Question about 3Com NBX 3102 IP Phone
Speaker and microphone is not working - 3Com NBX 3102 IP Phone
Hello, I have model no ICBM-2x12BT speaker with microphone. I can't seem to get microphone to work. When I turn microphone I can hear the speaker transition to microphone but microphone does not work.
Might the driver software was not properly installed. Or the settings of your audio and mic has something to do with it. Or try to goo to device manager, look for the specific device, then try to disable and then enable it back.
Apr 04, 2017 | The Computers & Internet
Tip
How to play computer sounds through microphone
<p>There may, of course, sounds from a microphone, because there is a speaker, but you can use sounds from a microphone or something speakers connected to the microphone system is played. Computer games, but might sound a bit complicated because they usually lead to loud sounds into the microphone to a number set. <br /> <p><br /> <p>1. Find the computer that you want to play sound. Go to Control Panel and click on "Hardware and Sound." Under "Sound" in "Changing the system sounds." You can access various Windows sounds by selecting them and clicking "Test". <br /> <p><br /> <p>2. External speakers to the sound card or audio output on a laptop. With active speakers is recommended, the stronger the better. Set the microphone in front of the speaker. <br /> <p><br /> <p>3. Connect the microphone and play the sound from computer speakers. That should pass the microphone for recording or performing live. <br />
on Jun 22, 2011 | Audio Players & Recorders
Internal microphone
Usually the speakers on the laptop would act as a microphone- go into speaker properties, enable microphone and see it reacts. Bar that, you could go with the usb or bluetooth microphone route (I use the same headset for my phone as a microphone for my pc)
Sep 22, 2012 | Computers & Internet
I have a Fender Passport 150 and my microphone is won't work but everything else does......????? Thanx Mike
Mike try the microphone if possible on another set If the mike makes a noise check for frayed and bad cables. As far as I know the mike is a dynamic mike and connect it to the speaker of a small transistor radio and it should sound.like a small speaker for dynamic mikes and ordinary speakers work just the one as a generating device(Speaker) and the other as a sound pick up Look at small to way radio's the send is the speaker a mike and on receive it is a speaker, Hope this help
Nov 14, 2010 | Lectrosonics FENDER PASSPORT PD-150 + 1...
Hello, i cant hear the microphone over the speaker
Make sure your microphone is not muted in the control panel, under sounds.
Nov 20, 2009 | Gateway Computers & Internet
Feedback sound
If moving the microphone doesn't work then suspect "microphonics" where a loose electronics component is vibrating and acting as a microphone. Could be cable. Unplug all microphone cables, still feedback? Right click speaker icon, sound properties, temporarily disable computer sound input devices. If still feedback then analog section of sound card (or motherboard sound chip) or your speaker system.
Oct 15, 2009 | Altec Lansing Multimedia Computer Speakers
Backpanel socket for microphone is not recognised. Speaker socket is alright.
in order to hear sound on the microphone you need to check the Mixer settings as the default setting for microphone (for playback) is mute as you would get some horrible feedback..
double click on the speaker icon in the bottom left and chose properties from the options menu you may (or may not) have the option to select microphone for playback, however there should be a setting for recording which should give you a slider to set the recording levels for the microphone, use sound recorder or other recording software to test microphone is working
Apr 13, 2009 | Intel Motherboard
Microphone volume low on sciphone i68
I found a solution but not a final one, during the call turn on the hand's free speaker and the microphone will work fine, you can set the hadsfree speaker to the minimal output so you can use it as the regular ear speaker and the microphone will continue to work well.
Dec 08, 2008 | Cell Phones
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
3Com NBX 3102 IP Phone Logo
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
