Question about Brother IntelliFAX 2800 Laser Fax
NG: poor line quality - Brother IntelliFAX 2800 Laser Fax
3 Suggested Answers
ziraffa
  • 827 Answers
SOURCE: OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Posted on Dec 21, 2008
F Victor man
  • 825 Answers
SOURCE: NG Codes poor line quality
To check your line quality is very simple. Unplug the fax from the telephone line and substitute it with a normal single line telephone. Make an incoming and outgoing call. if you hear any echo or crackle on the line when you are being quiet, then you have a noisy line and you should report it to your telephone company to have the line cleaned. If it is quiet then the problem lays with the fax. There are ways around the problem in the software of the machine but its quite complicated and best left to a trained brother engineer.
Posted on Sep 24, 2011
NG Codes poor line quality 4100 E Intellifax by Brother
Sep 08, 2011 | Brother IntelliFAX 4100 Laser Fax
What does NG mean in the TX/RX log?
NG just means the fax was unsuccessful or No Good. After the NG should be another number code that tells what type of error it was. Could be busy on the other end, poor line quality, or any number of things.
Jan 12, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Brother Inellifax 4100e will not send
It appears that you have interference somewhere in the office. Have you recently gone to DSL in the office? A DSL line transmits a signal that requires a filter to receive only phone signals instead of the DSL signal. If the fax machines are receiving an unfiltered DSL signal, this would explain the interference. If this is not the case, the link below is a Brother's Solution to the NG Poor line quality. Best of luck to you with your fax problem.
Greg
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000200/000009/faq000209_002.html?reg=us&c=us_ot&lang=en&prod=mfc6490cw_all
May 12, 2009 | Brother IntelliFAX 4100 Laser Fax
MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Apr 29, 2009 | Brother MultiFunction Center MFC-440CN...
Error 20 01 NG: poor line condition on outgoing fax's
My fax shows poor line condition. I have checked all of the connections and everything is ok. Perhaps my settings are wrong
Jan 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 shooting out blank sheets
The machine told you poor line quality. Try a different phone line to verify. Try it at a friends house to verify it. If you are using Vonage, that is the problem. I have Vonage and every fax I test with has some issues with poor line.
Aug 07, 2008 | Brother IntelliFAX 4100 Laser Fax
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
Fax busy, no response yet fax is sent ok
NG or poor line condition on the transmission report means that there is interference on the phone line.you need to double check the quality of the dial tone-if it static or clear.now,other interferences could be caused by other devices on the same line as your fax such as DSL modems.make sure first that you connect the brother machine directly to the walljack and try resending a fax.modem settings can be changed.e-mail me if you need that info
Mar 18, 2008 | Brother IntelliFax-2820 Laser Fax
NG: POOR LINE CONDITION / OUT OF MEMORY
You can adjust the Compatibility mode. This adjusts the sensitivity of the machine to interference on the phone line by lowering the transmission speed:
a. Press Menu, 2 (Fax), 0 (Miscellaneous), 1 (Compatibility)
b. Press Up or Down arrow to select "Basic"
c. Press OK.
d. Press Stop/Exit.
e. Try resending the fax.
If the problem continues we recommend you try the unit on another line at the current location or another location. Always restart your machines after you made changes, that way you will see the results.
Feb 26, 2008 | Brother IntelliFAX 5750e Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
