Question about W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer
The water and solution leaks out over the left side wheel and doesn't feed to the sprayer as it should
The water and solution doesn't feed through the pipe as it should it leaks out over the left wheel instead of feeding through the pipes to spray the carpet.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 55 Answers
So either the pipe is cracked or there is a missing gasket. Assuming this device was fully assembled when you received it I would check for any cracks or damage inside the containers or at the point of leakage. The best advice I would give for this is to return it if under warranty or send it to the manufacturer for servicing. If you're a serious DIYer you could disassemble it, the damage will be apparent from there.
Posted on Apr 16, 2014
  • Jane Jarman Apr 26, 2014
    we assembled the machine ourselves and I wonder if there should be a washer where the leak is coming from as definitely no cracks in it. Thanks
Windshield wiper fluid leaks
pipe from washer bottle could be cracked or perished. try follow pipe from water bottle to sprayers and check condition of pipe. sounds like leak is close to bottle
Jul 12, 2016 | 2009 Nissan Xterra
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
Apr 04, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Kitchen faucet sprayer I have a Delta classic single kitchen faucet and I have a side sprayer too. When I try to use the side sprayer the water stops at the faucet and barely trickles out the sprayer and...
There could be a clog anywhere between the diverter and the sprayer. Sometimes the line collapses from age and has to be replaced. Look under the sink to check for leaks.
Jan 20, 2014 | Plumbing
DW60CE dishwasher - E6 fault flood switch activated. Unit has not been use
After tipping the dishwasher on its side & it releasing its water from its tray, the fault cleared. I removed the bottom cover & inspected its internals for traces of a leak or evidence of leaking.
I could follow the calcium or detergent trail from the rear water duct connection near the top feeding sprayer arm, down the back of the dishwasher & into the tray. The lock nut on the duct where it enters through the inside S/S skin had become loose & simply needed to be tightened.
Jun 09, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water leaks out of the bottom
If you see water leaking it might be that the plastic has a broken, try to seal it with super crazy glue.
Thanks
Jul 01, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
It is only one year old and only been used last summer when i got it out this spring the detergent will not dispense
take off clear tube that goes into solution jug(where soap goes),make sure it is clear(water passes thru it easily) use a soda bottle- fill with vinegar- reattach hose and put other end in soda bottle- if this doesn't work that valve in the sprayer itself is gummed up- sometimes using HOT water feed sprayer will clear an internal plug
May 10, 2011 | Briggs & Stratton Prosumer 20324 Gas...
Not cleaning leaving residue - top sprayer doesn't spin
check spray arm for food residue build-up,if its clean then it may be the water feed conduit from the bottom tub up to the arm on top that leaking by and losing water pressure
Oct 14, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
Top sprayer arm is not cleaning cups any more
Hello. Make sure the water tube that feeds the top sprayer is properly attached and aligned with the water source in the rear of the machine. Sometimes the rear end of the hose gets dislodged and does not feed water to the top sprayer as it should. Joe
May 05, 2010 | Dishwashers
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
The clothes in the washer dryer at the end of the wash are really hot and therefore start to shrink the dryer button is not on and the wash is on a 30 degree heat can you help?
If you have washer set for a warm rinse and the cold water inlet screen is restricted you will get too much hot water. Another thing I have seen is if another near by faucet has a sprayer on it and the sprayer is off, but the hot and cold valves supplying the sprayer are on, the hot water can feed back through that faucet and give you an increased rinse water temp in your washer. Also, make sure hot and cold hoses are attached to the proper side of the inlet valve.
Sep 02, 2008 | Whirlpool Washing Machines
W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer Logo
250 people viewed this question
Top Vax Vehicle Parts & Accessories Experts
daf62757
Level 1 Expert
ray gallant
seanwalters1
Level 1 Expert
Are you a Vax Vehicle Part and Accessory Expert? Answer questions, earn points and help others
