Question about Casio Watches
G shock g5100 has stopped working it's not the battery
G shock g5100 has stopped working not the battery any ideas
I had a G Shock that quit working. I just ended up replacing it.
Apr 16, 2014 | Casio Watches
I have G-shock 3011 and it stopped working after a session of sea walk
if you dry the watch out completely and the battery is good it might work again. when the battery is removed there is often a couple of pins you need to short out before the watch will work
http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html
Apr 06, 2012 | Casio Watches
The watch has stopped working reset to 1.1 date new battery?
It sounds like it. Take it to a local dealer who will change it for you.
Feb 18, 2010 | Casio Atomic Solar G-Shock GW1210A-1AV
Replace battery on g-shock
It is advisable to take your watch shop and ask them to replace the battery for you.
One of the cries for help that appear on this web site is "I have changed the battery and the watch doesn't work now".
It is not really worth the risk of doing it yourself.
Feb 07, 2010 | Casio G-Shock G600-1AV Wrist Watch
Watch Stopped Working
The battery is empty, replace it yourself or take it to a local watch repairer / dealer, he or she will probably charge you around 5 $ for the new battery and replacing it.
Jan 31, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G Shock G2800 keeps going blank and resetting itself!
You have to change the battery. After that your watch will be back to normal.
Rate me, plz.
Jan 10, 2010 | Casio G Shock Tough Solar Digital Sports...
I've changed my battery on my casio g-shock dw 003 but the illuminator no longer works! why?
Did the same with my DW-003 and thought I'd broken the Illuminator (and the alarm didn't work). Next battery change was via a shop and the illuminator worked again (as did the alarm). This was just a battery cahnge, rather than a repair job - One of those things, I guess
Sep 30, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Buttons topped working
did the inside of the watch get shifted when the battery was put in or cover repleced. So the out side button doesn't touch the inside sensors.
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
37 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
