Question about Pool & Spa
Pump not cutting in - Pool & Spa
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 55 Answers
Try looking for apparent damage or burn marks any where. then unplug the pump(make sure it is disconnected from power) and take off the cover or any panels you can. Check the internals for burn marks as well. If there are no apparent issues you could always grab a multimeter and look up the pump schematics or troubleshooting paths online by googling the pump name and model number.
You could also try checking the switch or interface between the pump and the control board that initiates the pump for a loose connection or any weather related damage.
Posted on Apr 16, 2014
How much air should be in the bladder bag in a 36 gallon captive air tank
The air pressure in the tank should be two psi below your pump cut-on pressure (i.e. 18 psi with 20-40 psi pump cut-on/cut-off or 28 psi with 30-50 psi pump cut-on/cut-off).
Oct 03, 2017 | Plumbing
Location of fuel cutoff switch in a 2003 nissan 350z
There is no fuel cut off switch. The electric fuel pump only operates for a few seconds when the ignition is switched on and will only remain on when the engine has been started. If the engine is not started and the ignition is left on the computer will cut power to the pump.
If you want to cut all power to the fuel pump you have to remove the fuse for the pump or remove the relay that covers the power circuit to the fuel pump.
Jun 25, 2016 | 2003 Nissan 350Z
So where is the oil pressure cut off switch located on 95 caprice classic
Oil pressure cut off switch ? It doesn't cut anything off , it's purposes is if the fuel pump relay doesn't work ,when the engine reaches 40 psi oil pressure ,contacts close inside supplying voltage to the fuel pump . Watch this video on Fuel Pump Electrical Circuits Description and Operation from Paul Danner . He is an automotive instructor at Rosedale tech . Fuel Pump Electrical Circuits Description and Operation
Dec 05, 2015 | Cars & Trucks
How do I stop pump from running? Cistern connected pump does not seem to be pressurizing. Pump not cutting off, and getting hot.
Pump probably needs to be serviced. It probably pressurizes a tank and when that tank reaches a pressure the pump is turned off. But just guessing.
May 27, 2015 | Plumbing
What cable to cut for a kill swicht
The Safest cable to cut when installing an allarm or kill switch is the fuel pump because it doesn't hook directly to the computer like the ignition wires. It goes through a relay before going to the pump. You want to put your switch or alarm cut out relay on the wire coming from the fuel pump relay to the fuel pump.
Jan 26, 2015 | 1999 Toyota Tacoma PreRunner
02 buick lesabre starts up great cuts off after awhile or 5-8 seconds after driving. Replaced f/pump
check your fuel pump pressure sometimes after market parts are faulty
Apr 11, 2014 | Cars & Trucks
I had a water line bust. After fixing the leak, I lost water pressure. Someone tried to fix the problem and now we have little to no water flow. I have to pumps . The smaller pump that feeds the house is...
The nut on the larger spring in the pump pressure switch: Usually the larger nut in the pump pressure control switch adjusts the pump cut-on ("cut-in") AND pump cut-off pressures simultaneously. This is the left-hand spring (and nut) in our photo. That means that whatever the gap is between the cut-on pressure and the cut-off pressure, that gap is maintained, but the entire operating range of the pump is raised or lowered. Turning the large nut clockwise RAISES BOTH the cut-on and cut-off pressures. So turning the large nut clockwise shifts the whole operating pressure range of the pump UP to HIGHER pressures.
Conversely, turning the large nut counter-clockwise will lower the whole pump operating range. This is the simplest adjustment to make.
Photo (left) courtesy of a reader.
The nut atop the smaller spring in the pump pressure switch: this nut is used to narrow or widen the gap between the pump cut-on and pump cut-off pressures. This is the right-hand spring (and nut) in our photo).
Turning the small nut clockwise (tighter) will RAISE the CUT-OFF pressure, and vice versa, loosening or turning the nut counter-clockwise will lower the cut-off pressure. Watch out! If you loosen this nut too much you can set the cut-off pressure below the cut-on pressure and the pump will turn on and run forever (or until it burns up.)
Which nut to turn in the pump pressure switch control, and which direction to turn it, are usually visible on a label inside the pressure switch cover. Above we show photos of a common Square D water pump pressure control switch (Schneider Electric) and the label with pump control adjustment details. [Click to enlarge].
Here are Example Pump Pressure Switch Adjustment Instructions from Square -D Understanding how pump pressure control switches work and which way to turn which of the two nuts in the control can be confusing.
On a Square-D Pumptrol® 9013FSF-2 pump pressure switch, for example, Square D tells us that we
  • Turn the Range Nut #1 (the larger spring and nut) clockwise (to the right or "down") to raise [both] cut-on and cut-off pressures. This is "tightening the nut down" against the spring. ("Rightie-tightie, leftie-loosie" as Mara Gieseke says to her kids). Thanks to reader Rise for this clarification.
    In other words, adjusting the pressure on this spring shifts the whole operating range of the switch up or down, but keeps the difference between cut-in and cut-out the same, whatever it happens to be (typically it's about 20 psi from the factory.)
    If you want the pump to turn ON (cut-in) sooner
    , that is, at a higher water pressure, turn the nut clockwise or "tighter".
    If you want the water pump to turn ON (cut-in) later, that is, at a lower water pressure, turn the nut counterclockwise or "looser".
  • Turn the Differential Nut #2 (the smaller spring and nut) clockwise to raise the cut-out pressure.
    If you want the water pump to turn OFF (cut out or cut-off) at a higher water pressure, turn this nut clockwise or "tighter".
    If you want the water pump to turn OFF (cut out or cut-off) at a lower water pressure, turn this nut counter clockwise or "looser"
    Here is why the small nut is called the "Differential"
Keep reading at LINK
Nov 03, 2010 | Flotec TC2151 P2 Well Pump Pressure Switch
Where is the fuel or fuel pump cut off switch for
No cut off switch, It has a relay. The pump is in the tank
Apr 02, 2010 | 1992 Saturn SL2
I am trying to take the drain pump off of my washer and it seems to be stuck. how do i get it off?
the motor shaft is rusted causing the plastic pump to be stuck. you might have to cut thru the center of the pump with a chisel or flat screwdriver. once you get the pump off then you will have to grind the motor shaft down a little before installing a new pump. if the new pump doesnt just slide on and off easily then dont force it.
  • cut the center of the water pump where you see the red circle. cut all the way to the motor shaft.
Aug 08, 2008 | Whirlpool Washing Machines
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
