Question about Ricoh Aficio 1035 Copier
Ricoh aficio 1035 copier, functioal problem SC390
    Problem Solver:
  • 9 Answers
The TD sensor could be bad. But more than likely you need to replace the dev material and the drum and charge roller
Posted on Apr 17, 2014
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 1035 sc code sc 329 troubleshooting
Laser diode beam not positioned correctly. Turn the machine off and back on and see if it goes away. You can run sp 2109-3 or 2109-4 in the service mode to adjust the beam in service mode by pressing on the yellow button. pressing the 107 keys and holding down on the clear button.
If this doesn't resolve the issue, you probably need a laser which we have one for sale here.
Posted on Dec 17, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh Aficio 1035 from Networked Unit to Stand Alone
There is a service code to disable the key counter. I'll have to look it up. If you are not connected to a network, you can still use the copier without being hooked up to one. That is just a warning message. You can clear it out by pressing user tools counter. Select interface and set all ip addresses to 0.0.0.0.
Posted on Jan 29, 2009
SOURCE: error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Posted on Mar 23, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
Ricoh aficio 1035 copier gives error code 390
TD sensor defective
TD sensor not connected or disconnected damage
Poor connection between the TD sensor and IO board
IO board defective
Toner supply defective
* Insufficient toner in developing unit
Apr 16, 2014 | Ricoh Aficio 1035 Copier
How to find out where to read meter on my ricoh aficio 1035 copier machine
Ricoh Aficio 1035 have two meter those are the electronic counter and the magnetic counter type but they are program to synchronize. to look for the magnetic counter just open the front door and you will find it at the middle and to open the electronic counter just press the user tools/counter key located on the upper left side of your operation counter then press the counter on the LCD display. Hope this helps, thanks for using Fixya
May 03, 2011 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 gives ERROR CODE SC322. CANT TAKE ANY COPY OF IT, PLZ HELP
that mean laser unit have proplem synchro 1 can't detect do with me 2109 and 2108 via sp mode if it's not work out change it
Jan 14, 2011 | Ricoh Aficio 1035 Copier
Sc390
SC390: TD sensor error
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
Dec 30, 2010 | Ricoh Aficio MP 1600L Black and White...
I am looking for scanner driver of Ricoh Aficio 1035 3 in 1 printer
hello mate. go to www.ricoh.com.au and under the downloads you will get the scanner driver.
Dec 19, 2010 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 scanner problem,can scan but pc "hang " why?
1).Restart your computer. 2).reload printer driver on your computer.
Oct 31, 2009 | Ricoh Aficio 1035 Copier
Fusing lamp of my Ricoh Aficio 1035 was broken 230V 650W red
Measurement the countinously of the heater lamp,check the thermistor and thermofuses nad reset the error code.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
183 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
