Question about Maytag 2.0 Cu. Ft. Over-the-Range Microwave
Door won't open
The button depresses with normal resistance, but the door can't be opened.
  • Joel Lown
    Joel Lown Apr 16, 2014
    Please ignore this question. The make and model are wrong.
    Top Expert:
  • Maytag Master
  • 45,139 Answers
The latch may be defective or misadjusted.
Posted on Apr 16, 2014
How to fix the door button on panasonic microwave t6648fx?
Clean the inside edge of the door and oven where it contacts the door. Grease or oil is preventing the door to swing open.
Aug 28, 2014 | Panasonic Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
R-1481 start button won't work
I have a r-1482 model so I don't know how close they will be. The biggest issue I found so far with my particular model, yours my be the same, is the door safety micro switches fail primarily from opening the door while the unit is in the process of cooking which causes them to arc and burn the contacts resulting in premature failure. With an ohm meter, check the resistance of the contacts of each switch individually with the COM terminal lug temporarily removed and ensure the closed resistance is 0 ohms and infinity when the contacts are open. Measure from the COM terminal to the terminal in use either N.O. or N.C., with the switch button NOT depressed the N.O. will be open while the N.C. will be closed and with the button depressed they will be opposite, in other words N.O. will be closed and N.C. will be open. Another thing to check is that the door hooks aren't broken (they activate the safety switches. Should you remove the switch bracket to replace the micro switches, make sure you wire the switches exactly the way they were COM to COM, NC to NC & NO to NO, mount them in the bracket the exact way they were and adjust the bracket so that the switch buttons are just to the point of being fully depressed and no more when the door is fully closed. The micro switches may be different in model numbers but you can sub with a micro switch that has all three COM, NC, NO terminals and only use the terminals in use for the given switch. I used Omron p/n: D3V-16G-1C25-K from Mouser Electronics (800) 346-6873. Since you didn't indicate the control panel was not operational I won't go into that area. I can't say if the timer will count down or not if the micro switches are bad, but it's a possibility, further pointing to the switches. If the control panel or MW tube is bad it's my recommendation to buy a new oven, though you can get new MW tubes, diode & capacitor, it's not worth the shocking experience to the human body, not to mention the MW radiation.
Good luck if you still have the oven and decide to take it one step further.
Jul 19, 2012 | Sharp R-1481B Microwave Oven
Defective microwave door switch?
You are correct about the upper switch if normally open resistance infinity, but when switch is depressed resistance should read near 0 ohms, you need to change the door switch. Now the high voltage diode cannot be checked with a digital meter because the bias is to high, chances are it is okay.
May 11, 2012 | GE JVM1850 1000 Watts Microwave Oven
I have a jenn-air microwave JMC 7000adw. A few weeks ago, it sunddenly did not work anymore. I can still press any button and the clock is till right. But when I press any cook button, lick beverage, it...
Hello there and welcome to fixya
IBefore you begin to test a door interlock switch, first make sure your microwave oven is unplugged, and that your capacitor is discharged.
A door switch is a simple on/off mechanism that prohibits the microwave from operating when the door is open. Microwave door switches are only an inch long. Most are black in color and all have metal prongs, called terminals, extending out from the body of the switch. Microwave door switches are normally mounted to a bracket near the door latch. Also, microwaves usually have three or four door switches.
There is a latch (sometimes referred to as a hook) attached to the inside of your microwave door that comes in contact with and activates the door switch when the door is closed. Examine this prong first. You may not be experiencing any problems with your door switch. Perhaps the latch on the inside of your microwave door is missing or damaged, leaving it unable to activate the door switch.
Some door switches have only two metal prongs extending from the body, while others have three. Those with three terminals will have a common (COM) terminal, a normally closed (N.C.) terminal, and a normally open (N.O.) terminal. Those switches with only two terminals will have either a common terminal and a normally open terminal, or a common terminal and a normally closed terminal. We are providing directions for testing a door switch with three terminals. If you are dealing with a door switch that has only two terminals, ignore the part of this test that does not apply to you.
Using caution, remove all wiring harness leads from the switch's terminals. Be aware that some door switches may have a locking clip keeping the harness from coming loose. In this case, there is a protruding lever which must be depressed while the harness is gently pulled away from the terminal.
Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of Rx1. If you are using an analog meter, touch the metal tips of the test leads together and zero your ohmmeter by adjusting the thumbwheel in the front of the meter until the needle reads '0' on the scale.
Touch one meter lead to the COM terminal and the other lead to the N.O. terminal. Do not push in on the actuator. Your meter should give a reading of infinity, meaning the circuit is open, and there is no continuity. Without moving the meter's leads, press down on the actuator until you hear a 'click'. With the 'click' of the actuator, the meter should produce a resistance reading of zero ohms. This means the circuit is closed and continuity is presen
Feb 05, 2012 | Microwave Ovens
Panasonic NN-ST666W Microwave oven
What usually breaks is the door open lever, but it may be that the rear of the door open button and the face of the door open lever are worn to the point where they will not actuate.
On a counter top model, the outer cover will need to be removed to diagnose and repair this.
On an over-the-range model, only the control panel needs to be
removed in most cases.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find Panasonic parts in Australia here.
Dec 07, 2008 | Panasonic NN-P794SF Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Nov 17, 2006 | KitchenAid KCMS145J Microwave Oven
Maytag 2.0 Cu. Ft. Over-the-Range Microwave Logo
48 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
