Question about Gateway Computers & Internet
Bad pool header - Gateway Computers & Internet
    Sergeant:
  • 258 Answers
Yeah, I hate when that happens. Did it hurt your head when that happened? The cement at the bottom of the pool can be a real head banger! Take some aspirin. That may ease the pain. And don't jump into the pool head first anymore!
Posted on Apr 17, 2014
Raypax 2100 pool heater will not stay lit?
dirty or bad flame sensor if wired 120 volt try reversing black and white wire
Sep 01, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My pool Heater is leaking
You will need to take the top off the heater to see exactly what is leaking. It could be something as simple as a header gasket, or as bad as holes in the heat exchanger.
Jul 22, 2011 | Hayward H-series Electronic Gas Pool...
Pentair Mastetemp Pool and Spa Heater will heat to about 91 or 92 degrees and thats it. We have it set at 102 but it stops at 92 at the most.. It fires up then quits, fires up then quits. What could be...
This could be a number of things. Most often it will be the internal by-pass. You find the assembly inside the water header, it controls water flow through the heater. When it goes bad it can open at a low temp and keep the water from going through the heater.
Also you will want to check the temp probe on the side of the header. If this is bad it will usually show up on the temp display though.
Nov 19, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
The header on a raypack heaater has been replaced due to rotting on old manifold. New one also leaks in same area. Whats up here? Bad header?
The header could be good while maybe the heat exchanger is warped. If this is the case it is due to abrupt temperature changes or a bad burn.
Might as well get a new heater if this is the case, but make sure to get to the root of the problem first so it does no happen again.
Aug 30, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heater will not heat to set temperature and board goes blank
bad temp sensor or transformer if voltage coming out after it goes out bad board if no voltage bad transformer
May 12, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Water drips around one of the headers but can't see a crack
it's likely you have either loose header bolts or a bad gasket.
Feb 01, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Is it difficult to change the governor in a raypack heater? I have the replacement (pool comp. confirmed old one was bad and ordered new one - company abandoned job - no other company wants to do work on...
It's not that hard if you can get the old plug out. This is located benith the water pipes and is a 2" plug. If you have a cast or bronze header (where the water pipes connect) It's simpley a matter of unscrewing with a pipe wrench and the thermal govenor just pulls out and slips in then put the plug back in. If you have a plastic header you unscrew the plug using a square shaft screwdriver or like pry bar, you can also use a large set of waterpump pliers most people won't have these on hand. The problem comes at this point the plastic will have a tendesy to stick to itself, meaning the threads will stick to the header and may stripp off when you unscrew the plug. If this happens you will need to replace the header. If your pool company abaonded the job this may be the case. If not you may want to take the whole header off and replace it from the back this is harder but safer. Good luck with your project.
Sep 26, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Hard to read lcd on controler
Please read the problem "Bad LCD = Bad PC Board...", which I meant to post as a reply to this problem...
Jun 11, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Hayward navigator model #925CS keeps tipping on it's side.
Mine did the exact same thing. It's the hose that connects to the navigator. Replace it!! Problem solved.
The Header Hose becomes brittle and won't bend properly which causes the Navigator to tip on the side or backwards.
My advise is to replace all the hoses. If the header hose is bad so are the rest of them.
Apr 01, 2009 | Hayward Navigator Pool Cleaner
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
