Question about Panasonic Color Copier,printer,color Scanner,dpc213, Low Meter, Pass A Copy
How to change touch screen on panasonic dpc213
Need to change touch panel need info
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 55 Answers
Assuming you've got the replacement part it should be as easy as disassembling/removing the cover or any plastic panneling (most of the time its pop off) then slowly lift the screen which will be connected by a floating ribbon. Disconnect that ribbon and lift away screen. Reinstall new screen in reverse order.
The outer paneling is purely for protection and will either be screw-off or pop-off. The rest is making your way to the screen area and lifting it to access the data ribbon. ENSURE copier is not plugged in or on a battery while troubleshooting and do not touch any other circuitry without proper safety gear because any capacitors in the system will still have charge.
Posted on Apr 16, 2014
Turn off beep on 8060 savin copier
See page 76 from the Operation Instruction Manual:
ftp://ftp.panasonic.com/printer/om/dp-8060-copy_en_om.pdf
"The Key Operator Password is required before any changes can be made"
Screen No. Modes Function Initial Setting
03/13 11 TCH Panel Beep Sound
Beep sounds when touching the panel.
? Off, Soft, Loud Soft
Jul 01, 2014 | Acer Aspire 5810T-8060 Notebook
Changed touch panel on panasonic dpc213 now panel wont light up
recheck all of your connectors on the board/panel...i have had one that gave me fits once & it was due to a connector not being completely plugged in snug
Apr 23, 2014 | Panasonic DP-C213 Color Copier
Red shadow on my TH42PWD when showing white screens
You probably need to change the white balance, the control called Rgain or Red Gain but you have not given enough info to be sure.
How and from what source is it fed?
has it developed the fault or was it always like that?
How red is it and is it all over the screen?
do you mean the picture looks a bit "warm" or is it bright red?
Feb 16, 2011 | Panasonic TH-42PX60U Television
I loaded a microsoft intellimouse and it disabled the touch screen. I unloaded the mouse, and now it is saying I have no Touch Panel Driver...How do I fix this?
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001&catalogId=13401
Register with Panasonic at the link above in order to access driver downloads for your product. Download the touch panel drivers and install.
Jan 14, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
PANASONIC PT-46G40U CONVERGENCE PROBLEM HELP...
Have you checked the bias resistors for Exact Value. They normally change value when the stk's take a dive.
Dec 09, 2009 | Panasonic PT-46G40 46 in. Rear Projection...
HOW DO YOU CHANGE THE TOUCH SCREEN ON PANASONIC TOUGHBOOK
go to control panel and it should have a option about the touch screen
Nov 03, 2009 | Panasonic Toughbook CF-51 Notebook
The touch panel is black
There is connecting wire between lcd board and camcorder main board that seems broken, needs to be replaced.
Let me know model number of camcorder to find out part number info of flexible wire.
Thanks.
Sep 20, 2009 | Sony Handycam CCD-TRV318 Camcorder
Panasonic Viera Scratches help
The only supplier for parts is the Panasonic service rep and their parts distributors. To change the front panel transparent window is a fairly big job. In most models, the compete screen has to be removed.
You will find that the replacement window is fairly expensive. The labour would also be expensive because of the time involved.
What you should do is get it streight with your children to not touch the screen. Also, if they have allowance, you should cut if back by a fair amount for a long time to compensate for the damage.
Jerry G.
Nov 27, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Touch screen panel problem
You need to go to the control panel and recalibrate your touch screen.
Oct 07, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
PROBLEM WITH LANGUAGE
#Press the FUNCTION Key $Select the COPIER SETTINGS in Function Setting mode. (See page 36) %Touch the H key to advance to the 02/02 Display Screen of Copier Settings menu. &Touch the 09 KEY OPERATOR MODE key. (Enter the Key Operator’s ID Code and then press the OK key. )Follow the on screen instructions. *After setting, touch the OK key in Display Panel. +Press the RESET key, then exit the Function mode The screen to change the language is 01/05 option (04)
Mar 27, 2008 | Panasonic Workio DP-2500E Copier
Panasonic Color Copier,printer,color Scanner,dpc213, Low Meter, Pass A Copy Logo
82 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
