Question about Health & Beauty
I have a ewheel E36 red mobility scooter the lights and horn work but motor won't turn could it be a fuse or a loose wire plz help me to resolve this problem thank u
    Top Expert:
  • Health & Beauty Master
  • 45,297 Answers
Not sure it will help you but I just fixed a cosco scooter this morning with contact cleaner .took the control panel top off and sprayed the cleaner lubricant on all the wire connectersand the speed reostatunder the top .Hope it helps you . used radioshack cleaner/lub
Posted on Jul 11, 2014
SOURCE: Need a wiring diagram for Pride Rally Electric Scooter
I can tell you how i fixed it for $19.95
Posted on Jun 22, 2009
  • 175 Answers
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Posted on Jul 12, 2009
  • 103 Answers
SOURCE: HAVE PUT SCOOTER TOGETHER AND CHARGED BUT IT
Make sure the scooter is not in freewheel.
Posted on Jul 23, 2009
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
Posted on Jun 05, 2010
2013 EW36 ewheel scooter. Why doesn't it start?
I think the the fuse is under the head light cowling glass type 25 amp fuse. Your throttle, motor wiring, or controller maybe causing this problem.
Oct 24, 2015 | Electric Wheels Ew36 Mobility Scooter Red
Hi I have a Rascal 230 Mobility Scooter and it just stopped running I get juice to the the area where the horn is but I get no power anyone have suggions plz help thank u
hi, well normally the controller out put goes ,however you must first check the brushes located in the motor are okay and any other loose connections... I can repair those from £20...
Regards
Rob
Jul 31, 2015 | Health & Beauty
I have a Taotao electric scooter not a mobility scooter the scooter is fully charged the lights and horn work fine but when you turn the throttle nothing happens it makes a kind of clicking sound
Not familiar with your particular scooter - but I am well versed with electricity. The issue you're seeing is likely a result of a poor connection somewhere. The amount of power (current in amps) required to operate the horn or lights is a small fraction of that needed to run the motor.
You should trace larger sized wires/cables from the motor back as far as you can - ideally to the battery if possible. Remove, thoroughly clean and reconnect each of these cables under each terminal screw - one at a time. This way you'll know any unconnected cable goes on the only terminal that is removed.
At this point, you should have 100% good connections for all high current loads - including the motor and will probably be able to use the scooter. Placing the battery on a slow trickle charger overnight will help ensure that the battery is fully charged - not just enough to operate the horn or lights.
May 11, 2015 | Electric Health & Beauty
Bought a new ewheel e36 discovered today there is no way to load it with lift. Looks as if in design they failed to remember that a lot of us with disabilty drive trucks and need a way to load our mob
The majority of lifts they have for scooters involve a flat ramp that mounts off the back of your truck. There are crane types but you said it doesn't have lift points; I imagine you could build some type of sling that you can put around it to lift it. Use a material like heavy seatbelt webbing.
Here are a few of the places that have the ramp style: Bruno Scooter Lifts Mobility Products United Access Harmar AL 050 Micro Power Chair Lift Lift Go
Feb 16, 2015 | Electric Wheels E-Wheels E-36 Three Wheel...
I have a ewheel E36 red mobility scooter the moter won't but the light snd horn work can u help me to resolve this prohlem than yiu
I know some of the Electric Chairs have a way to disengage the motor from the wheels, make sure this has no happened to you.
Apr 16, 2014 | Health & Beauty
Mobility scooter - Electrics work, but won't go
hi, they are a nice scooter so let's get it working ,
First check that the freewheel lever is disengaged, in drive mode.
Do you hear a click when pressing the lever to go forward or backwards?
What can happen is the brake located on the side of the motor can seize,,,
Please keep me updated
Regards
Jan 04, 2013 | Electric Mobility Mobility Electric Power...
Electrical fault
Sounds like a problem with the circuit board under the speed pot,
It could be a loose connection and remember there can be a fuse under there.
Regards
Gewiz
Sep 26, 2009 | Pride New Mobility Legend 4 Wheel Scooter
4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Jul 13, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Health & Beauty Logo
62 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
