Question about Bruder MAN TGA Container Service Truck
What does a flashing Red triangle mean?
A "Red Triangle" keeps flashing non-stop. Also "Check TCO" keeps flashing!
  • Tony Oludemi
    Tony Oludemi Apr 17, 2014
    Thanks. That was bang on!
    New Friend:
  • 29 Answers
TCO means that the tachograph does not work properly. Because the european legislation is very strict regarding the malfunction of the tachograph system, the truck manufacturers alert the driver about his critical situation with a warning sign, the red triangle that flashes.
Posted on Apr 17, 2014
I defrosted my Electrolux intuition chest freezer yesterday and the red warning triangle on the lid won't stop flashing now. Why?
Check the temperature inside the freezer, chances are it just is letting you know it hasn't reached the correct temperature yet.
Aug 11, 2016 | Electrolux Freezers
It's shutting off while driving the red triangle show up it tell me to to safely now and shut completely off why does it do that
I think its telling you to stop the engine as safely as you can, such as not in heavy traffic. If the engine computer sees the engine is running too hot it will shut it down to prevent damage.
Have you checked the radiator and is the cooling fan working ?
Feb 20, 2014 | 2006 Ford Escape Hybrid
My printer will not print the orange light keeps flashing what can i do i got a refill cartridge
Hello.
Hold down the Stop/Reset button for approx 10 to 15 seconds (it has a red triangle stamped on it).
This dis-ables the ink level monitoring and allows you to print.
Regards GM
Jul 15, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Light with the triangle flashing - printer stopped
That means ATTENTION, you are either out of toner or have a paper jam.
Feb 18, 2010 | HP LaserJet P2015 Printer
Have a Kenwood KAC-9104D the red triangle is flashing
maybe when hook up something sorted and blew the sub side .I have seen it happen
Nov 27, 2009 | Kenwood KAC-9104D Car Audio Amplifier
My xc 1040 the little triangle keep flashing red and wont let me do anything else
Hello sir; The red triangle indicator light on, it means need toner, just replace toner cartridge shpuld be fine.
Nov 04, 2009 | Xerox Office Equipment & Supplies
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My kenmore series 80 electric dryer does not heat. I am replacing the TCO, but it does not appear to be hooked up. There are red wires going directly into the heating element, but the TCO lead is...
Yes, hook it up, but before you do that Vacuumn every piece of lint out of the cabinet. Also check TCO and check the thermostats for continuity. They should all read zero ohms.If one of them is open, replace it.
Also use your ohmmeter to check the heating element, It should not show an open condition.
Jul 29, 2009 | Kenmore 63942 Dryer
Oven not heating
Gallow, Whirlpool put out a service flash on this model concerning the TCO located in the back. Regarding oven wont heat up, control panel normal. It has to do with the TCO (thermostat fuse) located just under the vent in back and it's tripping. Since you had the elements checked out, Im suspecting this TCO. Usually when these thermostats open, they are non resetable and you don't have any heat at all. The best thing to do is check this TCO with a meter. If it shows open, thats probably the culprit. They recommend moving the new TCO over to the left about 6 inches so it is not directly under the vent. You are going to need help pulling the built in out just far enough to get at the TCO. The part number for it is 4450934. The service flash is 22-647. Catriver...post back.
Oct 11, 2006 | Whirlpool RBS305PD Electric Single Oven
Bruder MAN TGA  Container Service Truck Logo
184 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
ptpumpman
Are you a Bruder Toy Expert? Answer questions, earn points and help others
