Question about Pioneer CDJ-850 CD PLAYER
Pioneer CDJ850 is not powering up after cleaning inside.
Cdj 850 is not powering up.It was in well running condition only opened it for cleaning the jog.After that when plugged in and turned on the Standby light flashed for few seconds then its not turning on. Please Help...
  • Dom1n1c
    Dom1n1c Apr 16, 2014
    hey, You should check all cables connecting top and base together...also this may be your problem if not you can read through the service manual and try to diagnose the problem.http://djtools.in.ua/media/images/pdf/dj...
SOURCE: Pioneer CDJ-800MKII
Hi, if this cdj 800 mk2 is not loading or it keeps ejecting discs i would suggest you contact your local pioneer repair agent as this is a common fault with the players at the moment and there is a fix for it but you need a special jig to set up a laser replacement and only the pioneer agents have this jig or your player needs a software update but the software update is done via a cdr disc in your case your player isnt reading discs at all so its likely you need a laser pick-up replacement. hope this helps you. regards. paul.
Posted on Sep 04, 2007
  • 10 Answers
SOURCE: jog wheel problem with pioneer cdj1000
Sounds to me like your platter on the jog wheel is stuck in the engaged position. You have to open up your unit and take apart the jog wheel. In there you will find some spring things (don't quite remember what they look like at the moment or where exactly in the jog wheel they are) and you have to strech them back out so that when your hand isn't on the wheel it will spring it back up. Either that or the switch is busted and if that is the case you have to replace the switch.
Posted on Jul 22, 2008
CLARKPINK55
  • 71 Answers
SOURCE: pioneer cdj 1000 mk2 not powering up
its the internal power supply its failed these are all like this expensive to do get it fixed and out it
Posted on Dec 17, 2008
petraman7
  • 1175 Answers
SOURCE: Pioneer CDJ 1000 - Jog Wheel not working.
Parts:
http://www.instrumentalparts.com/picdmkicdj80.html
Beer is meant for human innerds not CD players
Posted on Jan 14, 2009
cdj repairs
  • 68 Answers
SOURCE: Pioneer CDJ-1000 CD Player jog wheel display
Sounds like a fault on your jogwheel pcb.
if you havent had your player repaired then you can contact me @ www.audiovisualservices.info
Hope this helps you.
Thank you.
Posted on Jan 19, 2010
Kerig K40 leaking coffee out the front of it
my pioneer cdj 850 power is not coming up after losing and cleaning it i mistake-ling interchange the cover and the boot player refuse to come up
Jan 19, 2017 | Coffee Makers & Espresso Machines
How do i connect my pioneer CDJ850 to my behringer DDM4000
with a RCA cable (red & white) from the CDJ's LINE OUT to the DDM's chanel 1 LINE IN then press the button on the back of the mixer that swops the channel from LINE to PHONO over to LINE..
Mar 02, 2013 | Pioneer Audio Players & Recorders
My CDJ 850 won't turn on.
If the standby light blink then it indicates a fault relevant to the processor.If the set is fully dead then the SMPS power supply can be faulty.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Jul 12, 2011 | Pioneer CDJ-850 CD PLAYER
I want to purchase a pair of pioneer CDJ 850 players, however in my country the power supplied is 110 volts at 50hz. I have had problems using electronic devices that only specify 60hz. The CDJ 800's...
The 850's should work fine on 50Hz. They are spec'ed at 120/60. with your lower voltage the transformer in the power supply should NOT have a problem. There is nothing syncronized to line frequency so it should work fine.
Jun 01, 2011 | Pioneer CDJ-850 CD PLAYER
Jog wheel problem,sometimes when I spin it,it is often soft and sometimes hard,is there any defects with the Cdj 200???
hi frnd,
no need to worry, Its just dirt has gone inside. If it is going to open in future
remember to clean too.
thx,
djajay
Jul 29, 2010 | Pioneer CDJ-200 CD Player
My cdj 800 is having a problem with cd reading.its not reading cds as it was new..just 1 year nw for my player.if put cd inside it cums out afetr 2,3times if i insert cd inside then it getging read......
Sometimes so CD does not play in certain CDJ, i have 2 or 3 disc which
does not play or eject when i try to play in CDJ 100s but when i play them
in another player they go well.
Pls try to have some other brand disc or you may clean compartment of the CDJ their may be dirt inside CDJ. I hope this will help.
thx,
djajay
Jan 29, 2010 | Pioneer CDJ-800 Turntable
Pioneer cdj 200
the fuse was blown inside!!
Aug 11, 2008 | Pioneer CDJ-200 CD Player
Cdj-800MK2 jog problem
From the video, it just looks like there might be some debris/dirt underneath the platter. There is a sensor pad under the platter, and if there is anything disrupting the pad, you'll have those issues.
Try opening her up, and cleaning her out. Or take her to a service center for a professional cleaning.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 06, 2008 | Pioneer CDJ-800MK2 Turntable
Power
You need to check internally, Transformer/rectifier could be bad, disconnected wire, blown internal fuse. Can you rub the needle with your finger and get sound? Is it just the table not turning or is the needle not getting "power" either?
Dec 04, 2007 | Pioneer CDJ-800 Turntable
Pioneer CDJ-850 CD PLAYER Logo
96 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
