Question about Sta Rite Sta - Rite 2hp Max - E Pro Inground Pool Pump, P6ea6g207l
We have a Sta-rite mode P2RA50-120L, when trying to empty the pool of excess water the pump runs for appox. 30sec and then cuts out...the pool was very over full we bailed some ot the water out but it is still not working like it should be...Please can you help
    President:
  • Sta Rite Master
  • 1,378 Answers
If all you are doing is running your filter system to waste or backwash the fact that the pool is over full has nothing to do with it. It should run fine in either case. Your motor is likely starting to fail and as it overheats, shuts off. You may want to consider taking it to a local electric motor shop for repair or replace the motor. That motor is somewhere around $150 from most places. We sell it as well. If you would like a quote, please contact www.arrowmotor.net
Posted on Jun 18, 2009
Sta rite dyna glas 1 hp pool pump low water pressure
There are a few questions you need to address first. One is the pump sucking are 2/ is the skimmer box at the pool full of leaf matter 3/ I have the pump impeller got leaf of rubbish in it. Check these items first.
Jul 05, 2014 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Just installed a new pool pump. runs quiet, but does not seem to "pump"
Check the gate valves before and after the pump to make sure they are open all the way and to make sure the body of water is full enough so the pump does not cavitate the pump.
Rod
US Parts Center
888-521-6183
Feb 18, 2013 | Sta Rite Sta - Rite 1hp Dura - Glas...
We are renting a house with an in ground concrete pool. Repeated attempts to get the pump and filter going have failed. The pump motor starts but there is no movement from the pressure gauge on the Sta...
The pump does not need to be on during the fill process. You don't need to turn the pump on until the water level gets to the middle of the skimmer. The skimmer pulls water out of the pool to power the pump. It then goes through the filter and out the returns (jets) into the pool. If there is not enough water going to the pump (through the skimmer), the pump will run dry and burn up.
Jun 14, 2011 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Sta-Rite Dyna Glas Pool Pump
debris may have gotten into pump or pump is air bound need to check pump first try to bleed pump if water comes out and not pumping hard possible burnt up impeller or seal
Apr 03, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Pool in off mode but pump keeps running.
Replace filter pump relay if you have an automated system.if you have a timer it is not wired correctly
Sep 16, 2009 | Sta Rite Sta - Rite 2hp Max - E Pro...
Pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Sta Rite Sta - Rite 2hp Max - E Pro Inground Pool Pump, P6ea6g207l Logo
337 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
