Question about Vehicle Parts & Accessories
A/C Re-Chargeing Suzuki SX-4
When recharging the unit what is the max pressure for the high side.
    New Friend:
Your charging tool should have a gauge on it that shows proper PSI for low and high sides, but only put refrigerant in the low side. Trying to put it in the high side will likely cause the cylinder to burst.
Posted on Apr 16, 2014
Testimonial: "I have guages, but is'nt each veh. high pressure differnt? I just wanted to be sure as I was putting the freon in on the low pressure side to be able to watch the high side."
Need to refill my a/c 2002 durango
The only smart solution is to take it to a certified AC Technician. There has to be a leak in the system and adding a can or two of 134A is at best, just a waste and at the worst could cause serious injury or even death, if the chargeing hose is connected to the high pressure side and the engine is started. It is cheaper in the long run to have a tech with the proper equipment solve your problem.
Jul 02, 2012 | 2002 Dodge Durango
Where located fuel sensor Suzuki Ario 2003
Component location diagrams for most 2003 Suzuki Aerio cars and light trucks sold in the U.S. from 1990+.
clsk2003aeri003.gifIgnition System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
Components on diagram:
  • TP Sensor
  • Ignition Coil
  • ECM
  • MAF Sensor
  • CMP Sensor
  • clsk2003aeri007.gifElectronic Shift Control System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Data Link Connector
  • Transmission Range Sensor
  • Throttle Position Sensor
  • Pressure Control Solenoid Valve
  • Battery
  • clsk2003aeri010.gifInstrument Panel For Connector Layout Diagram Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Clutch Switch
  • Thermistor
  • Brake Light Switch
  • Blower Motor Relay
  • Heater Fan Motor
  • clsk2003aeri011.gifInstrument Panel Harness Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Wiper Switch
  • Washer Switch
  • Turn Signal Relay
  • Radio
  • clsk2003aeri015.gifHeadlight System Location Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Headlight Relay
  • Headlight
  • Clearance Light
  • Headlight Diode
  • Clearance Light Relay
  • clsk2003aeri022.gifFuel System Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Fuel Pump Relay
  • Fuel Tank Pressure Sensor
  • EVAP Canister
  • Fuel Tank Pressure Control Valve
  • Fuel Filler Cap
  • clsk2003aeri027.gifFloor For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Wheel Speed Sensor
  • ABS Control Module
  • G Sensor
  • Air Bag Control Module
  • EVAP Canister Vent Valve
  • clsk2003aeri030.gifInstrument Panel For Ground Point Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Instrument Panel Ground Points
  • clsk2003aeri036.gifEngine Compartment For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Horn Relay
  • Radiator Fan Control Relay
  • Cruise Control Module
  • Condenser Fan Relay
  • clsk2003aeri037.gifEngine Compartment Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • MAP Sensor
  • Knock Sensor
  • Noise Suppressor
  • Heated Oxygen Sensor
  • Sep 18, 2011 | 2003 Suzuki Aerio
    My 1988 Oldsmobile Toronado's AC unit was fixed to allow for the new, safe refrigerant, but when I attempt to recharge it myself, the pressure gauge tells me that the pressure is already too high. So...
    The gauge must be connected to the low side and the A/C should be on max. The can should remain upright so the freon goes in as a gas and not a liquid.
    Jul 29, 2011 | 1988 Oldsmobile Toronado
    Chargeing Unit
    The old 410A fittings are different than the r-22 fittings. There are adapters available on ebay. Remember 410A runs at higher pressures than 22. Be sure to use gauges for 410A! Use the right gauges with the right hoses! High pressure.. Use the right gauges and the right hoses!
    Jul 30, 2010 | AmcorAire UCHW-H18AF2 Split System Air...
    Need to recharge 2003 chevy malibu air conditioner. where do i find the intake to recharge it.
    under the hood there is two a/c valves, one says H for high side and one says L for low side... hook up to the low side and turn the a/c on max with the car running and then charge. you really need a pressure gauge to know how much to put in. too much freon will make it blow hot also, you need the right amount of pressures, just go slow filling it up and keep checking the a.c temp out of the vents.
    Jul 11, 2010 | 2003 Chevrolet Malibu
    Power Washer has no pressure, any ideas
    1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
    2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
    3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
    4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
    5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
    6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
    Order of troubleshooting
    1, 2, 5, 6, 4, then 3.
    Thanks for using FixYa!
    Kelly
    Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
    2003 Suzuki Aerio A/C problem
    one ,the big one is the high pressure side, dont mess with it. you want to fill on the low pressure side. its the small connection port, usually colored blue on the cap.
    Aug 11, 2009 | 2003 Suzuki Aerio
    How to recharge A/C unit
    with a 134a type system the do it yourself kit comes with a recharge hose ( it normally will only fit the low pressure side ) the low side is the line running from the compressor to the firewall,it may have a blue cap on it,the high side runs from the comoressor to the front of the car and through the condenser back to the firewall,it may have a red cap on it.
    Apr 28, 2009 | 1999 Saturn SL
    Vehicle Parts & Accessories Logo
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
