Question about Vulcan EV12-2FP-240 Expando Range
Oven shuts off by itself
First load of the day; works just fine. But if you open the door too quickly, a warning light is lit and then the oven will not work anymore. If you crack open the door, wait then finish opening. You can reload the oven, but after about 10 minutes it will shut itself off and not work for the rest of the day
2 Suggested Answers
  • 586 Answers
SOURCE: The Fan shuts off and
You need to check the relay switch of the gas cooker to know if it is bad, then is what controls the power of the oven if it is faulty, it will begin to trip off and on all of a sudden.
Then for the oven that does not heat, the problem is from the baking element. The bake element is the bottom element in your oven. The life span of these elements can vary depending on the usage of your oven and the quality of the element.
Usually lifting the element and pulling out on it will release the element. If the contacts are discolored or pitted then they could be causing your problems. By using an ohm meter you can check the resistance of the element. If you get no continuity through the element it is no good.
Hope this helped.
Goodluck
Elect_Comp
Posted on Jul 01, 2011
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
Dryer not working. Lights reads PF
If your dryer is showing code PF, then a power failure interrupted the previous load from completing and you will need to restart the cycle. You will need to press and hold the "Start" button to restart. If the error message reads E1, E2 or E3, then there is a more serious problem and a technician will need called to resolve the problem.
Kenmore dryers come equipped with door switches. If the door is not closed entirely, the dryer will not start its cycle. If the other indicators seem in working order and the door is properly shut, the door switch may be faulty. On some models of Kenmore dryers, there is a warning light to indicate if the door is open. If the "Door Open" light is still lit when you have closed it and heard it click, you should look into replacing the door switch.
Another possibility is the thermal fuse. This fuse is usually found in the back panel near the exhaust duct. If the dryer overheats, the thermal fuse will blow, shutting down operation of the dryer until the fuse is replaced.
Check the wiring from the outlet. If you have recently had to convert from a four-prong wire to a three-prong wire, or vice versa, the connections to the dryer may be faulty. Make sure that the red and black wires are connected to the proper hot terminals, the green wire to a ground and, if present, a white wire to the neutral connection.
Thanks and have a nice day.
Jul 04, 2011 | Kenmore Elite HE4 Electric Dryer
Opener works fine buti have to hold button down until door shuts compltly no remote but door bell style button going into house thanks
Check your door sensors to make sure they are properly pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit. If you can't get both lights to come on you have bad sensors.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
GE JGBP80 oven shuts off and the locked door light flashes
That's awesome! I just found this site on Christmas day minutes away from family arriving and I had exhausted the manual for help. Under the troubleshooting section of the manual it lists "door Locked" light blinking as a problem with the only solution being - "shut the door." With three dishes in the oven that didn't help!
I took the advice of the site and wiggled the actual door lock on the inside of the oven and that didn't work right away either.
I had to trick the oven into thinking the door was shut by pressing the sensor on the right hand side in and then turn on the oven cleaning cycle with the sensor held down. After the lock activated and moved across with the door open, I had to hold down the door unlock feature and wiggle the lock as it unlocked. A little more complicated, but none the less it worked!
It must be a sensor inside the locking mechanism that isn't reading the lock being open - or something...
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Vulcan EV12-2FP-240 Expando Range Logo
77 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Paul Carew
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
