Question about Tivoli Audio® Music System Shelf System
Tivoli syssstem won't work without remote
My system used to work fine but now system works only with remote. did i mess something up while fumbling around with the controls in the dark? I tried removing batteries, and unplugging for 60 seconds, still nothing.
2 Suggested Answers
SOURCE: tivoli model two - low/no sound in base unit
I have exactly the same problem but found two work arounds, either one that I am completely satisfied. 1. unplug and replug the AC.
2. I have a subwoofer, when I plug the subwoofer cable half way in, the sounds of the base speak goes back to normal (but not all the way in)
Posted on Nov 22, 2009
I have a Tivoli Music System radio/CD player. When it is moved to another room and plugged in at the new location, it won't run! The screen lights up a little, but has to sit for 30-40 minutes bef
The Tivoli Music System must be left without power for a minute (60 seconds or more) anytime it is unplugged, before being plugged in again. If you observe this little rule when changing rooms, it should turn on and be usable immediately (after ensuring it has been at least a minute since it was last connected to power.)
Nov 18, 2012 | Tivoli Digital AM/FM/CD Hi-Fi Music System...
My car was running fine. I turned it off and now it won't start and my keyless remote or trunk opener or nothing works. The horn won't even honk. Is this something to do with the anti theft...
Might possibly be. Pontiacs were really tied into that anti theft security system. They were notorious for breaking. Here is a link to a site about these SECURITY systems. And possible DO IT YOURSELF solutions. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 21, 2011 | 2006 Pontiac Grand Prix
My emerson remote will only work sometimes even with new batteries. i push any button nothing, then if i fumble with the batteries and mess with it for awhile it might work? i just need a phone number for...
Try fixing your remote controller.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part of the circuit board, with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 26, 2010 | Emerson Premier SR110 Remote Control
Tivoli radio sticky case
I have the yellow songbook and it was so sticky and dirty after only a couple of years. I only use it inside, so I removed the sticky coating with nail polish remover and a ton of cotton balls. It worked really well on the yellow one - the finish is a little dull so it matches how it looked when it was new. And it's so clean now!
Apr 09, 2010 | Tivoli SongBook Clock Radio
Tivoli Audio Music System: CD wont eject
We've had the Tivoli Music System for 3 years. A CD became stuck in the player when I pressed the EJECT button before turning the player on. We tried turning it off and back on, unplugging it for a minute, removing the batteries and unplugging, etc. Nothing worked. I finally turned the player upside down in my lap, then turned on the CD player, and it said LOADING! Progress!!! I turned it right-side up and hit EJECT, and it worked like new. The CD loading mechanism had become bound up and simply needed a different "attitude" adjustment. Don't give up too early in attempting to fix these players on your own.
Feb 17, 2010 | Tivoli Audio® Music System Shelf System
Need to replace home theater subwoofer-Tivoli TDHT1 is the system
You please check the ohms with the woofer watts so that the same frequency of the woofer you can fix of different company, otherwise there will be damage of the circuit board so please use the appropriate frequency of woofer speakers.
Mar 28, 2009 | Audio Players & Recorders
Tivoli model two - low/no sound in base unit
Dec 26, 2008 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli Stereo Speaker
Any speaker has the potential to be used as a computer speaker. The problem you will run into is what will be used to power the speaker. Typical computer sound connections do not put out a strong enough signal to power a full sized speaker on their own. If you hooked the computer to an amplifier and then to a speaker it would work fine. If you do this, I recommend using the line out connection on the computer instead of the headphone connection.
Jul 20, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Problem with Amp sustaing Power
I fixed it. Believe it or not, it was a fuse. I looked at them all and they did not look blown. So I got mad and replaced the remote wire and the fuses. And when I put in the last fuse it was fine. Apparantly from diligent research, fuses can look ok but have issues with soldering problems. Thanks peeps.
Mar 03, 2008 | Alpine MRD-M300 Car Audio Amplifier
Tivoli Audio® Music System Shelf System Logo
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
