Question about Car Audio & Video
How do i install BOSS SE22 speakers in a 1996 avalon
There is a pin that I'm not sure where it goes
    Problem Solver:
  • 10 Answers
The pin may be used just to hold a bolt or screw that is stripped
Posted on Apr 17, 2014
I installed a Boss Bv9976b in my 1995 Honda accord,have no sound out speakers?
if you are sure the speakers are good and the wiring to the speaker is correct then you need to look at the Boss.. a volt meter on the output either at the speakers or the harness should tell you, as it fluctuates with the volume of the unit, hopefully you do have power to the Boss...
Dec 30, 2014 | Honda Cars & Trucks
Change out speakers in 96 avalon
how to
who can
please post a real question.
in the form of a question. or?
what types can i use.
what tools are needed.
are they polarized, yes.
who makes the best ones/.
like that , questions.
Feb 15, 2014 | 1996 Toyota Avalon
96 toyota avalon diagnostic code P1705
This is a fairly common problem more than likely what you're going to find is the revolution sensor on the top of the transmission just down from the bell housing has gone open. Remove the connector and ohm test the resistance through the sensor. You should have between 560 and 680 ohms of resistance. Check the pins in the connector and make sure there's no corrosion.
Oct 15, 2012 | 1996 Toyota Avalon
Locate power window fuse on 1996 avalon
The windows are not each on a seperate fuse if they all went out at the same time i would say its probably the switch in the drivers door cause all the power goes through that switch to go to each door switch
Jul 10, 2012 | 1996 Toyota Avalon
How do i match the color code for my radio in my 1996 toyota avalon
You should buy a wiring harness for your vehicle. That would solve your problem because Replacement head units all have the same color coding you should always buy a wiring harness when replacing any head unit for a proper install.
May 25, 2010 | JVC Arsenal CS-AR690 Coaxial Car Speaker
I have a 1996 toyota Avalon XLS my my dashboard
problem with steering wheel/column wiring harnes
Feb 21, 2010 | 1996 Toyota Avalon
Need car stereo color codes for 1996 toyota avalon xls v6
Check this for 1996 Toyota Avalon Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope helps (remember to rate and comment this free answeer).
Jan 06, 2010 | 1996 Toyota Avalon
DRIVER POWER SEAT 1996 TOYOTA AVALON WONT
Check all your fuses in the fuse box. A fuse must have cut off.
Mar 18, 2009 | 1996 Toyota Avalon
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
