List all the elements of B that belong to the specified set
List all the element of B that belong to the specified set b= 16, square root 7, -16, 0, 3/7, -7/3, 1.3, square root 16
SOURCE: ti-89 titanium SIN!!!!!
The answer that you have received in actuality is correct. However, it is in exact form when the answer that you were looking for was an approximation (decimal form) answer. To achieve this all you have to do is hit the alpha button (the yellow button with a diamond in the center) and then enter which will give you your desired answer :-)
Posted on Jan 15, 2008
  • 7993 Answers
SOURCE: TI-15 square root Function
You should enter it as follows [SQRT]36 ) [ENTER/=].
If you define some function f of a variable x you write that f(x), where the parentheses enclose the so-called argument (objet on wich the function acts). It seems that on this calculator the opening parenthesis is implicit: the calculator supplies it when you press [SQRT] but does not display it (a design flaw?). However the closing parenthesis must be entered by you to signifie to the function [SQRT] that you have finished entering the argument. Weird but one can live with it.
Hope it helps.
Posted on Sep 07, 2009
  • 14 Answers
SOURCE: Square root
It may be that you have somehow changed to a 'mode' that only shows integer values.
Try pressing the green button, then 5, then 9. Then try the calculation again.
If this fails, you can use Google as a calculator - search Google for sqrt(0.4053) and see what happens.. :-)
Posted on May 28, 2010
  • 7 Answers
SOURCE: When I enter the square
Instead of hitting enter, hit diamond, then enter. The calculator will then give you a decimal approximation. Alternatively, you can go to F2, approx( and enter in the root you need approximated. Another method is to go to the MODE page and scroll down to Exact/Approx and change it to approx. That way it will work the same as a TI-83/84 and always give a decimal answer.
Posted on Aug 29, 2011
  • 7993 Answers
SOURCE: i dont know how to
To calculate a square root you press the square root key. A radical will be displayed. You type in the positive number whose root you want. Press the EXE key.
Posted on Jan 14, 2012
Is it possible to calculate factors using a TI-30x IIS
I believe factors can be calculated on any basic calculator.
Starting with 1, increasing by 1 until you get to square root (number) + 1
Let's do an example.
28
square root (28)+1 = 6
Factors
1, 28/1=28
2, 28/2=14 14*2 - 28 = 0 (when you divide, you get no decimal)
3, 28/3=9.33333 - not a factor - doesn't go in evenly
4, 28/4 =7
5, 28/5=5.6 - not a factor - doesn't go in evenly
6, 28/6=4.66666 - not a factor
So now we can list our factors - 1, 28, 2, 14, 4, 7
Putting them in order, we get 1, 2, 4, 7, 14 and 28.
Good luck,
Paul
Jul 13, 2016 | Texas Instruments TI-30 XIIS Calculator
Checking ohms on whirlpool dishwasher heating element
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Rated voltage squared divided by rated wattage = ohms
Element rated for 240 volts and 3500 watts
240 x 240 = 57600
57600 divided by 3500 = about 16 ohms
Gene
Sep 09, 2014 | Water Heaters
What Has The Same Value As Square Root Of 7 Multiply By Square Root Of 15
(Square root(7))*(Square root (15))=(Square root (7*15)=Square root(105)
Mar 29, 2012 | MathRescue Word Problems Of Algebra Lite
When I go into the 1 Var-Stats menu, I need to type in L1 and L2 but my comma button will not work. It will only let me type in one list at a time, and if I put two lists in without a comma it says error....
If you are performing 1-variable statistical calculations, that presupposes you have one set of data only. Technically all you need is ONE LIST where the data is stored (ex. L1) . However if you have some data elements that are repeteated, you may choose to create a second list where you enter r the frequency (L2 or other). Both lists must have the same dimension (length).
When you bring up the 1-var calculation menu , the list of data elements is specified on one line (Xlist) and the fequency List is specified on the menu line Frequency. Thus there is no need to enter two lists on the Xlist line.
Oct 16, 2011 | Texas Instruments TI-84 Plus Calculator
My remote broke a few yrs ago. I need the tv code to enter in my comcast universal remote (can't find Element code anywhere?
Sounds like a re-branded set. Sold under different name than original manufacturer.
1-800-comcast they will get you the code. If there is no code specified, they can walk you through the procedure to search a working code. I assume you do not have the pamphlet / instructions for that. If you have the code list thing, it should have the manual search procedure on it. Quite simple to do.
Jun 14, 2011 | Element Electronics FLX3220F 32 in. LCD TV
Is there a positive/negative sign all in one on the ti-84? like to use for the quadratic formula... -b (plus or minus[symbol here?]) the square root of... the rest
No. The calculator can calculate either value at one time, but not both. You can calculate the positive and then the negative (or the other way around), but a single calculation cannot produce two answers. A calculation can produce, for example, a list with two elements, but that's still a single result (a list).
Feb 19, 2011 | Texas Instruments TI-84 Plus Silver...
How to put html element list item
Hi!
Please have a look here... Under "Elements for the BODY section" you'll find explanations/definitions of the different "list" elements!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Jan 27, 2011 | Game Elements HV-5 (GGE904) Wheel And...
How do you tak the square root of 64 or the 4 root of any other #
Hi shiny_diamon
Here is a picture of the powers and root functions of your calculator.
1.To calculate the cubic root of a number you use the key combination shown on line 5
Ex: Cubic root of 27
27 [2nd] [3 root x] [EXE]; Should get 3
2. You can use the general root key on line 7 [2nd][x Root y]
Ex: Cubic root of 125
125 [2nd][ x Root y] 3 [EXE] Should get 5
(-125) [2nd][x Root y] 3 [EXE]; Should get -5
3. You can also yse the general power key on line 6: [Y to x], but the degree of the root is entered as a fraction 1/3
Ex: cubic root of -125.
(-125) [Y to x]( 1/3) [EXE]; You should get -5
4. The [Y to x[ key is the one you use to obtain all other roots fourth, fift, tenth, n-th.
Ex: Fourth root of 256
256 [Y to x] (1/4) [EXE]: You should get 4
5. To extract the squqre root of a number you can use the key on the 3rd line [root x] or the general power key on line 6 with exponent 1/2
Exemple square root of 256
256 [Root x] [EXE] should give you 16
256 [Y to x] (1/2) [EXE] should give you 16 also
Hope that helps.
Nov 08, 2009 | Texas Instruments TI-30XA Calculator
Square roots
One way is you get square root by raising to the (1/2) power. For example square root of 16 is
16^(1/2).
You can use this method to get the other "roots" as well e.g. 1/3, 1/4, etc.
Apr 02, 2009 | Texas Instruments TI-30XA Calculator
jasbo
jasbo
