Question about Black & Decker Bread Machine
Pan B6000C break
The metal bit that one of the paddles attaches to has come lose. Can i replace the pan or reattach this part somehow?
Noggin
  • 944 Answers
SOURCE: Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Posted on Apr 20, 2007
SOURCE: I have a problem with uneven shaped loaves
I can't get my dough to rise all the way. I can't figure out what is wrong. Ive tried differt yeast,flour,made sure the water is the right temp. and the rest of the ingredients. Maybe my machine isn't working right please email me with some solutions
Posted on Jan 29, 2008
SOURCE: Paddles stick to posts & tear big chunks out of bread
Try some hard crisco on the post before putting in the paddle or any ingredients. Your paddle SHOULD COME OUT with your loaf. Then when it has cooled off some, you turn it on it's side and surgically remove the ****** from the bottom center. Try to remember the shape(of the paddle) you need to excise for your loaf. Have you ever noticed that most kitchen machines are designed by men?? As with floors that are horrible to try to clean. The big belief is that all companies have test kitchens.. not so. And we my dear must deal with items that do not function as one would logically think they should. I hope you give the company an earfull of customer feedback. Mine is an OSTER. Five 1/2 years and doing fine even with whole wheat, and desert pastry.
Posted on Nov 21, 2008
KMusselmann
  • 247 Answers
SOURCE: Looking for Mixing pan and paddle for B&D B1561
Try this site. Hope it helps you
Kurt
http://www.breadmachinedigest.com/beginners/manufacturers-parts.php
Posted on Apr 09, 2009
  • 433 Answers
SOURCE: I have the Black and Decker All-In-One Deluxe
There is a sealed bearing in the bottom of the bread pan. The paddle sits on the sealed bearing shaft. Over time the bearing begins to fail and the paddle does not turn freely or it may even freeze up. If you are sure everything is installed correctly this may be the problem. See if the paddle moves freely by hand and is not really loose. Sealed bearings can not be replaced. Eventually you will need a new bread pan. Sorry Hank
Posted on Apr 22, 2010
Piece that connects to motor and then paddle fell out
Yes, the C-clip holds the shaft for the paddle in place. I think the only relevant replacement part is the entire pan. Expensive!
Dave Kristol
Mar 23, 2017 | Breadman TR2500BC Bread Maker
Paddle axle fell out the bottom on the pan while washing.
I looked through the manual for this unit and you need a more comprehensive parts drawing showing the drive details. They do not have this kind of detail on line, my advice is to contact them directly by phone.
http://cart.russellhobbs.com/consumer-services/warranty.aspx?sid=BreadmanUS
Nov 10, 2013 | Breadman TR2200C Ultimate Bread Maker
I just bought a new B6000C bread maker. I have not used it yet. The instructions say "push the paddle down firmly onto the shaft to secure in place". But, my paddles just sit loosely on the...
No, there is nothing wrong with your bread maker. The paddle is supposed to be somewhat loose so you can remove it after baking for cleaning. Don't worry your paddle and breadmaker are fine.
Jul 26, 2011 | Black & Decker B2000 Bread Maker
My paddle on the removable basket is rusted and will not move/rotate. Is there a way to loosen it up so I can use the machine again? Thanks!
Hello finkm! here is how you do it if soaking hasn't worked:I have attached a short video clip of what to do if soaking hasn't worked. The video is of a pan and paddle that was so badly stuck ( I bought it used at a second hand store) that a week of soaking did nothing to free it up. What you need to do this is a strong shoelace or piece of string about 3 ft. long, 2 hot pads places on the edges of the pan to protect your fingers,& 2 empty milk jugs filled with water. Tie one end of the string around the post the paddle sits on in the little space between the bottom of the paddle and the pan. Loop the other end of the string through the handles of the jugs short enough so that when you turn the pan upside down the jugs hang about a foot off the ground. Bend your knees a little so you in a position kind of like a short stop in baseball. Then lift and drop the pan about 4 to 6 inches so the jugs kind of POP the string. You can hear the seal of the baked on gunk breaking it seal on the first pop and then the paddle comes flying free with the second pop....Let me know if this works for you and if so give me a thumbs up on you tube and a testimonial on fixya. Glad to be of help!
Oct 25, 2010 | Welbilt Kitchen Appliances - Others
I am getting bits of pieces of silver flaky looking stuff in my bread dough. What is this - stuff from the paddle? The machine is making a high squealing noise?
That is probably the nonstick coating coming off the paddle or your breadpan or both. Are there scratches in your pans or paddles surface where you can see the metal under the non-stick coating? If yes, that is probably what you are seeing in your bread. I would tell you to try to get a new pan and paddle if they are scratched, but if your machine is squealing too then you should try to get a new or good used machine as you would end up spending more on the pan and paddle plus repairs to end the squealing, so you should just replace your whole machine. I have some models that are like new if you are interested in buying one. I would have to go through ebay and sell the almost new/new ones for $40.00 including shipping if you are east of the Mississippi. If you shop on ebay you can get one from me or of course others sell them there too.
Oct 20, 2010 | Breadman TR2200C Ultimate Bread Maker
How to replace an oil pan on 1991 honda accord
  • Get under the car and locate the oil pan near the front of the vehicle . Put a drain pan within easy reach. Use a socket wrench to remove the nut that holds the oil pan to the car. Hold the pan with your other hand so it won't drop when the nut is removed.
  • Slide the drain pan quickly under the oil pan to catch the old oil. Drain as much as possible.
  • Remove the old oil pan gasket very carefully with a thin paint scraper, and then wipe the surface with engine cleaner or solvent.
  • Rub a bit of oil on the sealing surface to promote adhesion, and attach the new gasket securely. Reattach the oil pan to the car with the bolt.
  • Pour fresh oil into the crankcase. Honda Accord cars will require between 5 and 6 qt., so fill it until the crankcase looks full, and then check it with the dipstick to be sure, adding more if necessary. Back the car off the ramps.
  • Put the old oil in a used milk carton and attach the lid securely. Take the oil to a hazardous materials disposal facility, or to a garage.
  • Aug 23, 2010 | 1991 Honda Accord
    New Bread Maker, pan will not come out
    The metal clips in my bread machine are just to hold it steady. You should pull the pan straight up.
    When I take the loaf out of the pan after it has baked, I take the pan out and then set it on its side and wiggle the the thing on the bottom that makes the paddle turn loosen the paddle. Then I tip the pan over and holding the pan by the bottom and the handle, I dump the loaf out onto a kitchen towel to allow the bread to cool. It is recommended to allow the bread to cool for a few minutes for easier removal, but if the bread stays in the pan too long, it makes the crust soggy.
    Mar 16, 2010 | Oster 5838 ExpressBake Bread Maker
    The mixer blade won't mix. The motor runs but blade won't go.
    Take the pan out of the machine with the paddle attached and see if you can spin the paddle freely by hand. If you can that's great. If you can't then the paddle is stuck or the bearing is broken.
    Then, with the pan out of the machine start it up and look through the lid . Check to see if the shaft where the bread pan and paddle usually goes is spinning. If not then check to see if the drive belt inside the machine fell off or if it needs to be replaced.
    Hank
    Sep 14, 2009 | Oster Kitchen Appliances - Others
    The driveshaft falls out of the pan, even with paddle attached
    The shaft is pressed into a bearing that is molded and stamped in the bottom of the pan. This bearing is sealed and allows the shaft and paddle to spin freely. The rest of the parts on the other end of the shaft interact with the motor on your machine. They do wear out and can not be repaired because the worn parts are not available individually.
    Sorry to say there are no repairable parts, so it's time for a new bread pan. I don't know the brand of your machine so you can google or check ebay.
    Hank
    Sep 02, 2009 | West Bend 41052 Bread & Dough Maker
    Black & Decker Bread Machine Logo
    57 people viewed this question
    Top Black & Decker Kitchen Appliances - Others Experts
    Greg Cann
    Greg Cann
    Irene Tulloch
    Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
