Question about Honeywell 5-1-1 Day Programmable Thermostat RTH7400D1008
Battery I have four wires and all runs well. Does it run without batteries? When I take them out it doesn't run. Yet pkg states battery-free operation (optional)
  • 1 more comment
  • Ann kim
    Ann kim Apr 29, 2014
    supposedly it does according to the packaging on the thermostat. However it does not have instructions for this option.
  • Vuk B Apr 29, 2014
    I think you need "C" connected and if you dont have it that you need batteries. Good alkaline batteries will last a year. If still not sure best to contact Honeywell directly.
    For assistance with your Honeywell product, please visit www.honeywell.com/yourhome or call Honeywell Customer Care toll free at 1-800-468-1502.
    Master:
  • 678 Answers
Battery-free operation (optional) ?
Does your unit have this option?
Posted on Apr 29, 2014
Install battery isolator
if it is just the one battery, put the isolator on the ground wire
if the ground wire is turned off by the isolator , there is no circuit
Apr 16, 2017 | Chevrolet Cars & Trucks
Should I let the battery on my SanDisk Clip MP3 player run out completely before recharging for longer battery life? I've heard different answers. Some say it doesn't make a difference; others say...
It does not make any difference with these lithium batteries.
In the older Nickle cadium batteries, it does. It gets a memory effect, if you charge them from a half charges state.
Jul 10, 2011 | SanDisk Sansa Clip MP3 Player
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
Hi, I really need some help. I want to know whats wrong before taking my hp pavllion dv600 to service centre. Problem is that the charger doesn?t charge the battery at all. Charger is fine with other...
If the power supply does not run the laptop without the battery, then the problem is the jack in the laptop, over time the plug breaks free of the motherboard causing intermittent operation or no power. If the power supply runs the laptop without the battery, it is the charging circuits on the motherboard that is the issue.
Jan 04, 2011 | Computers & Internet
I want to install a 12 volt power point like the car lighter plug in my boat. Can it be done and how?
You can purchase this socket/connector at any marine store. You'll have to drill a hole large enough to slip the connector thru, but small enough so that it does not fall thru. Their should be hole dimensions listed on the pkg. Then, all you will have to do is run a positive wire to the postive battery or existing battery hot lead, and run a ground to the battery or exisiting ground lead. Also add a fuseable link to protect the circuit.
May 11, 2010 | Boating
Battery not charging.why?
most likely the voltage regulator,charge the battery up,check the voltage with meter engine not running,then start it up ,check voltage again,it should be 13-14 volts with the engine running,if it's less than the voltage you had without it runnig,replace the voltage regulator or check for loose or brole wires and connections....
Apr 05, 2010 | 1999 Honda Cb 400 Super Four
Battery not charging everything is good
There seems to be a no charge state in this case. i recommend checking the charging system. use the procedure below to isolate this issue.
Wear protective eye wear and clothing and remove all jewelry when checking your battery and charging system. Jewelry is a good conductor of electricity and is not recommended. Most batteries wear out every 3 to 5 years and need to be replaced. Always replace your battery with an equal replacement battery to assure proper operation. Automotive batteries have a +positive terminal (red), - negative terminal (black). Electricity is stored in the battery and then supplied to the vehicle when the engine is not running. While the engine is running the vehicles alternator charges the battery for future use. (Note: never disconnect the battery while the engine is running. If the battery cable is disconnected from the battery a spark can be generated which can cause the battery to explode or a major electrical malfunction to occur.)
To check a battery surface voltage, remove the positive terminal protective cover. Connect the +positive side meter lead (red) to the positive side battery terminal. Connect the - negative (black) side meter lead to the negative battery terminal. With the vehicle not running and the car sitting over night the battery voltage should be between 12.5 and 12.8 volts.(You will need to use a voltmeter for this testing procedure)
The alternator is rotated by a drive belt driven by the vehicles engine while it is running. Electrical voltage and amperage are generated to recharge the battery and supply voltage to the electrical system of the car. The alternator is held in place with mounting bolts. There is a main electrical wire on the rear of the alternator that supplies voltage to a main voltage junction box. If your alternator is not charging properly, your battery will slowly drain down from operating all the electrical systems in your car and stop the car from running.(most non charge states will be the cause of a loose belt or a low tension rate, due to a mis-adjusted alternator. make sure you have enough tension in the belt for full rotation of the alt pulley)
Next, you will need to check the alternators output with the Amp meter.
Testing the amperage output of the alternator is good for measuring the amount (not the level) of voltage the alternator can produce. This test can be tricky because if the alternator is weak it can still show it as producing amperage. Which is good, but if the voltage is low, it will still allow the battery to go dead. To check the amperage output of an alternator an amp meter is needed. Once the meter is connected start the engine. Next turn on all electrical accessories and raise the engine idle to about 1200 RPM. The alternator should output the max amperage it was designed to produce. Example: a 90 amp alternator should output about 88 amps. Note: An alternator cannot sustain maximum output for long periods of time. If the alternator is forced to operate at maximum output it will overheat and fail. An alternator is designed to operate at max amperage output only for a reasonable amount of time.
((Connect the voltage meter lead the same way you would in a battery static voltage check, Start engine (do not drive) at engine idle the voltage should be between 13.6 to 14.3 volts. If not the alternator may need replacing.)))
Nov 14, 2009 | 1998 Chevrolet Cavalier
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Honeywell 5-1-1 Day Programmable Thermostat RTH7400D1008 Logo
90 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Brandon Berry
Brandon Berry
Bill Long
richie46
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
