Question about Ronco Automatic Popeil Pasta Maker
Is there a spacer or bushing that goes between the faceplate and the sausage horn to keep it snug?
It does not tighten with either of the lock nuts I have.
I change the bushing kit for the shipper in my 93 Ford F 150 5 speed manual now and can't change gears
check the method that you used to install the bushes
could be that you missed a spacer block in a bushing and now the nut to assemble is tightening up to far and jamming the system
Nov 07, 2015 | Ford Cars & Trucks
On a 2002 ultra classic which rear axle spacer goes to which side thanks
hi Keith, the short spacer goes on the right brake disc side the long spacer goes on the left belt pulley side good luck and dont forget to tighten the axle nut to 65 ft lbs
Mar 21, 2015 | Harley Davidson Motorcycles
Adjust tension on wishbone rear
For a 2004 Softail - you never gave a model year.
1. Place rear fork (3) in the frame so that
the bores in the frame align with the bores in the fork.
Insert the bushings (10) into the spherical bearings (7)
from the inside.
2. Install pivot shaft.
a. Apply LOCTITE ANTI-SEIZE to pivot shaft (4).
b. From the right side, install pivot shaft and spacers
with spacer collars facing transmission case.
c. Apply LOCTITE THREADLOCKER 262 (red) to
threads of pivot shaft nut. Install and tighten pivot
shaft nut to 90-110 ft-lbs (122-149.1 Nm).
NOTE
Proper pivot shaft tightening is important to maintain rear fork
alignment.
3. Check for freedom of rotation of the rear fork around the
bearings and that the fork and frame side members have
not been distorted when the pivot shaft nut was tightened.
4. Install the canister (California models),
fender extension (2), brake caliper and rear wheel.
5. Install both rear shock absorbers (9) using bolts and
washers (8).
Aug 31, 2013 | Harley Davidson FLSTC Heritage Softail...
Bike fork parts
yes you do, the first part is the bearing race, it goes on 1st tighten it til it is snug (no play) and not too tight, the next 3 pieces are just spacers they go on next, then the last piece is the lock nut tighten it by hand until its snug then you need to hold the race with a wrench and tighten the lock nut (with another wrench) to lock it in place and you are all set to continue reassembling the handle bars... good luck
May 31, 2013 | Cycling
Why are the rear wheels locked up on my toddlers schwinn tricycle?
I took the fenders off to give a little more space for the wheels to move. Don't tighten the nut and washer right up against the black plastic spacer on the rim. Schwinn should be sending out locking spacers or nuts to fix the problem, but I don't see that happening.
Sep 23, 2012 | Pacific Cycle s Schwinn Roadster 12"...
I need a diagram of strut rod bushings for a 95 honda accord
sorry dont have a diagram here is a how to
  1. Disconnect the negative battery cable. If equipped with an air bag, properly disable the Supplemental Restraint System (SRS), as detailed in Chassis Electrical .
  2. Elevate and safely support the front of the car.
  3. Remove the wheel.
  4. Loosen the nut at the rear of the radius rod. Remove the nut, washers, bushing, etc. Keep them in the correct order for reinstallation.
  5. Remove the bolts securing the rod to the control arm. Remove the rod.
To install:
  1. Inspect the bushings carefully for wear or deformation. Replace them if any damage is found.
  2. Fit the rod into place and install the bolts at the control arm. Tighten the bolts to 40 ft. lbs. (55 Nm) on Accords through 1989 and Preludes through 1991. On 1990-95 Accords and 1992-95 Preludes, tighten the bolts to 76 ft. lbs. (105 Nm).
  3. Install the bushings, washers and spacers on the rod. Install a new locking nut. On all except 1992-95 Preludes, tighten the end nut to 33 ft. lbs. (44 Nm). On 1992-95 Preludes, tighten the nut to 40 ft. lbs. (55 Nm).
  4. Install the wheels and lower the vehicle.
  5. Properly enable the SRS system, if equipped, and connect the negative battery cable.
Jun 17, 2011 | Honda Accord Cars & Trucks
Change a bearing in 1983 ford f150 4 wheel drive
need special socket from parts store remove allen bolts from front alex, loose first axle nut. with neddle nose pliers pull out tab ring .then loosen second ring bearing will be next might have to wiggle wheel to get bearing to slid out. replace bearing snug first lock-nut against bearing keep track of lock nut with *** on it that one is first then {DON'T OVER TIGHTEN} then put ring with holes on next nake sure *** is in a hole, then tighten last lock ring watch how you take hub off make sure hubs are not locked in. after you are done with vech.in air lock hubs ane rotate tire to make sure front axel {drive shaft} turns . I use super blue wheel bearing. grease I pack my bearings every two years
Jun 05, 2011 | Ford F-150 Cars & Trucks
530 exc spacing between front fork & spacer
front axle installation: looking at the front of the bike:
slide the wheel into position and insert the axle from the left. with axle now through the right hand fork, install nut and tighten the left fork pinch bolts to secure the axle for tightening the nut. tighten the nut to 29.5 ftlbs. and loosen the left pinch bolts. now tighten the right pinch bolts and compress the front suspension while the left (from front) is still loose. now allow suspension to rest naturally and tighten all 4 pinch bolts to 11 ftlbs.
your done.......the axle is tighten against the rotor side and the other fork is then tighten in it's natural position so as not to cause premature seal and bushing failure and increasing stiction.
Sep 27, 2009 | 2008 KTM 530 EXC-R
Front brake rotor on 1992 Ford Ranger 4wd with auto lock in
With Automatic Locking Hubs
  1. Raise the vehicle and install safety stands.
  2. Remove the wheel lugnuts and the wheel and tire assembly.
  3. Remove the retainer washers from the lugnut studs. Remove the automatic locking hub assembly from the spindle.
  4. Remove the snap ring from the end of the spindle shaft.
  5. Remove the axle shaft spacer
  6. Being careful not to damage the plastic moving cam or thrust spacers, pull cam assembly off the wheel bearing adjusting nut and remove the two plastic thrust spacers from the adjusting nut. CAUTION: Do not pry on the plastic cam or thrust spacers during removal. Prying may damage the cam or spacers.
  7. Using a magnet, remove the locking key. NOTE: If required, rotate the adjusting nut slightly to relieve pressure against the locking key, before the key can be removed. CAUTION: To prevent damage to the spindle threads, look into the spindle keyway under the adjusting nut and remove the separate locking key before removing the adjusting nut.
  8. Loosen the wheel bearing adjusting nut from the spindle using a 2-3/8 inch Hex Locknut Wrench T70T-4252-B or equivalent.
  9. While rotating the hub and rotor assembly, tighten the wheel bearing adjusting nut to 47 Nm (35 ft lb) to seat the bearings. Spin the rotor and back off the nut one-quarter turn (90 degrees).
  10. Retighten the adjusting nut to 1.8 Nm (16 in lb) using a torque wrench.
  11. Align the closest lug in the wheel bearing adjusting nut with the center of the spindle keyway slot. Advance the nut to the next lug if required. Install the separate locking key in the spindle keyway under the adjusting nut. WARNING: Extreme care must be taken when aligning the spindle nut adjustment lug with the center of the spindle keyway slot to prevent damage to the separate locking key. The wheel and tire assembly may come off while the vehicle is in motion if the key is damaged.
  12. Install the two thrust spacers and push or press the cam assembly onto the locknut by lining up the key in the fixed cam with the spindle keyway. CAUTION: Extreme care must be taken when aligning the fixed cam key with the spindle keyway to prevent damage to the fixed cam.
  13. Install the axle shaft spacer.
  14. Clip the snap ring onto the end of the spindle shaft.
  15. Install the automatic locking hub assembly over the spindle by lining up the three hub assembly legs with three pockets in cam assembly. Install the retainer washers.
  16. Install the wheel and tire assembly. Install and tighten lugnuts to 135 Nm (100 ft lb).
  17. Make sure the final end play of the wheel on the spindle is 0.00-0.08 mm (0.000-0.003 inch). the maximum torque to rotate the hub is 2.8 Nm (25 in lb).
Jul 27, 2009 | 1992 Ford Ranger
10'' table saw binding?
Sounds like you lost a spacer that goes behind the first flange against the motor bearing, you could use a lock washer if you bend it flat.
Assemble:
spacer washer,
first flange,
blade,
second flange,
nut.
I think the first flange is rubbing the motor housing.
Apr 26, 2009 | Saws
Ronco Automatic Popeil Pasta Maker Logo
47 people viewed this question
Top Ronco Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
ray gallant
Are you a Ronco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
