Electrolux w3105h door no longer open when the machine stop
4 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
SOURCE: I have an Electrolux EW 548 F Washing machine.
It sounds as if something has got stuck in the filter jamming the drain pump,try draining the water out either through the filter but beware of the amount of water.Or take the drain pipe at rear and try to drain iinto a container or through the nearest door to an outside drain.Once the water is out you should be able to open the door.Then you will have to find out if some object is stuck in the filter(located at bottom right hand side).
Posted on May 03, 2010
piroman61
  • 21 Answers
SOURCE: I can't open the door of my Electrolux EW648F washing machine after the wash. Can somebody help?
Plese make sure the timer is at the end of the spin sickle and try to open after it unlocks. Otherwise take a crow bar to it and gently persvaide it.
Posted on Mar 03, 2013
What does error code 04e mean on the Electrolux w3105h mean
04 ERROR. LOW TEMPERATURE The temperature is below the lowest value allowed (open circuit in temperature sensor).
Jun 07, 2016 | Electrolux Washing Machines
Electrolux EIFLSI5IIW1 stops at 1 min left in cycle
I have solved same problem with washer Electrolux EWS1066. All cycles stops after starts with 1 min left on display and open inlet water valve. I think that was bad door interlock but it was a defective main controller. No damage visible on board than I heated PCD with heater gun mainly pointed to SMD parts. Now washing machine work good.
Oct 14, 2014 | Washing Machines
Electrolux W3105H
error codes http://www.needapplianceparts.com/electoluxfaultcodes.aspx
Aug 05, 2014 | Washing Machines
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
Sep 08, 2017 | Electrolux AWF1220 Front Load Washer
I have an electrolux ewx1440w washer-dryer. It keeps stopping part way through wash cycle. Cycle pause light flashes and door catch releases allow you to be able to open door. Machine will not restart...
Hi I exactly have the same problem.. seems to be a common issue with this Electrolux series.. Thought that Electrolux was serious brand but obviously quality is leaving our world.. did you fix the problem and how..?
May 20, 2010 | Microwave Ovens
2009 Frontloading Electrolux washer door will not open!
When this happened in our home, we unplugged the machine, waited then plugged it in again. This reset the machine and the door immediately unlocked
Feb 18, 2010 | Electrolux EW1000i Front Load Washer
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
