Question about Health & Beauty
I have a ewheel E36 red mobility scooter the moter won't but the light snd horn work can u help me to resolve this prohlem than yiu
    Problem Solver:
  • 15 Answers
I know some of the Electric Chairs have a way to disengage the motor from the wheels, make sure this has no happened to you.
Posted on Apr 16, 2014
  • 313 Answers
SOURCE: Batteries are fully charged with the lights in
Remove the seat and the plastic cover over the batteries. look at the lights in the cover or at the back of the scooter an see if they are plugged in. It is a common fault of when working on the scooter to forget to plug the lights back in on assembly. Hope thats what it is.
Posted on Aug 12, 2010
petraman7
  • 1175 Answers
SOURCE: fix mobilty scooter
This scooter should NOT work with the charger plugged in
Unplug and try
Posted on Apr 23, 2010
gewiz
  • 1271 Answers
SOURCE: rover three wheel mobility scooter full charge
First of all,
Make sure the freewheel lever is unengaged (up or down ?) , this can be tested by pushing the scooter forward , you should hear gearbox clunk,(Freewheel not engaged) Not all scooters sound a alarm when freewheel is engaged.
is the power indicator working okay,
Does the Wig Wam move freely, the thumb throttle part,
Check under the seat to make sure you have not blown or tripped the fuse, if it's a switch simply pressing the button will sort it, if not check the two prong fuse ,
you may also have some reset buttons on the stem so look out for them.
Now let me what you tried
Regards
GeWiz.
Posted on Jul 24, 2009
  • 692 Answers
SOURCE: I have an electric mobility
Barb the flashes indicate a brake problem. Make sure that you aren't in freewheel. Move the freewheel lever located at the rear of your scooter up and down a few times then put it in drive mode and turn the scooter on and see if you still get 5 flashes If so you will have to replace the brake assembly Hope this helps
Posted on Oct 21, 2010
gfreed100
  • 60 Answers
SOURCE: my scooter won't move! i turn the key, plenty of battery power, all lights, horn etc working but will not move forwards or backwards, when i pull the controls all i get is a beep. any thoughts?
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. Your scooter is dropping into a fail safe mode and is telling you this by beeping. Most scooters have a service light on the tiller head that will flash out the failure code of the failure detected. Does your beep a number of times pause then beep this same pattern. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually foes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people do it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Posted on Jul 30, 2012
I need the repair and lubrication manual for the ew 36 mobility scooter can't seem to find anywhere
Hi. www.monsterscooterparts.com sell parts for you're..... EW-36 they might be able to help. 800-798-0325 cheers
Jan 23, 2018 | The Health & Beauty
TGA supersport mobility trike service manual
Hi go to. tgamobility.co.uk. There site has an enquiry page .good luck
Dec 10, 2016 | GoSouthernMD.com EWheels / GT3 Electric...
2013 EW36 ewheel scooter. Why doesn't it start?
I think the the fuse is under the head light cowling glass type 25 amp fuse. Your throttle, motor wiring, or controller maybe causing this problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Oct 24, 2015 | Electric Wheels Ew36 Mobility Scooter Red
Bought a new ewheel e36 discovered today there is no way to load it with lift. Looks as if in design they failed to remember that a lot of us with disabilty drive trucks and need a way to load our mob
The majority of lifts they have for scooters involve a flat ramp that mounts off the back of your truck. There are crane types but you said it doesn't have lift points; I imagine you could build some type of sling that you can put around it to lift it. Use a material like heavy seatbelt webbing.
Here are a few of the places that have the ramp style: Bruno Scooter Lifts Mobility Products United Access Harmar AL 050 Micro Power Chair Lift Lift Go
Feb 16, 2015 | Electric Wheels E-Wheels E-36 Three Wheel...
I have a ewheel E36 red mobility scooter the lights and horn work but motor won't turn could it be a fuse or a loose wire plz help me to resolve this problem thank u
not sure it will help you but I just fixed a cosco scooter this morning with contact cleaner .took the control panel top off and sprayed the cleaner lubricant on all the wire connectersand the speed reostatunder the top .Hope it helps you . used radioshack cleaner/lub
Apr 16, 2014 | Health & Beauty
Mobility scooter - Electrics work, but won't go
hi, they are a nice scooter so let's get it working ,
First check that the freewheel lever is disengaged, in drive mode.
Do you hear a click when pressing the lever to go forward or backwards?
What can happen is the brake located on the side of the motor can seize,,,
Please keep me updated
Regards
Jan 04, 2013 | Electric Mobility Mobility Electric Power...
Gogo elite pride scooter horn won't stop
Peggy I've just solved mine as well there was a touching wire on the horn! So try that. You have to take some screws off the front panel
Jan 21, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Wont go forwards or backwards
are you sure its in gear. the nob on the moter should be towards the front of the machine! Hope this helps
Mar 12, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
98 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
