Question about Kenmore Ovens
Kenmore 790-911 F10 code
Error code F10
    Champion:
  • Kenmore Expert
  • 323 Answers
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore oven error code f10
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
Kenmore stove- what does F10 mean?
Good morning Christine, F10 error code is runaway temp. You probably have a bad temp sensor that isn't sending the correct temperature to the control board. Should be able to remove from inside toe oven but you may need to access the back of the oven to get to the screws. Not the hardest job in the world but kind of a pain. Hope that helps.
Jan 27, 2018 | Kenmore Ovens
The letter and numbers f10 keeps appearing on my oven screen what does that mean?
0Hello,
The F10 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F10 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Sep 09, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
F10 error message oven 790.9612
Hello & Welcome to FixYa
Error code F10 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Kenmore Ovens
F10 Error just appeared on my Kenmore oven. Could you tell me what is that?
The F10 error code indicates a runaway temperature condition. If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor & control checked.
Feb 06, 2011 | Ovens
What is F10 error code
http://www.applianceblog.com/mainforums/sears-kenmore/11065-kenmore-range-f10-error.html
Hi this website above directly addresses your issue.
F10, is an Over temperature, usually a bad thermistor or similar, as related see above post. For ID & repair parts and all.
Nov 01, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore model 790.9621 electric stove error code F10. The oven heats up on bake (set at 400 degrees) then goes into f10 mode; and seems to be heating up more. Answer for problem??
it is the bake relay sticking--on the eletronic oven control board.i tried to buy the relays but,no luck.must buy the eoc board-great engineering
Jan 02, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
May 27, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F10 code
actually F-10 was not listed on the error code list,
do you see any other malfunctions in the display???
Mar 12, 2008 | Kenmore 41389 Electric Double Oven
F10 error code
Need model number please. It should be behind drawer on left or right.
Nov 22, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
75 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
