Question about Electrolux EFC90244X Kitchen Hood
Electrolux PLHV42P8CC/two lights working two out and replacing bulbs does not fix the issue
There is an array of 4 lights, halogen insets, left and right front and back. The left front and back work, the right front and back do not. Changing out to new bulbs and as a failsafe changing out the working bulb on the left to the non working side, does not fix the problem. Still no light on right side, front to back. Help?
  • Rick Rappaport
    Rick Rappaport Apr 18, 2014
    Ok, one of the proferred solutions for a similar problem described testing the transformer and replacing it. Can anyone tell me if the unit I have also has a transformer and where it is?
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Rick,
I see that you are having trouble with the front right and back right halogen lights not working on your Electrolux range hood, model# PLHV42P8CC. I also see that you have heard of testing and replacing the transformer inside your appliance. I suggest contacting an authorized technician. It could possibly be something other than the transformer or it is possible that it is the transformer and something else that is causing the right side lights to not come on. Hope this is helpful.
-Best Regards-
WP
Posted on Apr 22, 2014
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Nov 29, 2016 | Sirius Kitchen Ranges
How do I find the fuses for my Electrolux PCHV42P88 hood? One row of lights is out and it is not a bulb issue.
Good Morning James Formalyn, thanks for your post!
I see that a row of lights is out on your Electrolux hood and you are searching for a fuse. I was unable to locate any additional information for your hood. The model number you have provided is PCHV42P88. If you could check the model number I would be able to locate any additional information. I look forward to helping you. -Matt
Dec 17, 2014 | Electrolux Cooktops
Passenger side low beam doesn't work. Notice bulb is out. Replaced bulb but still doesn't work. High beam works fine. No problem with driver side. Is there a fuse for the left side?
No you must have a wiring problem if the bulb is good. You can test the bulb out of the car. Do not touch any halogen type bulb with your bare skin.
Dec 09, 2014 | 2005 Hyundai Elantra
TYPE BULB FOR PANASONIC NNP295 COOKTOP LIGHT
Halogen Cooktop/Night Light Replacement
Be careful as the Cooktop Light Cover and the bulb may be
hot.
1. Unplug microwave oven or disconnect power.
2. Loosen the screw to open the Cooktop Light Cover.
(Be careful not to lose the screw.)
3. Replace the old bulb with a new one.
(use Max. 125 V, 30 W, Wide Pin Capsule Type/GY8.0~9.0
recommended)
do not touch a new Halogen bulb with bare hands.
Fingerprints may result in shorter life. Remove fingerprints
with alcohol.
If this bulb is not available locally, contact your local
Panasonic dealer. Part number is F612E6Z00AP.
4. Reinstall the Cooktop Light Cover with a screw
Dec 02, 2014 | Panasonic Microwave Ovens
Need replacement halogen lights for SU3
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Mar 07, 2013 | Sirius Hoods SU3
Installing d2r sylvania lamp in 2001 acura
look in owners manual back index for bulb replacement, it will show and tell you how to replace light bulbs.make sure you wear clean glove when handling halogen head light bulbs because oils from skin will cause halogen bulbs to over heat and blow out, halogen bulbs not cheap.
Jan 03, 2012 | Cars & Trucks
Removed the switch plate and connected the two wires going into the dimmer box and the lights still dont come on. I as thikning by bypassing the dimmer the lights should still function. What else could be...
I am going to stick my neck out a little with this one although I agree with BoomerP. The clue of halogen bulbs is feeding my answer. Halogen bulbs require a high voltage transformer to operate and won't normally work with a dimmer but I never tried it. Bypassing the switch should bring them on though. If you have the proper voltage at the switch and they don't work with the switch bypassed, its probably a bad transformer in the fixture. Good Luck. Be careful.
Feb 04, 2011 | Lutron ELECTRONICS MAW-600H-LA SMART...
2006 Honda CR-V; had front driver's side headlamp bulb replaced and car battery replaced and now the odometer backlight doesn't work -- a related issue or separate and is it expensive to fix?
You can replace the instrument cluster bulb with a regular halogen bulb, or use T5 led bulbs that come in a variety of colors (white, blue, etc.) They are inexpensive and will last a lot longer than the regular halogen bulbs.
Replacing the faulty bulbs isn't too hard for DIY.
For help: Moonlight Driving
2006-honda-cr-v-front-drivers-side-zp00lepaloflvda1hbduq5xd-4-0.jpg 2006-honda-cr-v-front-drivers-side-zp00lepaloflvda1hbduq5xd-4-2.jpg 2006-honda-cr-v-front-drivers-side-zp00lepaloflvda1hbduq5xd-4-5.jpg 2006-honda-cr-v-front-drivers-side-zp00lepaloflvda1hbduq5xd-4-9.jpg
Jan 16, 2011 | 2006 Honda CR-V
Advantium Bulb replacement
You are describing the little bulb in the front. The speedcook light is a different bulb
See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Apr 12, 2008 | GE Advantium SCA1000H Convection /...
Electrolux EFC90244X Kitchen Hood Logo
191 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
