Accurpress will not raise back up
Model 712010
    Sergeant:
  • 258 Answers
What is Accurpress?
Posted on Apr 17, 2014
Can't get plate screw loose. My feed dogs won't come back up
Difficult to respond without knowing the make & model.
Removing the needle plate generally will not allow you to raise the feed dogs. There is a lever, knob, or something on the machine that should raise the feed dogs. Frequently, access to the actual feed dogs is through the door to the bobbin mechanism.
Nov 13, 2016 | Sewing Machines
How do I get the feed dog up on model 6235
The feed dog for that machine is NOT designed to be raised or lowered; instead a cover is put over the needle plate. You might want to remove the needle plate--it's designed to be removed to access the bobbin case--and see if you can pop it up again. On models that DO have the ability to raise and lower their feed dogs, once it has been lowered, if you press the dial or lever to raise it, it won't raise until the hand wheel is turned one or two times.
Sep 29, 2014 | Singer Sewing Machines
How do you calibrate an accupress break?
There are several models made by accupress. They dont offer any advice on it without service contracts. There is an advantage to that because the equipment that you need to use for calibration is expensive, there are several sensors that need to be checked and it is not easy to do. http://www.accurpress.com/literature.html
Jun 04, 2014 | Office Equipment & Supplies
We have a Magnavox TV model 20MS3442/17 bought in 2004. Without touching the remote control, the volume will lower very low and eventually raise back. If, when the volume is low, we raise the volume to...
1. Find the 5 & 12 or 9 v line caps. Try to replace electrolitic caps.
2.Find out the keypad pin from the processor and suck it. Then use only remote.
Oct 24, 2017 | Philips Magnavox 20MS3442 20" TV
How do I raise the feed dob--I cleaning out the machine and put it back together--now the feed dog will not come up
By any chance, is this a machine that has a lever or buttons to raise and lower the feed dogs? You do not mention the make and model of your machine, therefore, not as easy to be more specific with an answer.
Oct 31, 2010 | Kenmore Sewing Machines
Ryobi (new) will not till forward. Model RY60502
mine did that until i raised the drag stake to barely touch the dirt and sometimes i have to raise the tines out of dirt and dig back in hope this helps
Jun 09, 2009 | Ryobi Cultivator
Pop up Camper will not raise up when cranked
The cable pulleys will be behind something in each corner of the camper , you will need to remove the wall somehow at the bottom corner , sometimes depending on the model it is easier to remove the outside panel and put the cable back on the pulley then put the outside panel back on , be prepared to damage it though as they can be very stubborn to remove but you can repair it later .
Jun 04, 2009 | Arc'Teryx Rock & Ice Climbing
Feed dogs
There is a switch somewhere below and on the freearm....depending on the model, it may be front, rear
(or inside the front door if a front loading bobbin machine)
.........flick the switch left or right to raise/lower,
(up or down if front loader)
.......just remember the handwheel needs to rotate one full revolution to re-engage raised feeddogs after being dropped.
If you still have trouble, post back with details of the model......
NOTE: some lesser models do have a legacy moulding where the switch would be, but do not have the actual function.
Jul 27, 2008 | Janome Sewing Machines
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
