Question about Frigidaire ATF6000ES Front Load Washer
Frigi ATF6000ES1 How do install the spring on the front door seal
The rubber seal between door frame and tumbler has a tight spring around the seal, how to replace it, it seem impossible
  • brentkennard Jun 19, 2009
    Ok I followed all your steps, I am a outstanding mechanic but fail to pass step 11 there is no way to stretch a haft the diameter spring over a tapered tubwith such a small lip to retain it. what am I doing wrong
  • 315 Answers
Please go through the steps provided in below website: http://www.applianceblog.com/washers/Rear.pdf
Best of Luck!!
Posted on Jun 18, 2009
  • mithun dey
    mithun dey Jun 19, 2009
    Try using a screw driver...
Front seal came off
Sometimes when the load get tangled during the cycle and you try to pull all the load out in one go, you can dislodge the seal and retaining spring. Remove the wire around the door seal, repositioned the seal around the edge of front panel porthole. There is a folded metal edge around the metal frame and the grey rubber gasket lips over this, once in position, offer up the metal retaining band and use a pair of long nosed pliers to stretch the spring so you can get it to sit around the seal. Sorry this a little long winded but very difficult to articulate properly, so I hope you get the gist. Cheers
Mar 26, 2013 | Bosch Washing Machines
How to install spring clamp on outer portion of
If you are referring to the small wire hoop with the small spring, follow these steps:
1. Make sure the bellow is installed correctly all the way around the opening of the door frame.
2. Beginning at the top of the door, start inserting the wire hoop in the rubber groove of the bellow. Make sure the wire spring points towards the 6 o'clock position (bottom).
3. As you work your way around the door to the 4 and 8 o'clock positions with your hands, maintain some constant downward pressure to hold the bellow in the rubber groove.
4. Pull the spring apart to stretch the wire hoop open and snap it back into place.
NOTE: Using a second set of hands to hold the wire hoop in place, makes the process much easier.
If you still have problems, please let me know. I hope this helps you.
Jan 05, 2010 | Kenmore Elite 45986 Front Load Washer
Rubber door seal came off along with metal ring. How do we fix it?
If you are referring to the wire hoop with a small spring, this is the front bellow clamp. The bellow is the rubber door seal. Around the perimeter of the seal where it attaches to the door frame, is a small groove in the rubber. Make sure the rubber bellow is properly seated around the door frame opening, then the wire hoop inserts into the groove in the rubber to hold the front of the bellow affixed to the door frame. Without it and the bellow will eventually come loose and the washer will leak. To reinstall, just follow these steps:
1. Make sure the bellow is firmly seated all the way around the perimeter of the door frame.
2. Begin inserting the wire hoop into the groove, starting at the twelve o' clock position.
3. Work your way around the four and eight o'clock positions. While maintaining some downward pressure to keep the hoop inserted in the groove, pull the spring apart and snap the wire hoop back in place.
A second set of hands may come in handy to hold the hoop in position to get it reseated. Make sure the wire hoop ends up at the 6 o'clock position when you are complete.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer with heavy items can contribute to premature wear on the bellow and can cause the clamps to come loose.
Dec 30, 2009 | Washing Machines
My washer front load rubber at the door has pulled away and the wire with spring has come out. the rubber is not torn and i put it back in but i dont know were the wire gos
Dec 29, 2009 | Kenmore Elite 45986 Front Load Washer
The rubber piece in the front of the washer is pulled up and the metal large ring is not in place not sure how it goes back on
If you are referring to the wire hoop retaining clamp that holds the door bellow (rubber gasket) in place, it installs the following way:
1. Install the bellow over the frame of the door opening and ensure its seated and snug all the way around the perimeter.
2. Beginning at the top of the door, start inserting the wire hoop into the rubber groove of the bellow that is located around perimeter of the door frame. Make sure to wire spring points towards the 6 o'clock position.
3. As you work your way around the door frame to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to get it to snap into place.
It would be helpful to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
The wire hoop is known as the front door bellow clamp.
If you have any problems, or further questions, please let me know. I hope this helps you.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rubber boot and spring need put back in
The rubber boot presses on the rim, and the spring clamp fits in the groove behind it. Don't overtighten.
--W/D--
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
Metal ring fell off
If you are talking about a small metal hoop with a spring on one end, it is the outer bellow retaining clamp. The bellow is the rubber door seal. The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If this is not the spring you are talking about, please post back and elaborate a bit more on what the part looks like to see if I can assist you better. (i.e., size, dimension, where you found the part, etc.)
I hope you find this information helpful.
Jun 30, 2009 | GE Energy Star WCVH6260F Front Load Washer
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Kenmore door to tub spring has come off
If you are talking about the inner spring that holds the door bellow to the tub, it's going to require two hands to get the spring to go back in the groove. You will need to carefully remove the bellow from the front opening of the door, first. On the 417 models, such as yours, the bellow is usually glued in place aorund the door frame and held in place by a spring to the tub. Use a putty knife to carefully peel the rubber form the washer facing. Once completed, you can glue it back in place with some appliance adhesive. To get the spring back in the groove on the tub facing, you will need to start at the top and have someone hold it on place as you work your way around the the tub. It's a real bear to get back in at times. Let me know if this helps you. Please post back if you have questions.
Dec 22, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
