Question about Pool & Spa
There is a symbol of ... flashing under my temperature. Not heating up but pump and everything else working
Im refilling my Nahanni hot tub after an emptiing and refill. I turned the breaker on and I can hear it working. The heater isn't though and it is flashing a symbol of ... under the temperature. What do I do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Check to see if fuse is blown if you turned it on b4 full it could blow fuse or temp sensor also check heater element sounds like temp sensor not calling for heat
Posted on May 08, 2014
  • 990 Answers
SOURCE: My Hot Tub gets and HL msg as soon as I turn it
This is probally a high limit warning. If you have a reset on your heater it is probally popped out. If you have drained the tub latly this may be caused by an air lock in the pipes and can be remeied by opening the drain **** on the bottom of the tub till you get water out of it. If your pump or motor has gone bad you will get these same simptoms. If you have no reset on your heater you may have burnt the element and will need to replace it This a symptom not the real problem. You need to check these other things first and be sure you have moving water before you try the heater. I hope this helped and good luck.
Posted on Dec 02, 2009
  • 11 Answers
SOURCE: Vibrations and banging when heater is turned on
wow! That heater that you have is meant for a very large swimming pool, quite a bit oversized, i bet i gets the job done quick though. I have seen before that somebody plumbed in a heater backwards, there are elevated arrows on the black manifold of the heater, make sure inlet and outlet are plumbed in correctly. Make sure you get your water tested. Because the water in your hot tub is no circulating as often (I assume) as a pool would be, the stagnate water sits inside the heat exchanger. What can happen, for instance, if you have high calcium, is the certain tubes inside the heat exchanged can get so clogged with calcium and they are completely shut and the banging noise is due to excessive heat build up inside the heat exchanger. This can ruin a heat exchanger very quickly and the heat exchanger is half the cost of the heater if you were to get a new one. You can check and see if tubes in the heat exchanger are clogged by taking the manifold off of the heat exchanger, and shining a flashlight down the different tubes. However you have to disassemble quite a bit to actually be able to do that.
Posted on Jan 08, 2009
PartsCenter
  • 125 Answers
SOURCE: Arctic Spa refill and a heater alarm ''HL''
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
Posted on Feb 26, 2009
  • 61 Answers
SOURCE: My jacuzzi keeps emptying into the pool when the
I agree it sounds like a check valve. if the water in the pool matches the water level in the spa, or drains all the way (depending on how far the spa is raised) then it is the valve before the pump, but if it goes down to the jets (and not any further) then it is a check valve or valve on the retun side of the plumbing ( after heater or chlorinator).
Posted on Apr 04, 2009
SOURCE: Tub is not heating to
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
Posted on Oct 20, 2010
What does code C6 mean on my Nahanni hot tub
if voltage past relay bad motor
Aug 10, 2017 | Pool & Spa
Heat suspended flashing hot tub loosing temp. Down from 104 to 84
just a guess but id say your temperature controller has failed and it went over temperature , the safety cut in to save the tub (heat suspended) could be anything in heating circuits from heat elements to temp probes
Jan 22, 2016 | Pool & Spa
The display panel on my hot tub shows a lock and none of the function keys respond when touched
didnt specify if you had a 4 8 or 10 button panel your unit is locked the only control that will work is temperature your owners manual has how to unlock it under side panel the following link is for an 8 button panel and the instructions are on page 6
http://qcaspas.com/media/pdf/Jewelp3-8Btn.pdf
Oct 28, 2015 | Qca Spas Jewel Series Topaz Plus Hot Tub
Infinity maax hot tub
all systems must be working or the spa will not heat. If one of the sensors is not functioning then the spa water will not heat.
Rod
US Parts Center
Nov 25, 2013 | Home
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
Just drained and refilled, plugged back in and hot tub is not heating. Three lights flashing at temp controls. Is there a reset
Most hot tubs have a freeze protection that will lock you out and run the pumps full blast with no heater if the temerature is under 50 degrees F.The circulating pumps create heat until the water temp is above 50 degrees, and then the heater will come on after that.
Hot tubs do this to protect themselves and it is normal operation.
Nov 22, 2010 | Qca Spas Pool & Spa
Even thuogh I made sure it was not on economy mode my hot tub will not heat up and the message board keeps flashing the word cool, do you know what could cause this?
it may be a bad temperature sensor or a bad heating element. Sounds more like a heating element. The cool should just be a warning or depending on the model, could mean that it thinks the water is too hot and is in "cool" mode trying to cool the water. Have the temp sensor and the heating element checked.
Feb 05, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Savannah spas
probably a dirty filter!! take it out turn tub off to reset turn back on with filter out and c if nthis solves problem if so replace filter.
Nov 20, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
Pool & Spa Logo
124 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
