Question about Bowflex TreadClimber TC10
Tc10 tread climber drive belt - Bowflex TreadClimber TC10
5 Suggested Answers
bugoy31
  • 1238 Answers
SOURCE: Assembled Bowflex Tread climber yesterday. Getting
Good day!
What is the model # of your Bowflex?
Posted on May 22, 2011
ercupa190
  • 12223 Answers
SOURCE: MY TREAD CLIMBER STARTS THEN STOPS AND FLASHES E1
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Watch this videos and tip.
You must concluded if the inclination motor is faulty or Main Motor Controller Board is faulty.
Posted on Nov 22, 2011
ercupa190
  • 12223 Answers
SOURCE: tread climer tc10 showing h05 code and it won't turn on
you must call the bowflex, because they have bad design for this board. They will exchange by new one. Do it.
God bless you
Posted on Jun 09, 2012
ercupa190
  • 12223 Answers
SOURCE: the display on my tc3500 bowflex tread climber stopped working
adjust the REED swithc see the diagram , clean it, and tight the connector very well.
2) Tight the ribbon cable inside, clean it, for keypads operations.
God bless you see the b. diagram attached.
Posted on Nov 26, 2012
How to correct Tread climber TC5500 error code NIPP COMM (Belt Shut Down).
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Oct 02, 2016 | Bowflex TreadClimber TC5500
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
HOW TO CHANGE MY TREADCLIMBER TC10 WALKING BELTS
Bowflex has a service manual for the TC10 that includes walking belt replacement instructions, If you call customer service they should be able to email the whole manual or just the belt replacement steps.
May 07, 2013 | Bowflex TC1000 Treadclimber
Slippery treads
see the video and fix it. God bless you
Feb 08, 2013 | Bowflex TreadClimber TC10
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
Tread climer tc10 showing h05 code and it won't turn on
God bless you
Jun 08, 2012 | Bowflex Treadclimber
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.
May 22, 2010 | Bowflex Treadclimber
Bowflex TreadClimber TC10 Logo
51 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
