Question about Husqvarna Viking 1
Unable to transfer my design from computer to sewing machine
Pfaff 2144 usb cable driver is what i am looking for. i have 3d program on a windows 7 laptop
4 Suggested Answers
SOURCE: Have 3D software,Pfaff 2140 machine and Hus Designer Diamond mach
I have loaded the 4D software and have communication with my Husquvarna machine through that. I communicate with my Pfaff through the old 3D software on my computer.
Posted on Nov 24, 2008
  • 192 Answers
SOURCE: unable to load 3d embroidery on hp windows 7
3D was intended to be used on XP and also worked for some time on Vista with the proper manipulation of updates. I don't believe that it will work at all on Windows 7.
4D does work on both Vista and Windows 7. It does need the latest update for Windows 7.
Posted on Feb 09, 2010
  • 192 Answers
SOURCE: I have a Designer 1 sewing machine and
3D software does not run on Windows 7.
4D does.
Is a pfaff 2144 compatability with windows 8?
It's not the machine that's the problem. It is the software version that you are running that most likely not compatible with windows 8. The problem is that the latest 6d software is not compatible with those machines unless you have a USB cable.
Apr 22, 2015 | PfaFF Sewing Machines
I have a 3D/ Pfaff 2170 Creative & I'm using Windows XP. No device found error. I can not transfer the embroidery design to 2170 Pfaff. Help!
Sounds like you don't have the device driver on you computer for the sewing machine. Question: Did it ever work? If it used to work but doesn't now, try using a different cable from the computer to the sewing machine. You can also try rebooting the computer (with the sewing machine connected and powered up) to see if it will locate the machine.
Dec 19, 2014 | PfaFF Sewing Machines
I have a 7570 phaff sewing machine and a new windows 7 PC What will I use to transfer my patterns to the machine
Hi franlove
I had the same problem when I upgraded to a laptop with Windows XP. I needed to buy a Keyspan, which connects via the USB on the computer to the machine via the pc connector that comes with the Pfaff 7570. However I had many problems after that, and found that the Keyspan transfer rate had to be slowed down to 2400. Of course 3D is the most recent Pfaff software that the Pfaff 7570 will work with. Anything older is OK.
Hope this helps. I will look up the steps that I went through to slow the transfer speed from the Keyspan if you need me too.
Good Luck
margielydia
Dec 29, 2010 | PfaFF Creative 7570
I have a 2144/2170 and new Florini software. I do not know how to transfer a design from the computer to the creative card with a cord and then to the sewing machine. The design is in the autoditizing...
I bought a Ultimate Box and Ultimate Card, Wright the design to it, and then in the machine, I use the Data Manager to select the design (doesn't show the actual name, just dsgn1 or something like that), ok to the warning.
Jan 13, 2010 | PfaFF Creative 7570
7570 connection
I have Windows Vista; I also had a similar problem; found out that I could only use the usb port on my computer exclusively for sewing as the driver software seems to conflict;
Also, having said that, go to Pfaff.com & download the free driver upgrade and see if that will get you started good luck deb
Jun 24, 2009 | PfaFF Creative 7570
Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Jan 06, 2009 | PfaFF Creative 7570
Cannot get Janome 10001 to read via USB direct link from computer
here's how I do it.
1. Get the design into jef or sew format (the only kinds janome reads). You probably already knew this, but some newbies try to use pes or art files.
2. Save it onto your computer (and remember the name of the file). I have a folder in my computer labelled "embroidery files" and then have subfolders dividing up those designs - such as animals, flowers, fonts.
3. Hook your sewing machine up to the computer via the USB cable.
4. Pull up your Janome "Easy Transfer" program (it came as a CD with your machine - this is NOT the customizing software).
5. Use that program to find your embroidery file. It's not going to show sew and jef in the same file - you'll have to switch back and forth.
6. On your sewing machine, click on the bottom button (under the screen) that shows the computer to the sewing machine (the third one).
7. Now click on the computer software "write to machine" or whatever it's called (it will be on the top tool bar).
8. Your file will be written to the sewing machine's memory and organized by the embroidery hoop size (A, B, C).
9. It will stay in the sewing machine memory until you use the cable hookup to delete it (reverse of the writing).
10. The 10001 software ate lots of the resident memory in the sewing machine - you can't store as many designs in it as the 10000 would allow. That's perfectly ok, as it only takes a few moments to move designs in and out of the machine.
To be perfectly honest, I vastly prefer doing the USB cable transfer to using the memory card jammed into the card reader deal. It's easy and quick.
Oct 30, 2007 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
69 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
