Question about Dishwashers
Matsui dishwasher The water is still in the machine when program is finished.
    Problem Solver:
  • 16 Answers
Probably a clogged drain line going to bottom of your sink.
Posted on Apr 17, 2014
skrbin
  • 121 Answers
SOURCE: Water left in bottom of machine when cycle finished.
you must check filter,it is full of dirt.
it must be on front side,down left or right corner,
Posted on May 22, 2009
SOURCE: Matsui MF145 beeping continuously
You might want to check the salt and rinse levels on your dishwasher.
Ours was doing the exact same thing and we refilled the dishwasher salt and it worked again. Unscrew the plastic thing on the bottom of the dishwasher and fill it up with about 1 kilo of dishwasher salt, water will flow out when you do this and you can put at least 2 kilos in.
Hope that helps xxx
Posted on Oct 19, 2009
  • 25 Answers
SOURCE: matsui mf160 dishwasher salt indicator will no go out
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
AcmeUK
Posted on Dec 05, 2009
pjhislay1
  • 822 Answers
SOURCE: my dishwasher is working good
if pump is working .......... then blockage in pipe work....or drain.............
cheers
Posted on Mar 27, 2011
  • 36 Answers
SOURCE: Siemens Dishwasher flooded. Now it doesn't take in any water and does not finish program. Aquastop filter?
Typically all dishwashers have a maximum full switch that is located on the bottom of the inside of the washer, on some it looks like a round plastic cap about two to three inches round, if you grab it it will move up and down as much as a half inch, this is a float that when the water level is at the maximum will turn off the water inlet solenoid, I have had something small (in my case a small lid) get under this float holding it in the up position so it would not allow the washer to fill with water, after removing the lid the float went back to the correct position and everything worked fine. I would say this is happening to you by what you say has happened.
Posted on Nov 13, 2013
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Matsui dishwasher mf2w/a not heating
If your Matsui MF2W/A timer stops earlier in its cycle, turn off the water and unplug the machine.
Pull it out and put it on its back. Remove the base panel. Remove the anti-flooding interlock. Unplug the two cables feeding the heater element and check its resistance. Should be 30 ohm or thereabouts. If not the heater's defective and you should replace it.
Pull the cables off each of the two thermostats and check resistance. It should be in the order of .5 ohm or less. If the reading is high then replace.
Remember there are two thermostats fixed to the dishwasher pan. One at the right back lower, and one at the left back lower. For the left hand one you may find it easier to access by removing the lefthand dishwasher panel.
And that's about it. Job done.
Apr 06, 2012 | Dishwashers
How do I reset my Matsui dishwasher
The only reset there is on this machine is to unplug it for 5 minutes, if that doesn't correct whatever is wrong then it is not a reset problem with the run program.
Sep 26, 2011 | Dishwashers
Matsui MF160 door tension is still strong after adjustment. Program cycle takes 150mins
Time consumption depends on the cycle chosen. For a full complete wash 150 mts is ok.
Also check whether water flow to your machine is free from clogging! Check the strainer attched to the water whose connecting junction.
May 19, 2010 | Dishwashers
Matsui mf160 starts its wash cycle and timer stops
on most machines, the timer will not run if the water is not up to temp. if the inside is plenty hot mid-cycle, then your heating element is probably good. it is the thermometer that needs located and checked. if the inside is not steamy, then your heating element is the most likely culprit.
don't hate your dishwasher. it just wants to make sure that you get a full wash cycle at a hot enough temp. to get the dishes clean. good luck
Jul 06, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
Matsui mf160 dishwasher salt indicator will no go out
AcmeUK
Apr 20, 2009 | Dishwashers
I have a Matsui MS160SLI dishwasher it keeps on draining and will not fill with water. I have tried everything in the manual but nothing works. Help.
If the cycle does not stop draining that is usually because of a faulty water level switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Check if the floating sensor is stuck or faulty.
Some machine may use a membrane switch instead of a floater.
Apr 13, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
Matsui dishwasher wont fill up with water
check your inlet filter at the tap source and behind the machine where the filler pipe enters. They changed some pipes in our street and fine sand filled our micro filters to the dishwasher.
Jan 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Matsui dishwasher mf160
I used the solution I found for a slightly different fault, ( this was the same fault but without the bleebs)
switch off mains and turn off water. Then disconnect water pipe and lay machine on it's back. Switch on electrics, and allow water to run out. Switch off electrics and stand machine up .Reconnect everything and hey presto I can hear two good things, the machine gently humming, and my wife telling me what a genius I am !!
Aug 05, 2008 | Electronics - Others
Hope that helps xxx
Apr 02, 2008 | Dishwashers
Dishwashers Logo
135 people viewed this question
Top Dishwashers Experts
