Question about Garden
I have a yellowstone home and garden electric power washer APW-HA-1300A and am having a hard time finding the part that connects from the quick release from the machine that screws onto the water hose please help.
2 Suggested Answers
  • 1388 Answers
SOURCE: Had the Northstar 3000 psi Pressure Washer for 2
It is easy to check if your hose and quick connects are supplying enough water to the pump. Your pressure washer gallon per minuite requirements are printed on the machine and also on the pressure tips in GPM. Your post indicates 2.5 gpm but check your documentation of GPM. Next remove the tip from the wand and connect your hose with current quick connects to the machine. Start engine and direct the pressure wand into a bucket for exactly one minute. Measure the amount of water in the bucket, it should be very close to stated gallons. Do the same test with tip installed and compare measurement. If pump is starving for water you will not get proper amount of water in the bucket and the water hose will collapse. Two to four gallons of water per minute is not very demanding and should be delivered even with very small opening. You can even just direct the hose into the bucket for one minute and check how much water your hose is capable of delivering. I believe that you will find no problem with water delivery to pump. I would certainly enlighten Northern with your findings and question their evaluation. When you start using your pressure washer again try using it at lowest pressure to get the job done. Lowering the pressure to about 75% of max will increase the life of the pump and engine. Good luck with you pump
Posted on May 10, 2009
Why won't the hose connect to the washer?
The connection is made at the bottom of unit.
should be standard garden hose.
sometimes I find if I gently hold hose against connection point then rotate counterclockwise until I feel a click! then ( without lifting hose) rotate clockwise and hose should now be threaded onto power washer.
Oct 09, 2016 | Earthwise 1850 PSI Electric Pressure...
While driving doors lock and unlock, TC light, engine light and power steering light come on. Speedometer goes dead, transmission stuck in 2nd gear.
Gremlins , ha ha ha ! No, just kidding ! Boy that could be a tough one to find . Have you had it checked for DTC'S diagnostic trouble codes ! Checked for lose ground connections , all of these thing's may have a shared ground or power supply . Only thing you could do is get a wiring diagram for the circuits involved an do some electrical testing , power supply an grounds , you mite come across a lose connection some where . Have you taken it to a repair shop ? Electric Testing Techniques You Need to Know
Oct 02, 2015 | 2006 Chevrolet HHR
I have a Yellow Stone APW-150a pressure washer bought in 2005. The hose is cracked at the fitting that attaches to the washer. Can it be replaced or repaired?
Though I have never heard of Yellowstone appliances, I am pretty sure there is a way to get replacement parts from the company spare parts department or from other sources who sell these pressure washers. If not, try the Internet, or try the Speed shops where they sell these to people who pressure wash their cars/trucks. I am also sure there are other hoses not necessarily for the Yellowstone brand but fit perfectly well on them. Find out where they sell other brands and take your washer to them, ask them if they can sell you a hose with the right connectors to fit your washer. No salesperson can refuse to sell you a good bargain.
Jan 30, 2015 | Garden
My 97 isuzu rodeo when push for washer fluid doesnt spray
If the pump is making noise when you press the washer-fluid button then it is probably a hose issue. Open the hood of your car and have someone press the button. If you can see where the fluid is spraying out, then you have found the disconnected hose. It should not have fallen too far away from where it is supposed to be connected, so it should not be too hard to reconnect it.
If your washer fluid pump is not making noise when you press the button, then check the pump. If there are no loose electrical connections, then the pump it probably dead. Replace the pump and you will be fine. If you notice a burned looking wire near the pump, then you should be able to replace the wire and be OK -- but this usually indicates that there is a bigger problem at hand (wires usually don't just burn out for no reason).
I know this one is going to sound silly ... but have you made sure the washer fluid level is full? If your tank is empty, it won't spray. Double check this before you spend any money on anything else -- sometimes the washer-fluid tank will crack and leak, so even if you fill it, it will be empty again by the time you go to use it again (it once took me a month to find out that this was the problem in one of my old cars ... ha ha ha ... I felt really silly)
Most likely it is just a hose. Most auto makers use a friction connection for these hoses since it won't kill anyone if it pops off. If you find that this IS the problem, I recommend using a zip-tie to secure the hose where it is supposed to be so you don't have to deal with the same problem repeatedly.
May 27, 2011 | 1997 Isuzu Rodeo
Bobo tayo diba ha ha ha
Tito Latoya Germaine
Chilly Willy Milli Vanilli
Nov 11, 2009 | APW Wyott Mr. Frank Hot Dog Broiler & Bun...
Where do I find garden hose attachment
You can find garden hose attachments at a lot of different places. Your local hardware store ought to have a variety of attachments to choose from. Many stores like lowes and home depot carry things like this in the garden center. When to Plant Garden
Jun 07, 2009 | McCulloch FH180A Electric Pressure Washer
Had the Northstar 3000 psi Pressure Washer for 2 months and it started leaking oil from the pump during use. Took it to Northern and they are replacing the pump under warranty but said it was likely...
May 08, 2009 | Northstar Pressure Washer 3000 PSI
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
