Question about GE Washing Machines
I HAVE A GE PROFILE WASHER AND SCREEN KEEPS SHUTTING OFF
4 Suggested Answers
  • 714 Answers
SOURCE: GE Profile washer...model: WPRE6150HOWT sesr:
i'd check the drain pump-there is a seal where it attaches to the motor-leaks often there, also could be a leak in your tub seal between the tub and transmission, also sometimes the outter plastic tub gets a crack in it and leaks
Posted on Feb 15, 2010
  • 256 Answers
SOURCE: Touch Screen on GE profile top load washer is not responding.
There is probably a problem with one of the following:
* electronic control board
* touchpad
Posted on Feb 25, 2010
  • 6277 Answers
SOURCE: GE Profile washer model# WPGT9350C0PL
Hi from retired Englishman in SW France
Here are my complete, pre-typed, general guidance notes for balance ;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 04, 2011
Shaking GE Profile Washer
level the machine and make sure the floor is sturdy, you can even put a piece of plyboard under it.
Feb 05, 2014 | GE Profile WPRE6100G Top Load Washer
What causes a ge profile washer top load not to shut off water and moreless has a mind of its own
not shutting of water is a common fault there is a problem with your water level indicating valve in most cases the pipe has a block or has a nick in it leaking air the last problem is normally the valve so check that the valves hoses are connected at both ends try blowing the pipe out and make sure there are no nicks in the pipe
best of luck
Jan 02, 2011 | GE WBSR3140DW Top Load Washer
* touchpad
Feb 24, 2010 | GE Profile WPRE6100G Top Load Washer
Our GE Profile dryer keeps shutting off, regardless of setting, after it has run for 4 or 5 min. Could it be overheating or maybe the vent to the outside is clogged?
it certainly sounds to me like a blocked vent issue somewhere along the line and in order to prevent a fire the safety thermostat shuts the heater off. are you saying the dryer stops altogether, not just the heat?
Oct 24, 2009 | GE Dryers
I have a GE PDW8060GSS dishwaser. The washer does not turn on. The "anti bacterail" swith keeps blinking. There is some water standing inside the washer. Tried draining, but water keeps coming back. Not...
If after draining water comes back then you need to check the waste water system for any cloughs. Problem might even be at the dwelling drainage system as any blockages would prevent water from going out from washer. Check the waste hose, filter and pump. clean them all if needed.
Best of luck
Jul 09, 2009 | GE Profile PDW8060GSS Built-in Dishwasher
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
After instillation, the washer runs several times-then we noticed my hot water heater is shutting the pilot light off. Back pressure possibly on the Hot water side? Was purchased as floor model and N
what kind of water heater do you have?? as far as the washer it has a mxing valve inside the unit that mixes the hot and cold water to get the proper tempreture, write me gary1121@aol.com let me know about the water heatrer,, that is what you are asking about
May 19, 2009 | GE Profile WPRE6100G Top Load Washer
Ge profile whsb8000bocc
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
May 12, 2008 | GE Profile WPSR3120WWW
Washing Machines Logo
18 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
