch...
I have a Kitchenaid refrigerator kbfs22ewms. Have ice on bottom of freezer. Water seems to be coming from the vents at the bottom of the back of the freezer. While we were away the bottome completely...
Thank you for listing a model#!! It really helps to see what you have and lets me diagnose it better for you.
Whirlpool bottom freezers with ice forming on the freezer floor is nothing new. It is formed most likely by an ongoing issue with the design of the defrost drain becoming clogged and there is a revised kit for it part# W10619951.
Whirlpool has extended the warranty of this issue only to two years from the date of purchase and will usually give you the part but charge for install. This is for most models and you would have to call them to verify if it is covered.
It can be put in in less then 10 minutes using just a 1/4" hex bit and a small flat blade screwdriver to release the clip on the old "slide" style drain.
Once installed,it is best to defrost the fridge for at least 24 hours (doors open and unplugged) to make sure all ice is melted from inside the unit.
The problem should not come back afterward
Feb 10, 2018 | KitchenAid Refrigerators
MBF2256keb Water is pooling in the bottom of the freezer and eventually overflows onto my hardwood floor! What is wrong with it?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 20, 2011 | Maytag MBB2256G Bottom Freezer...
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
My Sub-Zero 550 is on a wood flooring that is experiencing severe water warping. I checked for leaks from the fridge at the water feed line to the water valve. The drain pan is ok Is there another...
Are you sure that it is water warping and not the heat from the compressor under the unit? Some wood flooring, such as laminate flooring is made up of pressed wood that is glued together and the heat may be warping the glue.
Aug 29, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Water collecting below veggie compartments water inside
Take you bastor and find the drain hole and blow air into the line to open it up. The drain from inside to the pan is clogged.
Jun 11, 2009 | Whirlpool ET1FTKXK Top Freezer...
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
Leak From Freezer
you have a clogged evap drain, you need to take the back panell off the freezer and pour boiling water down the drain port until it flows freely
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 13, 2008 | Maytag MZD2768G Side by Side Refrigerator
GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator Logo
62 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
